Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Maytag wide by side.
The unit got warm . Freezer frosted up. I unpluged it for about 4 hours and now it seems to be working fine
    Problem Solver:
  • 6 Answers
If it happens again, check the defrost timer. If it does not self defrost, the cooling coils (evaporator) get plugged with ice and although it is frozen, the ice stops the transfer of heat. Unplugging the unit allowed it to defrost so air could circulate again.
Posted on Nov 09, 2008
Have a maytag french door fridge on top freezer on bottom, fridge is not staying cold, frezzer works just fine?
Hi
Check the back wall or floor of the freezer section for frost. Check the freezer (evaporator) fan to see if it is running. Check the condenser coils (under the unit) for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both doors wide open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 04, 2011 | Maytag Refrigerators
Maytag Wide by Side Freezer not working
open the freezer panel at the back of the freezer section and check the evaporator fan, it could have been burnt.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Fridge isnt working.freezer side is
well if this just started you will most likely find within the next 24 hours the freezer will stop also...the unit actually cools from the freezer side first and then the air is pushed over into the fresh food side or refrigerator side as you are calling it... few things you want to check... first there is a opening between the two sides make sure that it is clear and if has an eelctronic damper it is opening if it is warming up in refrig it should be wide open at current time. 2nd if that is good make sure you have no frost on the back wall of the freezer wall and that the fan in the freezer is working . you may have to hold the door switch closed will listening... the fan in the freezer should be running and there should be no frost on the back wall... if there is frost then maybe you have a defrost problem which could be a heater,a defrost thermostat or a timer problem... if there is no frost make sure the compressor is running and you here no clickin coming from compressor .. hope this helps check them items and if you need anymore help post again....
Jan 01, 2011 | Maytag MZD2766GES Side by Side...
Freezer is cold, but refrigerator not and it is all the way to coldest. What is wrong?
Check for frost built up in the back wall or floor of the freezer section. Check the freezer /evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with the doors wide open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer side is cold but the fridge side is not getting cold
Luispinto243 --
The heat exchanger is in the freezer side of a refrigerator. If the cold air pathway has gotten frosted-up, or the blower is not working, the fridge side will get warm. If possible, fully defrost the unit and the frost/ice build-up will thaw-out and the fridge will start working again. Adjust the thermostat to the energy-saving position. Trying to lower the temperature will not fix the problem. If you are still having problems, write back. -- SWT
Aug 22, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag wide by side not cooling
no cold, no compression.
Expansion of compressed freon or ammonia (these days) genartes the cold. You need a compressor running, a proper working expansion valve (not frozen in position) and ventilation over heat exchanger to get lost of generated heat from compression.
Thermostat may be broken. Check this with other temperature gauge around.
May 05, 2009 | Maytag MZD2766GES Side by Side...
My freezer works fine, however my fridge is not cold. It seems as there is no air flow in the fridge. I have checked behind the crispers to ensure nothing is blocked. I have a Maytag msd2734ge, wide by...
check in the freezer side and look at the back wall and see if there is any build up of frost, your coil may be block, so no air flowing through the coil, your unit may not defrosting, you need to check the defrost heater,the defrost timer or the defrost thermostat one of these part can be defective
Dec 11, 2008 | Maytag MSD2734GE Side by Side Refrigerator
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag wide by side
you're lucky, these fridge's are garbage!
Jul 08, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
My maytag fridge frosted up and got warm. I let it sit turned off for about 4 hours and it sems to be working fine now. will this reoccur?
yes it will frost up again, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Maytag Refrigerators
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
74 people viewed this question
Top Maytag Refrigerators Experts
Richard Roth
Richard Roth
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
