My Fujita N13174 is leaking gas. had it refilled and it lost gas again. The hoses are freezing up on the outside.I am told cheaper to replace than to repair. Is this correct?
  • 2,133 Answers
Friend! if your car tier puncture, what you will do? First arrest leak and then filling air, is not it?
Same way, when there is leak in a/c system, call repairman to find out leak by pressurizing nitrogen and arrest it. Then vacuum and do gas charging. This is the permanent solution and also cheaper cost than going with replacing another unit. Helpful advise?
Posted on Jan 02, 2011
Mitsubishi Eclipse AC leak & dealership cannot find the leak. Been in for service 5 times and dye is not showing leak. Any suggestions as to where it can be?
Your leak may not be coming from the outside. The AC has an evaporator tray that catches the humidity pulled from the air in the car drains it to the ground.. Sometimes the drain gets plugged up. Clear the drain and clean the tray. Sometimes that situation is accompanied by a nasty smell.
Mar 27, 2015 | 2007 Mitsubishi Eclipse Spyder GT...
Can i fix my air conditioner hose? i was told there was a leak in it
If there was a leak you need to find the point of leak first so as to recitfy and then the gas must be refilled. In some cases it cannot be the joints or the hose but can happen in the cooling coils or the condenser. If so you will need to release gas and then use a pressure system to check for leak - such equipments- comrpessor- is need to check the leaks at high pressure or else the gas filling will be a wasteful operation.
Jun 21, 2011 | 2005 Ford Taurus
When I turned on my Acura TSX A/C, it was blowing hot air, so I took it into the dealership. The customer service rep called me later and told me that I had a leak in my A/C hose that was causing freon to...
I cannot dispute the price the dealership quoted.
That said, a leaking A/C hose cannot be repaired. It needs to be replaced. These are vehicle specific parts so can get expensive. It also costs to vacuum the A/C system and refill with the the system
with freon.
The system ran out of freon because of the leaking hose, put in more freon with the leaking hose it all leaks back out.
So in effect the repair is a new hose, and a refill.
Hope this helps settle your confusion,
Wayne
Mar 13, 2011 | Acura TSX Cars & Trucks
How much work is it to fix a leak. it is spraying out anti freeze up by the motor. It looks like maybe the where the seal may go
If the leak is a hose, not a big deal. Drain antifreeze disconnect hose, instal new hose, refill antifreeze. If the leak is a water pump also not a big deal, same procedure.
If the leak is in the radiator, a bit more complicated. Radiator can be replaced or repaired by a radiator shop.
If leak is coming from somewhere else on the engine, could be more serious, like a gasket leak. If this happened you would get fluids mixing ( oil/gas)
Good luck. A Haynes manual is a good investment for your car.
Feb 05, 2010 | 1997 Oldsmobile Achieva
Water dripping from internal unit of J.B.S. split system air conditioner
Hi
This can be due to three reasons. The water drain pipe is block. Which can be sucked clean with wet/dry vacuum cleaner. The drain pipe behind the unit is not sloping downward away from the unit. Or the coils of the internal could be iced up. If this is the case the unit should be switched of until the ice is completely melted and switch the unit on again. If the copper pipes leaving the the condenser unit outside is starting to freeze up, the unit is short of gas. Call a A/C company to refill the gas and search for possible gas leaks.
Jan 26, 2010 | Heating & Cooling
Anyone have a Fujita Installation manual
it should be all coded on the head and compreser for the sparky
Dec 17, 2009 | Heating & Cooling
Fujita V-Lec Air con
i need a window kit for my air con
Jul 04, 2009 | Heating & Cooling
Gas fumes inside and out side the car when it is hot outside
Try having the area that the hose was disconnected from steamed cleaned, or go to a car wash wash and spray the area. It might help, that is if you already haven't done so.
May 28, 2009 | 1998 Ford Windstar
Lost Operation Manual
I was unable to locate your particular owners manual but click the link below and double check your model numbers. Also there is contact info so you can call to get more information if it is necessary.
http://www.fujitsugeneral.com/owners_manuals.htm
Mar 22, 2009 | Heating & Cooling
Heating & Cooling Logo
100 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
