Question about Keurig B60 Coffee Maker
When trying to make coffee, very little water passes through the kcup, most of the water "recycles back into the tank
Posted on Jan 02, 2011
Suddenly the water wont come thru when theres a kcup in it
Check the needles have not been damaged (top and bottom) if they are jot properly puncturing the kcup the water may be being blocked
Mar 31, 2014 | Keurig B60 Coffee Maker
I have a one cup at a time Keurig. I measure the water and pour in then Kcup coffee. I shut the covers and press brew. The coffee maker starts to heat the water but then will not pump the water through...
I have one too. Had the same problem and needed a new clean Kcup. The oil residue build up wasn't allowing the coffee to pass through. Some models also have internal filters. Bed Bath Beyond has all the replacement parts and lists the units by Model on the part. Hope this helps.
Sep 05, 2011 | Vacuums
Drips only a little bit of water tried viniger thru did not help.. 2 bottles
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Mar 28, 2011 | Keurig B70 Coffee Maker
Keurig B60. Brand New used maybe 4 Kcups. Now it won't fill a full cup setting. Maybe 1/4 cup. You reset, get a little more to run through. At this rate going to be a long time for a full cup. took...
if water does go thru it...try white vinagar/water mixture about 1/2 cup vinagar to full tank water..
run cycles until empty...NO Kcups..then run full tank of clean water.....
Dec 18, 2010 | Keurig B60 Coffee Maker
My kcup brewer leaks water around kcup area no matter how little or full I fill withy coffee how do I stop this Also tried different grinds still spittting water all over !!
I had the same problem I bought a 1/2" rubber washer and duct taped it to the top of the reusable unit and it has been working great for about a month, the indent in the reusable filter is too far away from the brew section of the machine
Dec 10, 2010 | Keurig 5048 My K-Cup Reuseable Coffee...
My Keurig B70 will not dispense the coffee. I have cleaned it, cleaned the needle, etc. but it still won't work. If I turn it off and on two or three times it finally will pump...taking longer and...
did you clean both top and bottom needles? Did the paperclip insert at least 1".
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
Sep 26, 2010 | Keurig Platinum B70 Coffee Maker
My keurig coffee maker will not draw water into the tank and shuts off after a minute.i hear the pump but it wont draw water
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Sep 15, 2010 | Keurig B50 Coffee Maker
I have the Platinum Keurig, but it will not take in any water from the tank. I've tried to descale, but if it won't take the vinegar solution, what else can I do?
Sep 12, 2010 | Keurig Platinum B70 Coffee Maker
Keurig B60 Coffee Maker Logo
110 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
