Air-Conditioner fault - mitsubishi Model - FDC308HEN3B Error UO e57 showing. this appears after a couple of minutes of running but not cooloing.
  • 2,133 Answers
E-57 refers short of gas or no gas. Find leak and arrest. Vacuum and recharge gas.
Posted on Jan 02, 2011
60000 BTU mitsubishi air.con is showing P8 error code and is blowing only hot air even temperature is set at 16 degrees. What might be the cause and how to rectify it.
go google and type in--Mitsubishi air conditioner fault code p 8-- and there are pages including a mitsubishi site that is a pdf version down load describing the fault
Dec 10, 2015 | Mitsubishi Heating & Cooling
HOW TO RESET A CODE ON A SAMSUNG SMART INVERTER MODEL NO AQV24uwbn?
Unplug it, then plug it back in. Unless you repair the cause of the error code, the unit will fault out every time it sees the error. It is basically saving its own life.
Feb 23, 2015 | Samsung Heating & Cooling
Indicator light
May be showing a fault code, you need to count how many times it flashes. Could also be a delay or de ice mode which will go away after a few minutes
Aug 05, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Mitsubishi electric Mr Slimair conditioning. It runs a few minutes in cool mode, then it stops and an error of P8 code appears. When it runs, the fan is not strong.
P8-Abnormality in outdoor unit.
1) Wrong wiring of indoor/outdoor
connecting wire
2) Reversed phase
3) Protection device is working
4) Damaged outdoor coil thermistor
Solution:
1) Check the indoor/outdoor connecting wire.
2) Change the connection of electric wiring.
3) Check the protection device.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board.
Hope,it's helpful.
Jan 15, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr. Slim PK 18 FK 3 will only cool for 3 minutes, then goes to fan only for 3 minutes, then shuts off completely with P8 00 flashing as an error message
P8 usually is caused by a low charge...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Aug 30, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi split-type air conditioner model MSH-26SV. When the unit is switched on, the 2 green lights on the front panel light up normally but but the unit doesn't work at all and, after a few minutes,...
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
May 23, 2010 | Mitsubishi MS09TW Air Conditioner
Air conditioner runs for 5 minutes then shuts down on fault code E6
your ac's compraser is getting off due to heat in that area voltage is one of the big issue 2 your thermostat is not working properly of your motor is jammed not rotating properly RPM(running per minute)
Feb 02, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Fan @ compressor wont run,one light is flashing
flashing light is showing an error code. if the unit is under 5 years old it will be covered under warranty.. if you want you can try and reset the power by turning it off at the isolator next to your outdoor unit, leave it a couple of minutes and switch it back on. this will reset the fault code, if the flashing light comes back there is a definite problem, if it runs the fault may have been caused by a power surge or something
Dec 22, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
P8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
458 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
