Question about Sanyo PLV-Z5 LCD Projector
My Z-5 wont power up the new bulb, I tried 2 bulbs. then it shuts down in about 10 secs.
  • tmtyler Jan 02, 2011
    What is a heat Lamb, and where can I get one. If you meant "Lamp" it is the second one I have tried.
  • tmtyler Jan 04, 2011
    And what do I need to replace and where can I get it?
  • 944 Answers
The heat lamb is the problem.The heat lamb filament have been damaged.You have to replace a new one.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 02, 2011
  • Natarajan Ramasamy
    Natarajan Ramasamy Jan 02, 2011
    I meant heat filament.Not bulb.It is connector which heats up the bulb.
    Natarajan Ramasamy Jan 04, 2011
    you need a soldering tool to solder the heat filament to the board.If you buy it in the shop they give it has a full board part only.In Sanyo service centre they will replace the defective filament removing it from the board.Which will be much cheaper for you to save money.
My samsung dlp turns on, then after 10-15 sec turns back off
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Mar 04, 2011 | Samsung HL-S5087W DLP TV
Wont power on
Sounds like you need a new bulb, or possibly new lamp. The red/green flashing is the warm up to get the bulb ready. If it's shutting down after that, instead of turning on, it means the bulb isn't working - that's a common thing, for the bulb to burn out. Possibly the lamp's bad, but that's much less likely.
Sep 01, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Toshiba 42HM66 and it shuts off on its own. Im not sure if its getting hot or if the bulb needs to be replaced. It will just shut off at any moment without the 10 sec countdown that happens when I manually...
remove bulb and place in freezer for 5 minutes. the when unit comes on, go into menu and find lamp setting. select and it will ask you if you replaced bulb. select yes which resets the lamp time to zero hours
Nov 10, 2009 | Toshiba 42HM66 42" Projection HDTV
Works good for 2 minutes, Then shuts down & light goes red. Remote wont restart , so turn power off then on, Works again for 1 minute then shuts down. Panasonic PT-AE900U... projector
change the Bulb if that does not work it could be a power supply or power supply regulator this should be done by a professional except the Bulb
how many hours of operation does the unit have ??
Sep 21, 2009 | Office Equipment & Supplies
1994 JOHNSON 200 WONT RUN AT ALL WITHOUT CHOKE'ON CARBS CLEAN. WONT DRAW FUEL FROM CARBS COMP GOOD. EX CLEAR ,GOOD SPARK,?NEW TIMING BASE NO HELP. POWER PACK NO HELP. WONT IDLE AT ALL, RUNS FOR ABOUT 10...
If you have a primer bulb and the motor "recovers" after a near stall with a pump of the bulb, then you have to replace your fuel pump. Johnsons do have this problem often. Otherwise it could be the high speed jets although it sounds like you checked the carb good. Also if you have a primer bulb, Replace everything from the tank to the engine. Costs about $14 at Wal Mart, $55 at a boat place.
Jul 06, 2009 | Boating
I have an SVA LCD Model VR-17S Monitor that has a black screen
Sounds like the Backlight balance sensor circuit is shutting down the inverter supply. A weak bulb can cause this or a malfunctioning sensor circuit can cause it too. Best method to troubleshoot is to substitute good bulbs; if it still shuts down, look for a pair of small electrolytic caps on the inverter board near the bulb sockets. They may be weak.
Monitor Mike.
Jan 03, 2009 | Computers & Internet
Lamp won't turn on.
I have a sharp xr10x ..........the problem lies in the bulb it needs a warmer temprature for the gas to expand in the bulb to fire and light up... hold a hair dryer up to the side of it fo a while and then fire it up still holding the haidryer up to it till it starts it may take a couple tries... ( this is a fix if your having a no buld startup problem and you know your bulb is still good) THIS IS THE FIX IF**** the lights will blink green for a while then one red and one green then will (shut off at both red) and not restart***
i had the same problem and thought id have to get a new bulb but this is the fix....
Nov 23, 2008 | Sharp (AN-XR10LP) Projector Lamp for XR10X
HOW TO RESET LAMP HOURS AND THE PROJECTOR WONT FIRE UP,STAND BYE LIGHT IS ON.sHOULD i LEAVE THE UNIT OFF FOR A WHILE THEN TRY AGAIN.I HAVE JUST REPLACED THE BULB AND I THINK WHEN IT KNOWS THERE IS A NEW...
From the booklet that comes with the replacement lamp:
1 While holding down the "MENU" and "ON/STANDBY" buttons simultaneously.
2. Insert the power cord
Not great English, but I tried this yesterday and it works.
Jul 12, 2008 | Toshiba TDP-S8 Multimedia Projector
My computer shuts down after 3 secs
Try to separate the power cord of your monitor from your system or maybe if your using UPS(uninterrupted power supply) directly plug the UPS to the wall outlet. either you can use pretty voltage regulator to the regulate the AC power.
if not solve the problem try to examine the your system power supply.
Dec 11, 2007 | Computers & Internet
Sanyo PLV-Z5 LCD Projector Logo
126 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
