Question about Akai Cameras
AKAI Digital photo frame ADPFO7XD4 Can't get it to show pictures in order
SOURCE: 7 digital photo frame problems
Yeah, I just got one too and I have no USB thingy, and I kinda need my memory card.... hmmm.... maybe it should come with one. That's a bright idea huh! And how on Earth do you get music on it?!
Posted on Dec 26, 2007
Paul319581
  • 101 Answers
SOURCE: Linx Digital photo frame can't
Change the settings from the options !!
or edit the image be4 sending to frame !!
Posted on Mar 09, 2008
SOURCE: Insignia digital photo frame won't recognize some .jpgs
When you save in Photoshop make sure you select "Baseline ("Standard") on the JPEG options when you save. That should fix the problem for you. It did the trick for My Kodak SV710 digital frame which wasn't displaying images I had edited in photoshop.
Posted on Apr 03, 2008
SOURCE: 7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Posted on May 12, 2008
pauman
  • 248 Answers
SOURCE: Philips digital photo frame 7FFI series
Here`s a tip i found for you...
1. Connect the frame to your PC using the supplied USB connector. Navigate to the \DCIM\100Frame directory and delete all the Phillips advertising pictures there.
2. Create a directory on your PC and put copies of all the pictures you want to display there.
3. Download the free picture resizer utility from Microsoft at:
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
(Look for Image Resizer in the right column). After installing it, "Select All" pictures in the directory you created, then right click and select "Resize Pictures" from the context menu. Choose the 640x400 radio button. Sort by size and copy all the small ones into the "\DCIM\100Frame" directory on the frame drive (Called Removable Disk on my PC).
Posted on Jun 20, 2008
How to get details about large digital picture frames?
There are lots of websites on the internet that happen to be giving info associated with large digital picture frames. They are especially designed for individuals who are searching for quality information regarding digital photo structures. to find out more kindly visit this web site: http://www.digitalframe0.com/ Show off your photos with EOOKE Digital Photo Frames
Oct 06, 2016 | Photography
I inserted a thumb drive with pictures on it and although they show on the frame, they do not show in the order that I numbered them in
The following advice is not specific to your model, but you have a common problem and the solution I suggest usually works for most makes and models.
Try renaming the files in the order you wish them to play as 001, 002, etc. If you do so without the leading zeroes then on some models of picture frames the filing system gets the images in the wrong order. Note that if you are uploading thousands of images then you may wish to start the numbering at 0001 instead. After renaming the files, re-upload them to the photo frame and you should find that they're OK. Depending upon your host computer's operating sytem you should be able to batch rename the files instead of laboriously renaming and saving each one individually.
Aug 21, 2011 | Quantaray 7-Inch Digital Picture Frame -...
How can I reverse the order of the photos..it is showing them in the backwards order
I'm not paying someone to fix this problem or give my credit card number for a 7 day free trail.
Please remove my name and address from your files.
Thank you
Tina Leathers
Jan 07, 2010 | Westinghouse 8" LCD Digital Photo Frame -...
New xD M+ card won't work in the digital photo frame.
Alot of the digital photo frames will only display images up to a certain resolution. There is a good chance your camera resolution is too high for the photo frame. try change the settings on your camera to 3mp or so and take a few photos and see if they will display.
Jun 16, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Order of photos
Hi, u need to arrange the photos by size or by alphabetical order in your desktop first, then u need to transfer it to ur pendrive, then plug it to ur device everything will b fine then. Rate the soln dude plz n tell me what happened
Jan 25, 2009 | Electronics - Others
Pandigital Frame Photos NOT in order or NOT in sequence..FIXABLE?
i'm having the same problem. I've gotten a good amount of photos going in the timeline order but then it starts messing up again to where it's not in order! GAH i thought i had it! :(
Jan 10, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Dec 13, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
How do I load pictures from my computer to the memory card in my camera?
You have to first download the images to your computer and Save them in a folder. Then connect the USB cable from the digital photo frame to the computer and transfer the photos you want onto the frame. Some time you have to change the photos name to alphabetic order so you photoframe will display the pictures in the correct order.
Feb 20, 2008 | HP Photosmart 635 Digital Camera
Slideshow on axion digital photo frame
noooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
Dec 05, 2007 | Computers & Internet
IQ Digital Picture Frame
I have an IQ Digital Photo Frame but the manual is in French I would like to be able to download the English version can anyone help please
Nov 19, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Cameras Logo
32 people viewed this question
Top Akai Cameras Experts
Are you an Akai Camera Expert? Answer questions, earn points and help others
