Question about Jandy Aqualink Pda Ps4 Wireless Handheld Remote Control System Pool and Spa Combo
My Jandy PDA-PS4 Combo is two years old. Recently it fails to connect, it tries repeatedly. Sometimes it gets as far as the full menu, however it won't schroll up or down let alone respond to a command. I have changed both batteries, no help. I have tripped the breakers no help. When it does connect and gets as far as the menu, everything looks normal, backlit looks fine, menu looks fine, just none responsive. ??? Maybe RF interference??
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Make sure 4 pin red connector is box is connected and not loose make sure wires arenot cut
Posted on Sep 25, 2014
4 Suggested Answers
  • 8404 Answers
SOURCE: breaker for my Jandy stealth tripped and wont stay
Start/run capacitor may be faulty ...
Posted on Aug 04, 2010
adamh294
  • 310 Answers
SOURCE: Have a 3.5 year old Jandy Aqualink RS 4 --- the
It is most likely not a bad reading on the on the display.
One culprit of a false temp reading could be:
If the temperature sensor is installed after the heater and the circulation pump is clogged or failing, this would allow super heated water to reach the temperature sensor and give you that reading. However, most pool/spa heaters have a high limit switch that would shut down the heater @ 150 degrees F. So this is also unlikely.
The most reasonable answer is to replace the temperature sensor.
If you refer to page 22 in this manual http://www.jandy-downloads.com/pdfs/Allbutton_manual.pdf
you will see that the temperature sensor is installed on terminals 5 and 6.
Trace these wires. They will goto a thermowell (which holds the temperature sensor) either in the pool plumbing, or to a temperature sensor in the heater itself. Temperature sensors when in the heater are located typically above the inlet/outlet header. There will be some disassembling required to access it in this case.
If it is in the heater and you need more help, e-mail me @ adamh@newconceptchem.com
Please take the time to give me a positive rating on this post if I have helped.
Thanks
adam
Posted on Nov 02, 2010
Testimonial: "Thanks for the prompt response. I'm at work now but I will follow your instructions when I get home. I had a feeling that it is a 'bad' sensor. "
uspartscente
  • 717 Answers
SOURCE: I have a Jandy stealth
This sounds like the motor has seized up. You will most likely need to replace at least the motor and maybe the complete pump assembly.
You can take the pump into a local motor shop and see if they can rebuild the motor for you.
US Parts Center
Posted on Aug 22, 2011
Jandy pda stuck on waiting mode
try changing batteries then shut system off turn back on then turn on PDA if still the same take off front top cover of aqualink make sure 4 pin red plug is connected and tight
Aug 19, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Indicates "waiting" and will not show menu
try turning off rs system turn off pda turn rs system back on then turn on pda reboot
Oct 03, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
HELP!! My Jandy PDA lost menu items, and I can't get them back!!
increase the aquapure output to5% or more it will show back up on PDA
May 28, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Jandy PDA-PS4 lost link to salt system?? There is no more
go to system setup find aqua pure up setting from 0 to something and it will apear
May 27, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Button on jandy pda 8265 broken
See this thread:
http://www.troublefreepool.com/how-to-fix-your-jandy-pda-for-15-t52166.html
May 13, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Jandy Aqualink Pda Ps4 Wireless Handheld Remote Control System Pool and Spa Combo Logo
116 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
