Question about Keurig B60 Coffee Maker
Trying to use the adapter to make my own coffee and when it coffee comes out the bottom it spits all over the place. The "K" cups don't do this. Only when I use the adapter?? Is there a problem with the adapter or an I doing something wrong?
    Sergeant:
    Champion:
  • 342 Answers
You have to lock the lid of the adapter on by rotating the lid until it locks into place and you cannot pull it off that should help i had the same problem when i got my adapter
Posted on Jan 02, 2011
When the cup button is pushed, the maker tries to make coffee (five or six grinding type sounds) but nothing happens. The screen reads "brewing" but no coffee comes out.
Run the keurig with vinegar instead of water. Then run it 5 times with only water just to remove the vinegar taste. Do this once a month. Also there are pins that pokes holes on top and bottom of coffee kcups, find the pins and clean it by unclogging with paperclips or some thinner wire. Buy a K-cup holder from amazon.com. Its the black cone shaped holder.
Jan 09, 2013 | Keurig Elite B40 Coffee Maker
Water does not go through the k cup. when the cup is placed in the coffee maker and the lid is dropped down, the needles punch through the cup at the top and the bottom. the water spills over the top of...
Yup... the bottom needle is plugged...Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 24, 2011 | Keurig B60 Coffee Maker
My keurig keeps spitting the water back into the water reservoir and not brewing a full cup. I have cleaned the needles and have not descaled. How do I fix it??
Hi, Place your finger over the tube going back to the tank and force the water through the needle...
heatman101
Sep 11, 2011 | Keurig B60 Coffee Maker
The "funnel" piece underthe cup
Here is a tip that I wrote about how and where to get replacement parts foryour Keurig Coffee Brewer
Keurig CoffeeBrewer Replacement Parts
heatman101
May 18, 2011 | Keurig B66 3-Cup Coffee Maker
My 9 month old machine only spits out water for a second
I called Keurig and they felt that it was likely a blockage at the needles, but despite cleaning them repeatedly, there was no improvement. They are sending me a replacement.
Sep 16, 2009 | Keurig Platinum B70 Coffee Maker
Water leaks out from underneath coffee maker
Well they don;t give these away for sure. Lets see if we can help you out. ? are you over filling it.This happened to me because I was reading the fill line wrong. {got new glasses} . If not may be you could try makeing less. But if only 1/2 cup comes out and no more, that wouldent indacate a leak in the tank, if there was it would all leak. Try backing off on the coffie and water, and see if it still leaks. if it does get back to me. DFD
Apr 12, 2009 | Bunn 10 Cup Home Coffee Brewer
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
Mr coffee urn inner stem problem
MY MR COFFEE 45 CUP URN SPITS OUT WATER WHEN BREWING COVER DOES NOT FIT ON TIGHTLY SOMETHING IS MISSING.
Dec 05, 2007 | Mr. Coffee CBTU45
Keurig B60 Coffee Maker Logo
76 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
