Question about Acer Aspire 5500 5570-2609 Laptop
My computer is an hardware and software error .how to fix it
  • 46 Answers
What is the error? could you be more specific please?
Posted on Jan 04, 2011
Tip
How to Fix Computer
If you face any problem with your computer system you can either fix ityourself or get it fixed by a computer professional. You need to fixall the hardware and software related errors for proper functioning ofyour computer.
Hardware and software errors
The common problems faced with the computer hardware includes the harddrive failure, power supply failure, motherboard failure, CPU failure,video card failure, USB device failure, and many others. The commonproblem with software includes - programs refuses to install, programdoesn’t load or takes more time to load, software functioningimproperly, operating system failure, incompatible device drivers, andother related issues.
There can be a wide range of problems which might occur in your PC dueto several unseen and even unknown issues like your computer does notturn on, you see a disk error message when you log on to your systemand many others. If you are a Windows user then you can find the helpfor most of the common hardware and software related errors on yourcomputer itself. Microsoft Windows offers a help section mentioningsolution to some of the most common hardware and software relatedissues.
Windows "Help and Support" center
You can have a quick access to Windows help and support centre inWindows XP systems by clicking on the "Start" button followed byclicking on the "Help and Support" center. Similarly, you can alsoaccess the "Help and Support" centre in other versions of Windowsoperating system. The help center carries a database of the most commonproblems and solutions. After opening the help center you can type thesearch term in the search box to find the solution. It will display alist of results on the basis of the search query. It is yourresponsibility to find the best solution for the problem you are facing.
In case of system failure you can carry out some of these troubleshooting steps to solve this issue:
  • Check if your PC is plugged into a power source and it is switched on.
  • Reboot your PC to check if the problem still persists.
  • Restore your system to an earlier state.
  • Scan your PC hard drive for any errors.
  • Check for any memory problem.
  • Check for any device driver related issue.
  • Reinstall the operating system.
Finally if you are still unable to solve the issues then don’t proceedon making some irrecoverable changes, you can avail online help from atech support company who can solve your problems through remotecomputer repair service
on Feb 02, 2010 | Computers & Internet
Hp black screen
Computer black screen of death is usually related to hardware or driver. It is typically caused by software errors in device drivers: in Windows systems by poorly written device drive , It also be caused by physical hardware faults, such as faulty RAM memory or power supplies, overheating of components, or hardware which is run beyond its specification limits . On the other hand, registry damage,corrupted program and viruses are the major causes of computer black screen,too. According to the issue you've got, the following tips may be available to you.1.An efficiency troubleshooting step on hardware is to start your computer with the minimum hardware necessary to run the operating system. If your computer starts successfully it proves that one of the removed hardware devices was the cause of the STOP message. Otherwise move to the next solution.
2.Boot your computer in Safe Mode by pressing F8 at startup. Then go to My Computer and right-click on Disk C to select Properties from the dropdown menu. From the Tools tab, perform an error check and disk cleaning. 3.If the about two solutions doesn't work, the last one I can suggest to you is to create a bootable disk. It is the most quick and effective way for you to solve the problem. You just need to download a software can be used to burn your CD/usb into a bootable one and then boot your computer from it. Run the software to fix the issue after that. There are a lot of software for you to use,Windows Boot Geniusowns a better performance among such kinds of software I've used. It is a multiple windows repair tool which can be used to fix all computer errors, create bootable CD/USB, recover data lost and unlock windows password, etc.
Source:
http://www.windowspasswordsrecovery.com/windows-boot/
Mar 21, 2013 | HP Pavilion Computers & Internet
The computer is powered on but the screen is completely black
2.Boot your computer in Safe Mode by pressing F8 at startup. Then go to My Computer and right-click on Disk C to select Properties from the dropdown menu. From the Tools tab, perform an error check and disk cleaning. 3.If the about two solutions doesn't work, the last one I can suggest to you is to create a bootable disk. It is the most quick and effective way for you to solve the problem. You just need to download a software can be used to burn your CD/usb into a bootable one and then boot your computer from it. Run the software to fix the issue after that. There are a lot of software for you to use, Windows Boot Genius owns a better performance among such kinds of software I've used. It is a multiple windows repair tool which can be used to fix all computer errors, create bootable CD/USB, recover data lost and unlock windows password, etc.
By the way,reinstall your operating system can also help you out if nothing important stores in it.
Source: http://www.reset-password.net/black-screen-of-death-and-blue-screen-of-death.html
Mar 06, 2013 | Gateway LT4008u Atom N2600 Netbook
Screen goes black just after the hp logo
Mar 06, 2013 | HEWLETT-PACKARD HP G62t350 156 Gray...
Bsod
Computer blue screen of death is usually related to hardware or driver. It is typically caused by software errors in device drivers: in Windows systems by poorly written device drive . They can also be caused by physical hardware faults, such as faulty RAM memory or power supplies, overheating of components, or hardware which is run beyond its specification limits . On the other hand, registry damage,corrupted program and viruses are the major causes of computer blue screen,too. According to the issue you've got, the following tips may be available to you.1.An efficiency troubleshooting step on hardware is to start your computer with the minimum hardware necessary to run the operating system. If your computer starts successfully it proves that one of the removed hardware devices was the cause of the STOP message. Otherwise move to the next solution.
2.Boot your computer in Safe Mode by pressing F8 at startup. Then go to My Computer and right-click on Disk C to select Properties from the dropdown menu. From the Tools tab, perform an error check and disk cleaning. 3.If the about two solutions doesn't work, the last one I can suggest you is to create a bootable disk. It is the most quick and effective way for you to solve the problem. You just need to download a software such as TenorshareWindows Boot Genius. It owns a better performance among all kinds of software I've used. Windows Boot Genius is a multiple windows repair tool which can be used to fix all computer errors, create bootable CD/USB, recover data lost and unlock windows password, etc.It is as easy as three steps to fix your computer by use the software:Step 1. Create a bootable usb or cd by this software
Step 2.Set your computer boot from CD or usb flash drive
Step 3.Fix computer blue screen after running up Windows Boot Genius
http://www.windowspasswordsrecovery.com/fix-windows/blue-screen-of-death.html
Mar 03, 2013 | Acer Aspire Computers & Internet
My acer p205h moniter goes black after 5 secs on start up
Source:http://www.windowspasswordsrecovery.com/fix-windows/black-screen-of-death.html
Feb 26, 2013 | Acer P205H 20 inch Monitor
Cd drive code 39
What the Code 39 Error Is
CD-ROM/DVD Drive Cannot Start. (Code 39)
Code 39 is an error specific to the device manager. It is directly associated to drivers and errors that have occurred within them. Drivers are the small pieces of software that your hardware devices use to function. Each hardware device has it's own unique driver, developed by the hardware manufacturer, that contains the instructions allowing the hardware device to cooperate with other hardware devices and communicate with the operating system. Drivers are essential to the normal operation of any computer as they bridge the gap between hardware software.
Code 39 errors are amongst a wide array of device manager errors that all point to the same problem: the driver. It is not uncommon for drivers to become corrupted and produce errors during normal operation. Drivers are accessed constantly for every operation that a hardware device performs. Because of this, there are thousands of opportunities for errors during a single session of Windows. Because of this high rate of failure opportunity, many users have experienced Code 39 errors as well as many other device manager errors.
manually fixing Code 39 errors. Updating to the most current driver will replace the corrupted file with a new, better driver. Updating the driver will not only correct Code 39 errors but it will also introduce greater speed, performance, stability and compatibility. Driver updates are changes that the developer made to the original driver in the interest of all-round improvement. Driver updates often correct many other errors that are related to device incompatibitlity.To learn how to fix Code 39 errors manually, read this guide. The guide will provide steps for manually finding, downloading and installing the most current driver avaiable for your hardware devices. However, it is generally MUCH easier, safer and more reliable to use an automated tool. We've discussed using an automated tool to fix Code 39 errors below.
DriverUpdate.DriverUpdate is an easy-to-use tool that scans your unique hardware configuration for any device driver problems. Drivers that are out of date, missing, misconfigured or corrupt can easily be re-installed automatically by the program. The benefits of this program are endless. Most users not only have error messages fixed, but also will see a performance improvement since all of their system drivers can be updated! ( click here to download DriverUpdate ) RECOMMENDED
Feb 23, 2012 | Dell Dimension E310 PC Desktop
PC crashes repeatedly, sometimes comes back on, screen says this!
this problem is cause by some hardware components. just make sure all of your hardware components are fixed correctly with mainboard. or else, if you installed any new hardware options to your computer, just remove that & try to start the computer.
if you still have that problem, just let me know!!
Mar 08, 2009 | E-Machines T2200 PC Desktop
I recently bought a HNC model CTGJD2028 3D Optical USB Plug and Play Mouse for my Compac Deskpro EN running XP Pro. Plugged mouse into usb port. Get a Popup Bubble – Found New Hardware – Mouse. Message...
UPDATE YOUR WINDOWS SOFTWARE FROM MICROSOFT OR YOUR VENDORS SITE, THERE MAY BE MORE SOFTWARE PATCHES FROM THE VENDOR TO FIX THAT TYPE OF PROBLEM
Aug 11, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
