Question about Dell Latitude D510 Notebook
My Latitude D510 has started running very slowly. Every time I switch on, the machine loads a programme called 924PLC32, which is taking up around 4gb of memory. I suspect it is slowing the machine down. Add/Remove Programmes gives me a message saying I cannot remove this programme, but when I cancel that message, rather strangely the programme is apparently removed - only to reappear next time I switch on. Any ideas?
  • 583 Answers
Go to this link on Fixya where I outline how to correct this problem. You have been hijacked by some malicious software. This link should help you get your computer back to normal..
http://www.fixya.com/support/r4282570-laptop_running_slow_or_unable_download
Posted on Jan 02, 2011
    President:
  • 662 Answers
The 924PLC32 file/program may be a Symantec/Norton system restore in progress.
During a system restore, system performance would be enormously degraded due to the
consumption of large amounts of CPU time, and disk I/O needed during the restore.
Why Norton would decide to restore your system at every boot - check with Symantec support.
Or check your Symantec documentation (if you have any - Comcast customers just get software).
(WinXP) To access normal Windows restore:
START > control panel > system > system restore
(WinXP) Full Windows System restore features at:
START > All Programs > Accessories > System Tools > System Restore
These Windows restore software access points are worth checking, but Norton may have
(probably does have) its own system restore functionality independent of MSWindows.
A system caught in a restore loop like this will be unable to be upgraded (service packs or otherwise) since the next restore will wipe out any changes made before the restore.
To exit a restore loop like this, run msconfig & remove the offending restore.
HOW (WinXP): START > RUN > msconfig > Startup
More importantly, find out if Norton is trying to protect your system against something that it's finding every time your PC boots. Do this by (possibly repeatedly) deep scanning for viruses & malware. On badly infected systems, I've had to do this over half a dozen times, just to remove enough of the viral load so that I could access a Symantec web site, or upgrade the anti-virus database.
W3400 runs very slow, 64 bit, 2gig ram xp-pro
Your hard drive has the defective, there are bad sectors already in you drive, that's why it run slowly even though you formatted it.
Mar 27, 2012 | E-Machines W3400 PC Desktop
How to turn on the wifi in lattitude d510
Hi Friend, In order to turn on the wireless switch on Dell Latitude D510 laptop you have to press and hold the "Fn" key in blue color and then press the key "F2" for once and then release both of them. It will turn on the wireless switch of the system
Dec 11, 2010 | Dell Latitude D510 Notebook
My indesit WI153uk wont stop when I set it to any of the programmes, I have to switch the machine to release the door. Also when I put it on spin, it spins but slowly and does not seem able to pick up...
When the machine starts to act erratically like that, i certainly would suspect the board. The operation of all the components are given instruction directly from the micro processor. If the motor continues to run, the instruction is at fault. Very possibly the Thyristor that controlls the speed of the motor could be defective. If you are fortunate to have some electronic expert repair it, you certainly will be in the same ball park as buying a new board with much less running around.
Aug 19, 2010 | Indesit W 123 Front Load Washer
Dell latitude d510 want power on
Why can't you dell latitude d510 power on?You didn't descript your dell latitude d510 problem clear even.It may be the problem of ram,graphics card ,mainboard,or dell latitude d510 battery.
May 31, 2010 | Dell Latitude D510 Notebook
My problem, start the laptop dell latitude D510 after that trunoff ?
There are maybe virus harm your computer OS of dell latitude D510 ,reinstall your windows!
Apr 01, 2010 | Dell Latitude D510 Notebook
MY DELL LATITUDE D510 LAPTOP CANNOT BE SWITCHED ON...WHEN I PRESS THE ON BUTTON, THE GREEN LED JUST STAYED ON FOR ABOUT 4 SECONDS THEN WENT DEAD.
that sounds like a hardware fault. pull out the ram, hdd and dvd drive. Then clean the connetions and plug them back in one at a time, starting with the ram.
The computer will not load with the ram uninstalled, but when you reconnect it, it will make sure that it is plugged in correctly.
Feb 24, 2010 | Dell Latitude D510 Notebook
I have a dell D510 latitude. AC power OK - doesn't charge battery
The battery of the dell D510 latitude is completely bad and need to be replaced. i suggest you get another one and avoid the battery running completely down before charging it.
Compliments and I wish you best of luck
Dec 24, 2009 | Dell Latitude D510 Notebook
Washing machine keeps taking water in even after programme has stopped
poss moisture on your control module causing tracking . unplug your machine from the mains and take the back panel off, you can try blowdrying the module down in the bottom left hand corner or you can take it off (noting where all the leads go to),get an old toothbrush and clean the solered side around the bottom of the board failing that you will most probably have to change it
Jul 07, 2007 | Indesit WA 115 Front Load Washer
Dell Latitude D510 Notebook Logo
265 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
