Question about DeLonghi Ovens
My Delonghi D906GWF dual fuel oven over heats and shuts down after about an hour of cooking. it appears the cooling fan is working but does not appear to be blowing any air through the venting system trough the inner part of the oven controls and throught the door, although air is comming up through the top vents at the back of the burners.
SOURCE: magic chef stove and oven installed 1978
Yes this is normal. you can use that burner to keep things warm without turning it on, saves energy.
Posted on Dec 14, 2007
  • 3 Answers
SOURCE: DeLonghi Debige 2440 Electric/Gas Double Oven Fan Failure Light
I had the very same problem. I slid the oven out of the wall about 6" or so, unplugged it, plugged it back in. It worked. I'm not sure if I jostled some connection, or if unplugging/repluging it in reset some sort of circuit fault.
Posted on May 30, 2008
  • 33 Answers
SOURCE: Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Posted on Dec 17, 2008
    abhishek33
    • 1239 Answers
    SOURCE: oven has stopped heating up;delonghi oven906gwf
    hi this is abhishek,,,,,,,,
    its actually a thermostat or its sensor problem check it,,,,,,,,if its not then its a timer problem.......better to fix it
    thank u...
    Posted on May 03, 2009
    MNTECH
    • 1543 Answers
    SOURCE: My GE profile electric range (model PS905SPSS) has
    Disconnect power to range. If you have an ohm meter, you can check the burner coils for continuity from the wires at the switch. If not, open oven door, remove screws holding top. Lift up top and remove screws holding the set of burners in question and visually inspect the inner coil for a break in the burner coil.
    Posted on Nov 28, 2010
    During cooking the oven goes off. There is often a lot of water/steam present. Sometimes after a while it comes back on?
    It could be that the overheat thermostat is kicking in, albeit earlier than it should do. Have you checked to see that the oven thermostat is working correctly and is not heating the oven up too much ( does the neon go off and on) and is the oven cooling fan running ok in the background. If these two appear to be ok, then you may need to replace the overheat thermostat.
    (The oven cooling fan should remain on for about 5 to 10 mins after either oven or grill has been used. If this isn't happening or it is not running correctly then that is why the overheat device is shutting the oven off). As a thought, are the top oven and grill working ok? if they are, then it narrows it down to either the oven thermostat or the overheat sensor.
    Nov 19, 2010 | Stoves 720EF Electric Double Oven
    Jenn Air SVD48600
    One of the relay boards is a downdraft relay board....I would be suspecting the main clock assembly as it is the one that shuts down and controls everything. This might also increase the fan speed randomly, turn it on at random temperatures etc., You have to get a new board. You can find it here
    http://www.affordableappliance.com
    Feb 27, 2008 | Ovens
    The oven is not work or better say works for little be and going off. could you please help or please let me know what telephone should I call?
    Hi,Everything operates normally, but the oven shuts off after varying amounts of time. This could be a faulty magnetron, bad cooling fan (or just built up dust and grime block ventilation grilles), bad thermal protector, faulty controller, some other intermittent component, or bad connections.
    • If resetting it allows cooking to resume immediately, if even for a few seconds, I would not suspect the magnetron or thermal problem as no cool down time is required. It could be bad connections in the controller or elsewhere, a marginal door interlock switch, or a controller problem. Jiggle the door to see if this will cause it to shut off.
    • If the magnetron was overheating, you would not be able to resume cooking until it cooled and the thermal protector reset. If it just stopped working (i.e., the filament opened), everything would appear normal but there would be no heating. If the magnetron were shorting, there would likely be a loud hum associated with the periods where there was no heat.
    • If it is not possible to resume cooking for a few minutes indicating that something needs time to cool off, then the magnetron could be faulty but check for the obvious cooling problems first: blocked or dirty ventilation grill. Determine if the magnetron cooling fan is operating by listening for its sound or looking through the ventilation opening in the back of the oven. If it is not, there could be a broken or weak belt, gummed up or lack of lubrication, other mechanical problems, a bad motor, or bad connections.
    • Extremely high power line voltage may also result in overheating on a poorly designed or oven where the components are marginal.
    • Make sure the stirrer fan is turning normally. Should it gets stuck, some models may sense this and shut down/restart.
    Hope it helped..
    Thanks for using fixya....
    Oct 20, 2010 | Ovens
    My Delonghi DE60PYROS needs a new thermostat, are
    Ok get a Service Manual, and the Sensor, and it is not too hard.
    Mar 29, 2010 | DeLonghi AS1070 Electric Single Oven
    I have a elecric delonghi oven with a gas hob with 6 burners. the oven does not work at all no heat. the light comes on but no heat. the turkey is stuffed an no hat to cook it HELP PLEASE
    if the temp indicator light comes on and/or oven fan circulates then its most likely the heating element. if neither then its thermostat or selector switch...
    Dec 22, 2009 | DeLonghi DEBIGE 2440 Electric Double Oven
    COOLING FAN DOES NOT STOP AFTER HOURS
    Hi I am Vortash the cooling fan must be controlled by a thermostat , it appears that it has a problem on it and is not shutting off .
    They are usually normally open contact switches that are on the top or the side of the oven ,they heat up close the connection and turn the fan on . yours sounds as if it is sticking . Other ovens are controlled by a rheostat a long tubed thermostat that goes to a main control consul on the oven , it controls the fan and responds to what the stat tells it .
    It may be this controller is not turning the fan off afterwards , my suggestion is that unless you are electrically trained you get the help of a service engineer to check your oven out .... regards Vortash
    Jun 15, 2009 | GE Profile JT912 Electric Single Oven
    Oven has stopped heating up;delonghi oven906gwf
    thank u...
    May 03, 2009 | Ovens
    DeLonghi ESS601 electric oven
    We just moved in to a place that has this oven, if you use the setting with the fan with a circle round it, seems to get hot! Don't know what the other is for though!
    Hope it helps!
    Pete
    Jun 20, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
    Jenn air single wall oven model jjw8530BAB - exhaust fan not working properly
    in not sure but i think that fan runs off a thrmistor that goes to the contol board.open the oven door and look on the right side of the oven see if theres a metal looking bulb.
    Aug 19, 2007 | Jenn-Air JJW8530C Expressions Collection...
    Oven not heating
    there is more to this than meets the eye if youre oven takes a long time on fan setting it may be thermostat but more likely to be fan not turning at all or quickly enough the stat capillary is above oven element and if fan not blowing air away from capillary oven stat will shut oven temp down too soon if using conventional heat eg no fan make sure there are no full size trays directly on bottom of oven this will block heat from bottom element effectively giving only half the heat output.
    hope this helps
    Jun 13, 2007 | Bosch HBN 430560B / 430520B Single Oven
    Ovens Logo
    171 people viewed this question
    Top DeLonghi Ovens Experts
    ashburton
    Brandon Berry
    Brandon Berry
    Jason Harris
    Jason Harris
    Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
