Question about Refrigerators
The refrigerator and freezer have both stopped cooling. Lights are on and i can hear the fan but there is no cooling
  • 29 Answers
You have lost freon
Posted on Jan 02, 2011
Compressor running continuously. Hearing surging sound. Both fridge & freezer not cooling.
there may be a blockage in the evaporator tube in the fridge sections and the only way to establish what the fault is will be to have fridge technician run test on it
Jul 25, 2015 | Fisher and Paykel Active Smart E522B...
My frige & freezer do not cool at all,lights & freezer fan work,compressor & coil fan do not
Hello Friend, this is Z. Thank you for allowing me to assist you!
Based on the symptoms you are describing, it sounds like your refrigerator could have floating restriction in the line or something more complicated like an issue with the sealed system that only a professional can repair. This can include the compressor not working, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. It is typically normal to hear the compressor running, humming, or even to be a little warm. However, if you do not hear the compressor at all, I suggest cleaning your refrigerator out including the coils you can reach (typically located in the bottom behind the toe grille) and make sure no food items are blocking any vents in your appliance. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues. Best! - Chris
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
2005 Maytag Refrigerator Fan Stopped WOrking
What is the model number and is the compressor kicking on?
Oct 28, 2012 | Maytag Refrigerators
GE Profile Refrigerator PSS26SGPSS stopped cooling on both fridge and freezer side. Temp controls show current temp (now 78), but when I set for lower temp, nothing happens. Hear small fan running, but...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 01, 2011 | Refrigerators
I own a amana fridge fridge on top freezer on bottom . all of a sudden my fridge stopped cooling the freezer still works fine I hear fans running but no cool air at all. please help me
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Amana Refrigerators
Kenmore SxS 596.52673200 stopped cooling
You have a refrigerant leak. Your coil in the freezer should be frosted. You're looking at 600 dollars minumum for repair.
Sep 12, 2009 | Frigidaire FRS23H7CS Side by Side...
Refrigerator stop cooling
THIS DOESN"T SAY WHICH FAN IS WORKING IF THE FREEZER FAN STOPS WORKING THE FRIGE WILL NOT GET COLD.
DOES FREEZER STILL FREEZE?. IF SO ITS YOUR FAN
Aug 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Kenmore Trio 596.75509400
Generally speaking if the refrigerator does not cool and you have frost on the back wall of the freezer it suggests a defrost problem.
However since the refrigerator started working by itself it would point to an air circulation problem from the fan in the freezer compartment failing to operate. The frost on the back wall without the fan operating would cause frost buildup because the heat is still trying to get to the coil through the back wall. If your refrigerator freezer has a door fan light switch something holding the door partly open would cause the fan not to operate. Look for a button or toggle and manually push it in. You should hear the fan turn on and the light will go off.
Mar 12, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
GE model GTST2BPLWW
they all have fans the freezer does all the cooling for the whole unit there is nothing in the bottom unit that cools the freezer fan blowes air from the freezer down to the bottom and draws air to the top if you dont hear the freezer fan running and there would be no doubt in your mind if it was then pull the fan cover and see why and let my know hold my rating till we are done please
Feb 11, 2008 | GE (GTS16BCS) Top Freezer Refrigerator
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
