Question about Whirlpool Calypso GVW9959K Top Load Washer
My washer comes on and fills with water and i can pump out water but its not spinning or doing any tub movement at all, i have the whrilpool calyspo top load
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Replace the lid switch with this part.
Posted on Jan 02, 2011
How do I check the belts or springs holding the washer tub
to check the belt or Air shock , its easy to remove the rear access panel , you can have a look for shock and motor & belt but there are a lot of reason for your complaint for doesn't spin out water and noisy when spinning it may be have kinked in the drain hose or the spin start before pumping water out properly leads to load unevenly distributed in the movement of the drum, so i believe that your problem in pumping the water out. Alaa Refaei
Mar 04, 2014 | Frigidaire ATF6000ES Front Load Washer
Water will not drain. sewer line is not pluged. Customer service says I could have a plugged filter at the pump ( we have dogs). How do I get to the pump to unclog it. Model EIFLS55IIW woody
Hi agnes! Washing machines, including those built by Frigidaire, have internal pumps. These pumps help drain out the water from the washer tub between the wash, rinse, and spin cycles. If the pump is damaged or the pump pulley system is frozen/stiff, the water can become trapped in the washer tub. In both cases, the pump assembly needs to be replaced. You can check by looking for a few signs that a pump is dying or already dead.
1 Start the washer and wait for the washer tub to fill with water. If you do not hear water or hear a motor whirring, the washer motor may be dead.
2 Open the washer lid in mid-cycle. Note whether or not the inner tub is still spinning around. The inner tub is the inside surface of the washing compartment with many holes for water draining. If the tub is not spinning but the motor is running, it is possible the pump is dead. Check the pump pulley by removing the pump from the washer and trying to rotate it by hand. If the pulley doesn't turn freely and is frozen or stiff, replace it. Also, if the agitator is moving but the tub isn't, this is a sign the pump is dying. For front-loading washers, do not attempt to open the door mid-cycle. Look through the glass door. If there is enough water to come up against the door, the pump is malfunctioning.
3 Wait for the washer to finish its cycle. Open the unit. If water is still in the tub, the pump is likely dying or dead.
Sep 04, 2013 | Electrolux EIFLW55I Washer
Leaks from underneath
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Kenmore Elite Washing Machines
Washer filled and will not drain if I reset the fill capacity knob it will fill but not drain.
This washer has a belt. The belt drives the pump on this washer. The motor turns in both directions. iIn one direction the washer tub is locked and the tranny agitates. The water pumps out and the tub spins in the other direction. If that pump is locked up or the hose from tub to pump is blocked then it wont pump the water out. Lay the drain hose down towards a bucket and see if any water comes out. If not you got blockage. Once you drain it out tip is back and remove the belt (no tools needed) turn the pump both directions and look for signs of a failed pump. Manual and more
Jun 30, 2011 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Water leaking from washer
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs: During fill only During drain and spin only All the time During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make
Jan 01, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Will agitate but won't spin leaving the water in the tub.
the transmission may have been damaged during the runaway.to much movement can cause it harm that is why they come with a shipping rod in them.
Aug 08, 2009 | Kenmore 22422 Top Load Washer
Washer won't spin makes banging sound
remove the agitator. there is a cone shaped block on the agitator shaft and locked to the tub via a large lock nut. spin tube has 2 tabs that lock into slots on top of block. these can strip out and cause the spin tube to spin inside block. watch it and turn machine on spin. tub can also drop and drag on bottom of outer tub. if this is it replace block and gently straighten tabs on spin tube.
Jun 11, 2009 | Whirlpool Washing Machines
Excessive vibration and movement during spin cycle
mostly its faulty motor problem or drain problem. It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
May 07, 2009 | Frigidaire FEX831CS Top Load Stacked...
Neptune washer front load may4000awq
Check your washer belt has not slipped off.
Just so you know thats not the problem.. Ours went ga ga and it was only the belt!
:o)
Aug 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
