Question about Dell Inspiron 1000 Notebook
My Dell Inspiron 1000 laptop just randomly turns off while i'm using it. How do I fix this?
  • 95 Answers
My guess is overheating- does the machine feel excessively warm during use? Try blowing into the exhaust vents with compressed air or an office duster can. If that doesn't help the service manual can assist you on disassembling the machine to clean out the heatsink and fan assembly. http://downloads.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1000_Service%20Manual_en-us.pdf
Posted on Feb 18, 2015
  • danoyachtcap
    danoyachtcap Feb 18, 2015
    Make sure your laptop is setting on a flat hard surface. Not on a pillow or soft material. The laptop need to breathe under it.
mewms_14904
  • 1027 Answers
SOURCE: get a laptop to talk to projector
  1. Are you using the SVGA connector on the laptop or the S-Video?
  2. If using the SVGA (normal computer monitor connector) then you have to "toggle" the proper Function Key. e.g FN+F5 on my laptop to change from internal LCD to external or both.
Posted on Mar 26, 2008
  • 998 Answers
SOURCE: Dell Inspiron 1000 notebook won't turn on
If you tried another AC adaptor and the green light still blinks, then most likely your motherboard has a problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 11, 2008
  • 37 Answers
SOURCE: dell laptop inspiron 1000
Put recovery disk in the CD drive. On reboot, hold down F12 key. You should get a choice of drives to boot from. Make sure the first two are in the correct order:
1. CD-ROM (optical drive)
2. HDD (hard drive)
then press F10 to save and exit.
Now the laptop should boot correctly from the recovery disk.
Posted on Jan 06, 2009
kamal1984
  • 1383 Answers
SOURCE: Getting wireless to work on my Dell Inspiron 1000
find switch on laptop it is wi fi network adapter switch on laptop turn on it.
Then also check your wi fi drivers are installed.
if driver are not install for wi fi downlaod from here in netwrok
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_CEL_1000&os=WW1&osl=en&catid=&impid=
then install wi fi then check.
Posted on Jul 14, 2009
  • 89 Answers
SOURCE: Dell Inspiron 6000 screen goes black / hibernates / turns off
well go to your power setting by clicking on the battery by the clock and then say power options to change those setting such as Hibernating sleep ect... you can also get to this by going to you control panel then power options hope this helps
Posted on Jul 28, 2009
My dell inspiron 1000 Model pp08s wont turn on
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad
5. The motherboard could be defective & needs to be replaced.
Sep 17, 2010 | Dell Inspiron 1000 Notebook
Randomly shuts down. Dell Inspiron 1000 with battery removed it will usually get past login and stay up for a while all hibernation options have been turned off.
check that it is not heated up Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Aug 31, 2010 | Dell Inspiron 1000 Notebook
My dell inspiron 1000 will not boot without a password and i have no clue what it is and the backdoor passwords didn't work
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-1000-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Nov 29, 2009 | Dell Inspiron 1000 Notebook
Screen goes blank during use
Go to your settings menu and adjust the bar that says to turn your screen off after a minute.  If that don't work then have IT open this puppy up and replace the bulbs or inverter.
Oct 31, 2009 | Dell Inspiron 1000 Notebook
Jul 14, 2009 | Dell Inspiron 1000 Notebook
Cannot connect a hp psc 2410 printer to dell inspiron 1000 laptop
Try a powered USB hub, this will boost the power in the USB curcuit.
Also ensure that in Device Manager, USB Root HUB, Power Management tab, that the option to let windows turn off the device is unchecked.
May 27, 2009 | Dell Inspiron 1000 Notebook
Computer ask for password to get started
it cannot be yours then, otherwise you would know the password, pc's don't randomly throw in a password.
As you can appreciate we cannot give instructions on how to get around passworded pc's.
Sep 01, 2008 | Dell Inspiron 1000 Notebook
Replacing a motherboard in a dell Inspiron 1000 laptop, and the screen not working
u need to reset the bios to factory defaults..this would fix your problem
Feb 06, 2008 | Dell Inspiron 1000 Notebook
Dell Inspiron 1000 Notebook Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
