Question about Memorex (MEMXMEMMC1008) CD Player
CD player is stuck with "hold" message. Can't figure out how to fix it.
6 stack CD Player in Auto
The CD player died. Probably the magazine (the thing that holds the cd's) isn't functioning properly, crooked inside the radio. Needs the radio repaired or replaced.
Apr 21, 2013 | 2005 Chevrolet Chevrolet Malibu MAXX LS
CD stuck in cd player
Hi there:
When CD ERROR shows on the player display, there is a problem with the CD mechanism. It will have to be sent out or taken to a repair shop to have it fixed.
Hope this helps.
Dec 24, 2012 | 2003 Ford Explorer
OEM CD player is stuck
have you tried disconnecting the battery cables? if this does not work, a CD may be stuck in it! You will have to remove the changer and open it up to remove the cd!
Aug 15, 2012 | 2005 Chevrolet Equinox
Trying to play a cd on the TEAC GF-680 . Blinking message
  • You may have some dust blocking an optical sensor that detects the door being closed. Try to blow into the door area with the tray open, either with your breath or with compressed air.
  • You can also try unplugging the player for 1 minute and plugging it back in to see if that fixes it.
  • Try a different CD. The DVD player may not like the CD you are trying to play or the CD might be dirty.
  • The DVD player might just be broken.
Feb 11, 2012 | Audio Players & Recorders
MD6541BLK cd player has two dashes (--), the cd spins and spins, and i am hearing a "zipping" noise. it does this for approx 30 secs then shows ERR. Is this cd player ready for the trash or can i...
It needs a new optical eye,also called laser eye.The part alone is $70+.This is a common malfunction of CD and DVD players and you described the exact symptoms.Greg
Feb 10, 2011 | Memorex MD6451R Personal CD Player
My cd is stuck in the player, i get an error 6 message when i try to eject it or play it
have u tryed holding the eject button for ten seconds my clarion does the same thing but it should eject the cd
Mar 05, 2010 | Clarion DXZ438R CD Player
2003 Ford Expositi CD Player will not play or eject
Does the CD door open or is it stuck open? If it is open look to see if you have a jammed CD. This happened to me and this is what I did. A CD had gotten off track and jammed the CD changer turn table. I stuck a little key in the slot and was able to pull the CD out. This fixed my problem. Hope it helps.
Dec 21, 2009 | 2003 Ford Expedition
A cd has gotten stuck in my Sony 5 cd/dvd carousel player. Appears that the label on the CD had gotten soft (sticky) and when the carousel rotates it stays stuck underneth the top while the carousel moves...
As long as the cd hasn't caused any other damage to the electronics or mechanics of the player, it should be an easy fix. First, open your carousel then unplug the player to avoid shock. Remove the top lid of the player via the screws on the exterior holding it in place. From there, the stuck CD should be right there for you to reach in and remove. Hope this helps!
Mar 24, 2009 | Sony CDP-CE375 5-Disc CD Changer
Cd stuck in my Dual XD5120 cd player in my car.
if the cd player has failed about the only way to retrieve the disc is to take apart the player
Jun 20, 2008 | Car Audio & Video
37 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
