Question about Whirlpool Dryers
Power is on. Can select cycle and time dryer will not start when I push start
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Posted on Jan 02, 2011
Lg wle1501w dryer no power
Since its brand new it should have a warranty I would use that since you trying to could void that.
Jul 05, 2017 | LG Dryers
Won't start
Is door securely shut? Safety switch could be preventing start. Might try unplugging for about 1 min, then plug back in and try. On some models, this will allow circuit to reset. Good luck!
Apr 08, 2014 | GE GFDR485EFMC GFDR485EFMC 8.3 Cu. Ft....
105I have a samsung dryer dv409AER/XAA. Currently, I turn the power on and select a cycle and push the start button. When I push the start button - nothing happens. This occurs for any cycle. There is...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Dryers
Dryer will not do anything at all. when start button is pushed. does the thermal switch stop power to the dryer if it is bad.
Ok
Thermal and high limit thermostats control heaters in dryers . The motor should still start.So you have something else wrong.Check door switch first. House Circuit breakers of course .Remember ,there are two.Try selecting different cycles like timed drying . If it works in timed but not auto you may have an issue with moisture sensor . If there is no voltage at all getting to start switch and door switch is ok ,then suspect timer (or controller)
Hope this helps a little
Aug 18, 2011 | Magic Chef Dryers
Dryer won't start after I push the Start button
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 26, 2009 | Whirlpool Dryers
Need to initiate cleaning cycle
to enter the cleaning cycle:
Select the RINSE & SPIN button.
Select Low SPIN SPEED'
Select Warm/Cold WATER TEMPERATURE.
Select the 2ND RINSE Option.
Push the END of CYCLE SIGNAL button 4 times within 5 seconds to start cycle
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer will not start
If if "hums" like the motors is working you drive belt may have broken. If it makes no noise other than the click it could be a blown thermal fuse (there can be several) or a seized motor.
Jun 15, 2007 | Kenmore 64722 Electric Dryer
Open Questions:
Dryers Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
