Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
White vert lines 1 inch apart, toshiba rear projection
I am getting white vertical lines on my toshiba rear projection tv. They are pretty consistent but will flash out now and again for a few moments at a time unless i leave it on for a few hours with a black screen but as soon as it need to produce an image or movement they come right back. I have replaced the lamp, and removed all other devices for days at a time. I moved it once and ran it with a tivo and no hd signal and after a couple of days it went away for a month. I started adding devices and it was fine. I added an hd box from my cable company, fine. I switched to a hd dvr and the lines came back. the lines are there regardless of imput being used, xbox, dvd player, tivo or hd dvr.
  • 4 more comments
  • jholm7 Jul 08, 2008
    Here is a pic of the TV in all its glory.
    No. Could DLPs need recalibration during their life times? Do I need a repair guy to do this?
  • jholm7 Jul 10, 2008
    I have searched for DMD Boards and I have all the Toshiba schematic diagrams but I do not see it. Is it a set of components? I also have the service manual, is there something there worth trying?
  • Anonymous Sep 11, 2008
    I have the similar problem. I can see white thin vertical lines spaced ~1 inch apart. On top of that, when I turn on the TV, it will give buzzing sound and sometimes the LED indicates a solid red with green blinking.
    Is it the problem with ballast board?
  • s4gal Sep 11, 2008
    I have similar problem with white thin vertical lines spaced ~1in apart. Also, when I turn on the TV, there is a buzzing sound coming from the rear left of the TV. The LED indicator will have solid red with blinking green. After a few seconds, the picture will come up but the white vertical lines will remain on the screen.
    Any ideas what is wrong?
  • mavtek May 11, 2010
    Have you calibrated the convergence?
  • 33 Answers
From further research it sounds like you experiencing a failure of your DMD board. Here's a forum dedicated to the topic of your television.
http://www.avsforum.com/avs-vb/archive/index.php/t-438276-p-7.html
Posted on Jul 08, 2008
Vertical ghost lines about a 1/2'' apart. Our cable provider changed out the DVR box and rebooted the system and the problem still exist. What is the fix??
The tuner of the TV may be at fault.To bypass/test if the fault is with the TV try hooking up the DVR using audio video cables through video 1 or 2 of TV rather than standard cable through channel 3or(4).
Dec 07, 2009 | Toshiba 50H82 50" Rear Projection...
Can't get manual conf. to hold in white
Ur convergence it dead.need it to be replaced,know how to solders?Tries these Websites for convergence kit.Tv repair World.com or Tv repair Kits.
Nov 18, 2009 | Hitachi Director's Series 65XWX20B 65"...
The picture is only about three inches high in the middle part of screen and has a slight curve
vertical circuts or vert drive circut shady easy fix need more info on tv dlp proj plasma usually bad ic 1 or 2 18.00$apiec ver def ic look up ur part #go 2 nte electrnics.com buy part tip replace surrounding capacitors and output resistors good luck
Aug 07, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Convergence problem with old rca 46 in rear projection TV
you will need to have a shop re converge it or order a new convergence board.
Nov 17, 2008 | RCA P46924 46" Rear Projection Television
White vertical lines in Zenith lcd projection tv
Get price of a LCD drive board first, then call a shop to see how much they would charge to replace it. If you have already researched the price you can get a better deal. But I really wouldn't try to replace this yourself. It takes major disassembly and alot of training just to get this model taken apart and put back together. Good luck, Russmann.
Jun 13, 2008 | Zenith E44W46LCD 44" Rear Projection...
Red Green Blue horizontal line at top of screen
Since both were replaced at one time, you now can't limit the problem properly. Should have been done one at a time.
Your vert height may be too short, causing you to be seeing things that should be off screen.
This can be remedied in the service mode.
Mr Bob
Feb 06, 2008 | Mitsubishi WS-65411 65" Rear Projection...
Toshiba 43 inch projection set
Possible bad solder connections in convergence circuit or vertical deflection circuit. This happens in alot of equipment. After warm up, expansion of joint pulls connections loose. Recommend not running like this, could cause component failure.
Dec 22, 2006 | Toshiba 57H83 57" Rear Projection HDTV
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
639 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
