Question about Samsung DVD-H1080R DVD Player
Do I need and Hdmi cable running from my DVD player to my tv to stop it from playing in black and white
  • 1,557 Answers
You dont need to you can hook it up via rca or composit but you will need to set the setting in menu to the correct output on the dvd player
Posted on Jan 02, 2011
    Sergeant:
    Champion:
  • 342 Answers
It may be playing in black and whit cause of a cable problem try a HDMI cable and see if that helps
3 Suggested Answers
weaponx69
  • 58 Answers
SOURCE: DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Posted on Jan 12, 2009
  • 133 Answers
SOURCE: new lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Posted on Jun 04, 2010
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
#dhb300b DVD player plays only black and white my TV is a JVC HD TV with HDMI cable from driver TV box hook up DVD to TV audivo to audivo video to video set TV to component program DVD to TV but plats
The yellow/red/white cables are COMPOSITE cables. COMPONENT cables are RED/BLUE/GREEN. You can buy those at any electronics store. Your best bet, though, is to stick with HDMI if you can.
Jan 21, 2015 | JVC Televison & Video
How to hook up DVD player to 19' led HDTV
The modern way is to buy a HDMI Cable
Plug it in to the HDMI Port on back of DVD Player
Plug the other end into spare HDMI Port on LED TV.
Put in a DVD & hit Play
Use remote control to select HDMI port on LED TV
If it does not have a HDMI port then you need a converter box which picks up the Red & White (sound) & Yellow (viideo) and converts to HDMI standard.
Aug 13, 2014 | Televison & Video
Sanyo tv and Sony DVD player sound issue
If you post this query in a forum dealing with tv related issues, someone may be able to help you.
Apr 28, 2017 | Sanyo 50" Plasma Hdtv Dp50740a W/ Free...
I'm trying to hook up my dvd player to tv and don't know where the cables on the back of the dvd player should be????
RCA cables:
connect yellow on DVD to yellow on TV. Connect white (next to yellow) on DVD to white on TV.
OR if you have HDMI cable, connect HDMI on DVD to HDMI on TV.
Insert DVD, press PLAY.
Select proper TV input using TV remote. Cycle thru (Select input or Video etc.)
Mar 04, 2011 | Televison & Video
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
When i hook up a dvd player the screen is in black and white what is wrong i followed the manual?
U used the RCA component AV cable Y,R,W?Yes,the Yellow cable must have been damage,that the video out put cable.Ur DVD player have a HDMI port?Used the HDMI cable hook up for DVD player to ur tv HDMI port.HDMI cable better cable design.
Jan 15, 2011 | Sansui 19 in. LCD TV
We have a black and white picture on the TV, no colour
check for DVD/TV cable. Use a SCART 21 conductor cable (if possible with gold contacts), or HDMI Cable if Tv has HDMI Input
Nov 29, 2009 | Panasonic DVD-S35 DVD Player
Sony rdr vx410 dvd player playing some dvds in black and white
  • DVD's are standard definition video sources. Number of lines output is 576 lines, whereas your HD TV set has 720 or 1080 lines. This difference may result in a poorer image. However some DVD players are able to “upscale” picture to obtain a very good picture. Check if your DVD player has the following connectors: YUV, DVI or HDMI. For more information, refer to the instruction manual of your DVD player.
  • Some HDMI or DVI featured DVD players also have an internal processor that can upscale pictures from a DVD to 720 or 1080 lines to provide an excellent picture from a standard definition disc to your HD TV set. Those settings are available from the setup menu of your DVD player. Please refer to the instruction manual of your DVD player.
  • If your DVD player does not have those connectors and only has a SCART connector, or S-VIDEO, or composite, there is not much to do to improve the picture quality. Just make sure that you are not using the cheapest cables and that the picture settings of your TV set are correctly adjusted.
  • Some high end TV sets have a picture improvement engine that can soften a noisy image. Make sure that it is activated from the setup menu of your TV set. Please refer to the instruction manual of your TV set.
  • If people and objects have weird white outlines around them. This may suggest that your TV sharpness is set too high. Make the correct sharpness adjustments from the setup menu of your TV set.
  • Make sure you use good quality cables and that your cables are not too long (less than 5 meters long).
Jun 15, 2009 | Sony RDR-VX420 DVD Recorder/VCR
I just purchased a Sony DVD player...DVP-SR200P. Plugged it in and have no color...movies play in black and white only.
Hello cherylsacket,
Check your cables to your TV. If possible check the various cables to your set. I would suggest using the HDMI cable if your TV has an HDMI input. Remember to power off all devices before connecting your cables. If I may ask which cable are you using to connect between your Tv and the DVD player?
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 10, 2009 | Sony DVP-NS700P DVD Player
Samsung DVD-H1080R DVD Player Logo
124 people viewed this question
Jerry Greenberg
Jerry Greenberg
