Compaq 511 touch pad not working. i think it is not broken.
Pyrhyc
  • 2028 Answers
SOURCE: touch pad driver.
Uninstall the driver from the device manager, then reboot. The machine will find the touch pad and reinstall the drive automatically. If this doesn't work, check the touch pad connection, they will sometimes work loose ar get a little dirt/corrosion build up. The connection is under the keyboard. At this point, if it's still not working, then it has failed and will need replaced.
Posted on Jul 20, 2008
  • 19 Answers
SOURCE: my Touch pad mouse doesn'e work
hi. if its a physical problem, try using a eraser with it and then clean the thing with the eraser. i do it on my my laptop and it works for me. so yeah.
Posted on May 20, 2009
  • 90 Answers
SOURCE: left mouse button not working but touch pad is
Use a mouse :)
Posted on May 28, 2009
bordiavineet
  • 50 Answers
SOURCE: touch pad not working nor mouse buttons
touch pad driver is download is your laptop.
see site and download your laptop touchpad driver
http://driversdownloadsfree.com/get.php
download mirror ok
Posted on Feb 26, 2010
reyjoshua07
  • 1157 Answers
SOURCE: MY COMPAQ C745 EE [
Hi tintocochin2,
Based on your situation. I suggest trying the following steps:
1. You can download the sound driver from your here:
Download drivers
2. Select operating system
3. go to Driver - Audio section then download the driver
4. After downloading install the audio driver then restart your computer.
Hope it helps.
Thanks for using FixYa
Best regards,
Reyjoshua07
Posted on Jan 22, 2011
Why Acer aspire ES1-511-C6G7 touch pad stop working what could be the problem? the driver is up to date
I have a switch on my laptop that turns the touch pad on and off. Also, in some BIOS and/or OS settings you can enable or disable the on board touch pad.
Oct 05, 2014 | Acer Computers & Internet
Compaq v3000 touch pad not working
You probably forgot to plug the flat cable from the touch pad to the motherboard. If you remove the keyboard you should be able to see if the touch pad flat ribbon is plugged into the motherboard.
Jul 09, 2012 | Compaq Computers & Internet
Scroll is not working
This could be one or some of the 3 issues that may be happening with your notebook or netbook:
1) check control panel (if this is windows) and click on touch pad icon and make sure the sofware to control the touch pad is working and it's on.
2) If it is on, reinstall all touch pad and mouse drivers for this unit by going to the manufature's website and downloading the original drivers for this unit
3) it that does not work, you may have a defective or broken touch pad and it may need replacing
BEFORE CONTEMPLATING A NEW TOUCH PAD, do 1 and 2 first.
They are usually the main causes of touch pad failure and should resolve your issue.
If both fails you may need to order a new part to replace the pad.
I hope this helps. Write me back and let me know how it goes
Jun 14, 2010 | Compaq (153515-001) Touch Pad
Whenever i click on touch pad its not working
Try to check in the mouse properties if the tapping feature of the laptop is turned on. If the mouse button works and you can move the pointer throught the touch pad, then definitely its working.
Mar 29, 2010 | Compaq Presario CQ60-220US PC Laptop
Touch pad not working nor mouse buttons
download mirror ok
Feb 25, 2010 | HP Compaq nx5000 Notebook
Mouse pad over heat's and the cursor go's wild on the screen, complete loss of control of cursor, is the cpu below the touch pad? this is on my notebook by compaq presario v6000 /
It doesn't really matter if the cpu is located directly under the mousepad. Other things inside your notebook can produce heat. You will probably find that a fan inside the case isn't working.
Often the fan does not come on until the heat builds up so it is possible that the fan might be ok and the sensor that detects the heat may be broken.
A friend of mine told me that his internal fan wasn't working so he went out and bought one of those pads that you sit your notebook on. The pad has fans built into it. I didn't think this would be enough to draw the heat away but it worked for him.
Otherwise If your not comforatble pulling your notebook apart I'd get a professional to fix it.
Oct 21, 2008 | Compaq Computers & Internet
System freezing when touchpad not being used.
This will be one of three things; 1- a driver glitch with the touch pad. Uninstall the drivers for the touch pad from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers automatically. You might also look at Compaq's support site for any updated drivers or patches for the touch pad. 2- You may have a loose connection. Remove the keyboard, check and clean the touch pad connection/connector. 3- A faulty touch pad. If the other two don't work, then disconnect the touch pad and try using the machine with an external mouse. If this works, then the touch pad has malfunctioned and needs replacing. Ty these and let me know.
Aug 01, 2008 | Compaq Presario V4000 Notebook
Touch pad driver.
Jul 20, 2008 | HP Compaq nc6220 Notebook
Compaq armada 500 (touch pad not working)
look at the ribbon/connector again, make sure it's not broken.
Sounds like a broken ribbon or bad connector.
May 23, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
163 people viewed this question
David Payne
David Payne
