Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Hi, I have the KM250BAF. There are seems running cycles from the board but no water going to the plate. And I see there is water pump which too hot to touch. Is this causing the problem? Thanks, Chong
  • Hoshizaki Master
  • 1,043 Answers
Most likely that's your problem. New pumps very expensive.
Posted on Jan 15, 2011
Does not cycle properly
if water valve still allows water even after unplugged electric wires to it then water cylinoid valve is bad.. if water stopes when unplugged then relay in circuit board is sticking or board defective..
Mar 26, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki water dont stop runing
float switch is stuck in the "down" position. The unit goes thru a fill cycle and after 1 minute, the board "Looks" at the float swith to "see" if the sump is full. If float is stuck down, it tells the board that the unit does not have enough water and stays in the fill cycle. The compressor will not come on as long as the machine "thinks" there is not enough water. let me know if I can help further
Aug 02, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki km-900mah ice maker won't start the freeze process
cycle is, fill cycle for 1 minute first. If there is not water entering the unit when first turned on, look for that issue. Water turned off, water valve not working or some restriction, clogged water filters, etc. That is got to happen first. Don't over look the bin stat being bad. Nothing happens if teh bin stat is bad. It sends voltage to the control board that runs the unit.
Jul 28, 2012 | Hoshizaki Freezer Commercial Ice Machines...
I have a manitowoc commercial ice machine.It has stoped making Ice and just seems to keep running water and not freezing
Check to see if the compressor is running... if it is running and not cooling then it may have a refrigerant leak...
If the plate is getting cold but the water is not freezing then check to make sure that the float is not stuck on and the the water just keeps running in... that will keep the water warm enough so that it does not freeze...
heatman101
Mar 10, 2011 | Freezers
Do you have to reset ice machine after running wash cycle? Mine is not making ice now?
If you did the wash cycle per the manufacturer instructions, you may have forgotten to turn the directional water valve back. It directs the water/cleaning solution to go inbetween the plates. It has a micro switch that will not let the compressor come on. If you did turn it back, the switch may be bad.
Check it out.
Mar 03, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Beeping 3 times every 3 seconds
The 3 beeps indicates that the unit was in the freeze cycle for 60 minutes. Causes: 1.) Water valve leaking, allowing water to continually enter the system. 2.) Float switch stuck, sending false signal to board. This indicates ice not being produced. 3,.) Low freon level causing long freeze cycle. 4.) Hot gas valve leaking thru causing warmer than normal evap plates=low production. 5.) Expansion Valve not feeding freon properly to evap plates.
Items 1 and 2 are the most common. Number 3 possible due to freon leak in the system. Number 4 and 5 are usually a very rare occurance.
Hope this helps ya.
Sep 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Manitowoc SD 0852A ice maker compressor will not kick-in
Here's my thoughts, I hope it helps. I'm going on foggy memory here, so I may not be entirely correct.
I worked on something like this a few years ago. The icemold (plate) is vertical, there is a circulating pump that runs water over the mold, with the water freezing as it passes. The sealed system is a heat-pump scheme, it freezes the mold to form the cubes, and reverses to heat for release. And when it works, it makes ice fast. It runs constantly until the ice hopper is detected to be full. (there should be a bail to detect the ice level) The system will not run in the event that it thinks the hopper is full (bail up) but the pump motor runs continuous to avoid it freezing. There is probably either a false detection of "full" or there may be a leak in the sealed system and the system will therefore not run.
Jun 28, 2009 | Freezers
Hoshizaki ice machine KM500-MAE not sending water to harvest
I would not change the pump. If it runs for 3-5 minutes and stops, it has to be a control. The control board runs the freeze cycle for the first 5 minutes. This prevent "Short Cycling" of the freeze cycle. The board looks at the float after the first 5 minutes for the proper water level but should not effect the pump. If the pump does not run in the wash mode, check out the "Power/ Wash" switch. I would start there before I go spending hundreds on pump motor or control board. You may be able to get by on a $20 fix! Do this and get back to me. We will get it going.
Good Luck
May 06, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Ice Cubes won't drop out
The thickness probe should be approximatly 1/4 inch off of the evaporator.Sounds like you might have loose grids on the evaporator.turn the unit off and remove the curtain.use a flash light and inspect the grids.There should not be space in between the joints,if there is the ice will freeze behind the grids and not properly release when in harvest. Also gently pull at the grids,if they pull towards you or wiggle then they are separating. I have removed one of the grids and had the unit continue to run for sometime until the evaporator could be replaced.The plating being spotty causes release issues as well.Finally check the level of the machine,front to back and side to side.Not being level will also cause release problems
Feb 18, 2009 | Freezers
Hoshizaki ice machine repair?
seems that its low on water or float switch is bad. try to clean float
Sep 02, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
101 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
