Question about Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My dryer vent located inside the dryer drum turns black with a gooey substance on it. the metal plate(vent) inside the dryer drum gets so hot, it burns holes in my clothes.
  • Anonymous Mar 22, 2014
    dryer gets hot but will not turn not even when I try to turn it with my hand
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
You will need to replace the "high limit thermostat" in the dryer.
Posted on Jan 02, 2011
Dryer is making a scratching noise
Could be something simple like a coin or other metal object caught in the drum edge and rubbing as it turns. Next could be a bad or worn bearing surface for the drum causing it to rub metal on metal instead of riding on the proper bearing surface like it should. Metal on metal rubbing usually produces a black powder looking substance so look for that or a shiny metal edge around the drum edges.
Mar 29, 2015 | Dryers
Too long to dry my clothes
HI,
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jul 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Perforated metal plate in back of drum of new Frigidaire Affinity gas dryer has 1.5 inch oval of black char at lower left corner.
If the high limit thermostat were bad it wouldn't heat, I would recommend having your vent checked/cleaned. If the vent flows poorly it will retain extra heat in the dryer.
Nov 28, 2017 | Dryers
My whirlpool LER8648L dryer makes a burning smell within 5 minutes of starting it was wondering what would cause that
Dryer Gets Too Hot
  • When you have a problem with your dryer getting too hot, there are many things that could be causing the problem. Check to see if there is lint inside of the vent hose or inside the outlet of the wall exhaust. A blocked vent will definitely cause a dryer to overheat because it does not permit the heat to exit the machine smoothly. Make sure that you are only using firm and rigid metal or bendable metal duct according the manufacturers instructions. Look for kinks within the vent hose. You should also check for any obstacles or obstructions inside the outer damper.
    Make it a practice to check the outside vent damper every other month or so. Check to see if you can feel a good flow of air being released out of the exhaust. If not, the blower may be in poor condition inside of the dryer. Some other possible reasons for overheating include, a bad operating thermostat, worn, drum seals or a shorted heater coil.
Apr 18, 2011 | Whirlpool LER8648L Electric Dryer
Heating elements are lit up working normal, drum hot but not inside of drum. it takes forever to dry clothes. vent wide open no clogging inside. need help ?
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 04, 2011 | Whirlpool LER5636P Electric Dryer
I have an frigidaire electric dryer model number FERB6600ESO will not get hot. What could be the problem?
First check to see that your getting 220 Volts to the dryer.
Then locate your heating coil on the back of the dryer under the metal plates.
You should see a fan/blower housing that goes to the inside of the dryer drum that is where you will locate the heating coil, also some times the thermostats/thermistors are located either inside or outside of the same fan/blower housing. Check them to make sure they are not faulty.
Good Luck
Please rate me
Thanks
Aug 12, 2010 | Dryers
Very little heat in the drum..clothes arent getting dry
Check the following -
Cycling thermostat
Vent
Internal ductwork
Post further comments if you need more help...
Good Luck!!
thanks
Jul 19, 2009 | Whirlpool LEW0050P Dryer
Sears Kenmore elite quietheat front loading dryer not drying. Moisture builds up on the window inside.
Vent
Heating element
Internal ductwork
Cycling thermostat
May 28, 2009 | Kenmore 64902 Electric Dryer
Overheats and sets clothes on FIRE
sounds as if your experiencing an air flow issue, check your venting.. it would be normal to see a red glow from the right side vents with in the drum( its heating up after all, and its merely a reflection form the heater located on bottom of frame, no way its gonna heat entire drum to "red hot")
Dec 24, 2008 | Whirlpool GEW9250 Electric Dryer
Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer Logo
277 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
