Question about Car Audio & Video
Slave hard drive
Hello
when you go to the bios do you see the disk in there? also is the jumpers set correctly? other disk as master and other disk as slave.
  • Ekse Jul 08, 2008
    ok, are they on the same cable? can you try both disks in difrent cables also look in bios and see if the ide channels are disabled or turned off.
    double check the jumpers also try the disk that is not showing up alone and see if it appears.
    You can also try loading the defaults on your bios incase something is turned off. the button is marked on the screen somewhere or in the main menu.
No io don't see the disk in there.
\Yes, the jumpers is the clip you remove and re position.
Posted on Jul 08, 2008
NEED JUMPER SETTINGS FOR MASTER HARD DRIVE
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
Jumper settings for master drive
if its a SATA hard driveyou dont need to set master slave the biggest capacity hard drive will set as master
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Oct 03, 2011 | Dell Computers & Internet
Can anybody tell me detailed settings for MoBo D102GGC2 ? In actual i bought 1TB wb hard disk. But during installation process setup is not showing 1TB hard disk. It is only showing old 80 gb hard disk. ...
Go to start and right click on my computer and scroll to manage and click...Computer Management will appear on this click Disk Management.You will see the hard drives you have..If the 1TB hard drive is visible and unallocated in the status column Format hard drive to NTSF..Right click on the 1TB drive and format..
Sep 16, 2011 | Intel D102GGC2 Motherboard
How to set up jumpers when adding harddrive on master and slave
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
Jumpers for a PC hard drive are next to the power connector. Mostly in between the power connector and the data cable connector. These are used for setting up Master/Slave settings and also to limit capacity of the HDD seen by PC BIOS on some older hard disks. Usually settings which are selected by jumper setting to various locations are printed on the hard disk information sticker.
hope this helps
May 14, 2011 | Dell Computers & Internet
How can I set either of two drives to master/slave in bios
> set in BIOS.
It is impossible to change any BIOS-settings to assign "master" or "slave".
Instead, if you have _internal_ disk-drives, there are a grid of gold-coloured pins on the disk-drive,
between the "data" and the "power" connectors, and three jumper-positions,
namely MA(ster), SL(ave), and C(able)S(elect).
If you have an _external_ storage device, then if you open-up the enclosure, and look at the jumper-settings on the disk-drive, it always will be set to "master", because there will always just exactly _one_ disk-drive inside the closure.
Nov 03, 2010 | Western Digital WDG1C2500N MyBook Premium...
Bios Fail to detect Local Disk C and DVD-RW
I'm going to make an assumption here and guess that you have both hard drive and cdrom plugged into the same IDE cable. I think you have either 2 masters or 2 slaves and that is why the bios can't see them. On any one cable you can have a master and a slave. Drives have to be jumpered to configure them as a master, slave, or cable select. Cable select requires a certain kind of cable but in that system the master is the drive plugged into the first plug-in away from the motherboard or the middle plug and the slave is the second one or end plug on cable. If you can jumper cable select and then plug the hard drive into the middle plug on the IDE ribbon and the CD rom to the end one then you'll have a master and a slave. Bios should then read the drives. If that doesn't work then you have to jumper the hard drive to master and cdrom to slave. The cdrom is marked on the back as to which jumpers you use. MS/SL/CS. master/slave/cable select. The hard drive usually has jumper settings on the front of the drive but you might have to look up on manufacturer's web site. Most computers use cable select now.
Dec 06, 2009 | Audio Players & Recorders
Slave jumper settings for a 2.5 Hitachi DK23DA-20F hard drive
Most hard drives I've come across have tiny little letters on the PCB next to the jumpers that say MA SL CS which are for master, slave, and cable select. If that doesn't work, go to Hitachi's website and search their support section. There is a diagram of the jumpers for that drive out there somewhere. Good luck!
Nov 07, 2009 | Hitachi (DK23DA-20F) 20 GB Hard Drive
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Mar 29, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Need master slave configuration
You should have a jumper configuration written somewhere on the front (up) side of the hard Disk ... Look there, or look just around the Pins... Look for M, S, CS (Master, Slave, Cable Select)
Darko, Serbia
Mar 20, 2009 | Western Digital 60GB U100 5400RPM 2MB...
Car Audio & Video Logo
67 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
