Question about Goodman GMS90703BXA Heater
Heater won't come on - Goodman GMS90703BXA Heater
    Genius:
  • 1,015 Answers
The first thing to do is verify that you have power to your heater.If you have a volt meter you can remove cover from electric box inside furnace and set meter to a.c. volts and check across black and white wires. You can also turn your thermostat to fan on setting and fan should run if not you may not have power to heater or bad t-stat.
After you're sure you have power to heater turn thermostat to auto and heat. Turn temp setting up high enough to call for heat. See if your induced draft motor comes on. If it does not then check electrical connections or replace draft motor.If you have power to heater and t-stat is good if draft motor does not run then nothing else will work.
You can by pass t-stat to see if it's the problem by removing cover and and taking base off the wall to get to stat wires. Locate wires that are hooked to terminals marked R or Rh and W. Remove these wires and touch them together. If t-stat is bad this should make heater come on and run. If this works then you need to replace stat.
If this does not help you please let me know and tell me what you have found and I will do my best to assist you. Thank you
Posted on Jan 02, 2011
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
Heater does not turn on
If you have a gas hot water heater that won't stay on, check to see if pilot light is out and relight it if it is. If you have an electric hot water heater that won't stay on, then you should have an electrician check the wiring.
if you need an auto tool you can click here: chinasinoy.com
Nov 05, 2012 | 1990 Toyota Corolla
1993 buick park avenue heater won,t work.checked all fuses an relays
i beleive you did more than that.? you,ll probably find all have a common earth , chech and remove it , clean with a wire brush and replace, also chance the fuse you removed and replacer reguardless of it,s appearence , ensure its put back in the correct location,peter.
Sep 03, 2012 | 1993 Buick Park Avenue
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
Goodman GMS90703BXA Heater Logo
111 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
