Question about Carrier Heating & Cooling
Carrier Air conditioner. Turn the unit on and the green on light flashes. We have replaced the batteries in remote and cleaned the air filters. I saw a comment about water in the exterior drain pan. Do you know how we can find the drain pan?
  • 2,133 Answers
Call repairman to disassemble your unit and clean drain pan. And then restart.
Posted on Jan 02, 2011
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
Carrier 42csr series cannot turn on. Only green light at "operations" flashing. what can I do to start it or put it off? the remote doesn't seem to work on it right now.
Transmission problem between remote and PCB sensor. Please replace batteries in your remote and try. If not try with another same type remote. If still problem persists, problem with receiving sensor in PCB. Repair or replace it.
Jan 16, 2011 | Carrier 52PQ307 Wall/Window Air...
Problem with remote will not switch unit on or off
May be transmission problem. Replace new battery in remote and check. If not,check with camera phone focusing on transmission signal of your remote. Press any button in remote. If ultra light flashes, your remote is o.k. Other wise repair PCB where receiving sensor problem.
Dec 29, 2010 | Carrier (52PE315) Thru-Wall/Window Air...
Carrier Air conditioner. Turn the unit on and the Green unit light is flashing. But the system will not turn on. Have tried replacing battery in the contol, and the air filters have been cleaned.
make sure your getting power to unit is this a split or package if split make sure water is not in exterior drain pan this will kick the float switch out push contactor in see if it comes on if not check the capacitor please give me a rating and vote
Sep 19, 2010 | Carrier Heating & Cooling
Samsung air conditioner light flashes and switches off by itself
It could be the temperature sensor. It is the short , usually black wire that runs across the front of the air handler. Unplug it, and check it with a meter set to ohms. If it reads a value it is good. If you get nothing it is shorted, and needs to be replaced. If it reads good, you may need to replace the main board on the handler.
GOOD LUCK WITH THE REPAIR
Mar 10, 2010 | Samsung Heating & Cooling
My carrier A/C turns off by itself but the light blinks
Switch OFF the circuit breaker of ac, after 5 seconds. Switched ON the circuit breaker. If this will appear again try to check the wiring connection of ac.
Jun 17, 2009 | Carrier 36KCARMS Air Conditioner
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Heating & Cooling Logo
287 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
