Question about Samsung Washing Machines
My samsung fully automatic washing machine (model-wa85n2) cannot work after the power from the main got problem. all the led blinking and red led add the fuzzy is on..... how to fix it????
SOURCE: samsung fuzzy wasing machine WA75N6
sad to say, he is correct. when all indicaters come on together and do not extinguish, the board needs to be replaced
Posted on Jul 15, 2008
JAN_yuanjia
  • 470 Answers
SOURCE: Electrolux EW 1005f washing machine trouble.
try to go for the technician of washing machine, cuz you have the chance to replace it by replacing another board by there old unit that available and compatible to your washing machine
Posted on Mar 31, 2009
  • 174 Answers
SOURCE: Fully automatic washing machine with fuzzy logic.
if the water valve is energised for a long time with little or no water it can damage the valve coil. you may need a new water valve. most machines will limit the fill to a maximum time 5 to 10 min if a certain level is not reached an error code is generated (aeg is e10)
Posted on Jul 24, 2010
SOURCE: i need a manual for WA13UP Top load(samsung) washing machine
water running out at the draining pipe the while the machine fill itself with water
Posted on Sep 02, 2010
  • 6277 Answers
SOURCE: Hi.... i have daewoo 7
No promises but please try the following.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 20, 2011
Samsung UN55FH6003FXZA won't turn on even though the red LED on the front is lit showing power is available. It did have a long delay to turn on, now not at all.
Samsung TV won't turn on + blinking red light (explained fix ...
? 4:03
https://www.youtube.com/watch?v=wEWzYLaKdgU
Aug 29, 2014 - Uploaded by Mysimplefix
(CC) (HD) A step-by-step repair video, showing the replacement of swollen/shorted "electrolytic capacitors ...Missing: un55fh6003fxza
bout 1,270 results (0.53 seconds) Search ResultsSamsung LCD TV LN32A330 power won't turn on - Forums - CNETwww.cnet.com > Forums > SamsungCNETMy 1 1/2 year-old LCD TV model LN32A330 won't turn on by direct and remote today. The red stand-by light is lit, but never blinks and the TV won't power up. A..Samsung UN55FH6003FXZA BN94-06418R Main Board ...www.shopjimmy.com/samsung-un55fh6003fxza-bn94-0641...ShopJimmyThis Samsung UN55FH6003FXZA BN94-06418R Main Board IC901 EEPROM ONLY ... TV won't turn on after being off for 30+ minutes - TV shuts off by itself
Jan 05, 2016 | Samsung Televison & Video
Batter green red samsung
The rechargeable battery needs to be replaced, go to www.ebay.com type make and model of laptop, refine search to battery.
May 31, 2012 | Samsung Computers & Internet
Samsung UN46D7000 red light blinking and clicking
I have this exact same model "UN46D7000LFXZA" with the exact same problem and I also replaced the power board expecting that since that is where the clicking was coming from that would fix it even though there were no swollen capaciters. However, it didn't and the board is from a working pull so I knew that was not the issue. What I did is I unhooked the main board connection from the power board and turned it on to test a hunch, and instantly the LEDs powered on and no more clicking. I just received a main board in the mail switched it out a few minutes ago to confirm it was indeed a main board problem. I got mine for $114.99 on eBay after confirming that the part numbers that were slightly different were interchangable. I lost all of the firmware upgrades changing out the main board obviously but downloading and installing those is a small price to pay for finally having a working 3D TV back for less than the cost of the extended warranty.
I would suggest carefully trying the same thing and disconnecting your main board and make sure your LEDs light up. I bet they will. I was just guessing at the main board but since there are only two boards left after the power board was replaced and the other board should have no affect on the power board to my knowledge I think this will fix your issue too.
Apr 14, 2012 | Televison & Video
My Samsung fully automatic washing machine Model # WA13G2Q showing 1E error code.What do I do?
My Samsung fully automatic washing machine Model # WA13G2Q showing UE error code.What do I do? THIS IS MY EMAIL engrabih12@hotmail.com
Apr 13, 2011 | Samsung SW62ASP Top Load Washer
Water supply hose(cold) blocker dont work
i am sameer from india... i want whirlpool fully automatic washing machine pcb circuit diagram
Jul 28, 2010 | Samsung Washing Machines
Daytek DT4660 - at ac on , led grn for 2-3 secs, one blink red, pause, 2 blinks red, pause , 3 blinks red, pause ,then rapid 5-6 red blinks followed by repeat of above. I've unplugged the 12 volt connector...
Hi
I work on Daytek 4660 models. I have seen the problem you are having and have solved it a couple of times by replacing all the capacitors in the power supply. If you use an oscilloscope to measure the voltages they may appear fine, however I have solved this problem by replacing all the capacitors in the 2ndary circuit of the power supply. It doesn't always work, but has worked in about half of the TVs that have come in with this problem. Also, just to make sure, if you remove the shielding from the board that drives the LCD panel make sure the little smt fuse is good. It's right on the 5V power line close to the ribbon connector from the main board.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
Hi. After a Samsung washing machine error code chart. Where can I get one?
Try here:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
Jan 19, 2010 | Samsung SW62ASP Top Load Washer
Samsung LN-T3242H
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 26, 2017 | Samsung LNT3242H Television
Power led blinks red
See recently added Fixya service tip for this model.
Service Bulletin PDP 0068-01 Main Digital pcb see http://www.eserviceinfo.com/download.php?fileid=43450
May 03, 2008 | Fujitsu Plasmavision PDS-4242 42 in....
Washing Machines Logo
329 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
