Question about Haier hwr10xc6 Air Conditioner
Water spitting into room
Where is the drain?
  • 1 more comment
  • Anonymous Jul 09, 2008
    Water spitting into room. Just turned it off. Did not know what else to do.
  • stratosurfer Jul 19, 2008
    I have the same problem, the unit is 'gurgling' water and spitting water. The evaporator pan is full as view from the outside of the unit.
    The installation is good, it leans toward the rear.
    Help.
  • Anonymous Jul 20, 2008
    where exacly is the drain pipe?
    Sergeant:
    Champion:
  • 330 Answers
If your AC is window unit, check the dirt underneath the unit and also check the level of your unit.
If your AC is a central unit, be sure check the drain pipe, should be toward to the outside.
Posted on Jul 12, 2008
Why is my air conditioner spitting water back in the house. These do not have ourside drains on them?
Take the front cover off and use a shop vac to suck the water out, check filter while you do this see if the evap coil is dirty the one on the inside. sounds like it maybe freezing up. check for air flow.
Sep 06, 2014 | Haier Heating & Cooling
I HAVE A KENMORE A/C THAT SPITS WATER INTO THE ROOM AFTER RUNNING ABOUT 15 MIN AT A TIME. THE COMPANY I BOUGHT IT FROM WILL NOT DO ANYTHING ABOUT THIS. IWISH YOU COULD GIVE ME A SOLUTION TO THIS PROBLEM.
While you didnt say i suppose its window a/c and not a certral unit
the drain for teh condensate water is clogged and the fan is picking up the water and "stipping it out" go outside and clean the drain in the corner of the cabinet
Aug 04, 2011 | Kenmore Kitchen Ranges
Window air unit is spitting condensation back into room.
Hello, most of the time this will happen when the AC is not tilted back in the window enough or if tne drain i s blocked. If the unit is level make sure it is tilted back in the window somewhat. If the window does have a drain make sure it is clean and the water is draining properly.
Jun 10, 2011 | Daewoo Heating & Cooling
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
Spitting water out of vent. dehumidifier is has drain hose set up.
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 31, 2009 | Dehumidifiers
(Tilted) Plasmaire spits water into room....
What your problem is is that water coming back into your face is condesation. Appearently there is a clog preventing your condensation water from draining out the back side of the a/c You can remove the a/c from it's sleeve, take it outside and with a pump sprayer (Type used for spraying insecticide) filled with water spray around the base of the a/c where the condensor coil sits (you should see a small drain channel in this area) If this drain channel is clogged water will back up and the squirrel cage will pick it up throwing it out into the house.. Good Luck on your repairs
Dave
Sep 03, 2009 | Kenmore 76100 Wall/Window Air Conditioner
Sears Plasmaire spits water into room
It's probably just holding water somewhere and getting thrown out. I've seen people drill holes on the bottoms to drain water quicker.
Sep 03, 2009 | Kenmore 75085 Air Conditioner
Droplets of water are coming from the vents and it's making a noise like something is rattling around inside. What could this be?
The problem with this unit is that the evaporator, or the part of the air conditioner that 'creates' the colder air is not draining correctly. Pertaining to a window unit, it needs to be installed correctly with the correct amount of tilt toward outside, to allow the evaporator condensation water to drain. You may also want to check to make sure there aren't any plugged drain holes in the air conditioner housing.
The rattling you hear is most likely the blower fan spinning against the held water inside the unit.
I hope this helps! :)
Sep 01, 2009 | Heating & Cooling
Panasonic a/c 'spitting' water out the sides.
your water pan is not draining and fillin up with water causing the fan to spray it around
Jul 12, 2009 | Panasonic Room Air Conditioner CWXC104HU
Frigidaire window unit spits water into room
To be honest with you this is a good and a bad thing. The bad thing is that it is spitting water into the room. The good thing is that the unit is running Great. The amount of humidity it is removing. is greater and faster than it can run down and off the coil. See if there is any possible way to deflect the water. i would recommend trying to attach a piece of screen door material. It will likely keep the water from going through it.
Dec 17, 2008 | Maytag M7D24E7A Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
384 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
