Question about Sony Playstation 3 (PS3) Console
My PS3 wont read PS3 games - Sony Playstation 3 (PS3) Console
  • Aaron Busch
    Aaron Busch Jan 02, 2011
    Can you try putting in a blu-ray and seeing if it reads it?
  • 3,530 Answers
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Thank you!
Posted on May 11, 2011
  • 1019 Answers
SOURCE: ps3 wont read games movies nada.
send it Back it,s warranted.
if you mess about with it, or open it.
Throw your warranty in the Bin.
they,ll replace it most likely. sounds like the lasers gone already. 2 weeks you say, good old SONY eh.
get your money back and buy an XBOX 360 :)
Mike @ Compurepair.
Posted on Feb 24, 2008
bubulica2000
  • 55 Answers
SOURCE: ps3 not reading disc
the Diode in the PS3 units actually has 3 diodes built in. Looks like your blu ray one went bad the other 2 still function.
Order a replacement KEM-400 AAA and replace it (the whole laser lens mechanism with deck). If you still have warranty send it in.
Posted on Sep 05, 2008
SOURCE: ps3 wont read games discs
Same problem. It won't read games but reads everything else fine.
Posted on Oct 18, 2008
SOURCE: ps3 wont read disks
If YOUR WARRANTY IS UP. taking the ps3 apart is easy as long as you have the rght screw drivers. getting the plate off is the hardest part. there is a hex screw under the warranty sticker. after removing the screw, simply slide the plate down and it will pull off. then there are about 8 philips head screws on the casing itself. after removing these screws the top is hinged on the front side of the system... lift the back untin it is at a 90 degree angle and and remove the flat wire that goes to the SDcard slots by lifting the black flapwith your fingernail, then the top is removed. at this point the disk drive is no longe fastened by any screws of clips. pull the plug from the left side toward the front out to diconnect that set of wires. then there is a big flat silver strip connected to the bottom of the drive. once again lift the black flap to release this strip.now you are ready to open the drive itself. there are 2 silver screws on the bottom rear of te drive and 3 black ones at the front. you will need a very small philips head screwdriver for these. then the gray casing will come off. thelense is not exposed yet. there are still 5 or 6 tiny black screws on the top of the drive that will remove the black plastic case THERE ARE 2 TINY WIRES COVERED BY TAPE BE VERY CAREFUL NOT TO PULL ON THESE WHEN TAKING THE BLACK COVER OFF
. now the lenseis exposed. simply clean it with rubbing alcohol and q-tips and reassemble the machine. BE SURE NOT TO GET ANY OF THE WIRES PINCHED WHEN SETTING THE DRIVE BACK IN PLACE AND DONT FORGET THE LITTLE METAL GROUND ON THE RIGHT REAR OF THE DISK DRIVE. ANY ?S E-MAIL ME AT hartsedustin@yahoo.com
Posted on Apr 03, 2009
al-sultan
  • 250 Answers
SOURCE: My PS3 ont read PS3 games but ps1 and ps2 are compatible.
just fold a buisness car in half the long way. don't fold it hard. slide it in the disk slot about an inch to open up the rubber flaps. then just blow hard.
TIP: try not to spit in there . first clean the dust off the ps3..... dont want to take the chance of putting more dust in there. canned air will work too just make sure you spray air not liquid .
If your diode is not burned out yet then this should fix your problem.
1. Plug in controller
2. Have system in standby mode (red light)
3. Hold down power button for a full cycle (will turn on and back off again)
4. Hold power button again will hear 2 single beeps then a double beep.
5. As soon as you hear the double beep immediately remove your finger from the power button.
6. Hit the PS button on controller when it tells you to
7. Go to only option 3 (restore)
8. warning: select any other option and you can wipe out everything only use option 3
9. Follow on screen prompts
Posted on Jul 21, 2009
Ps3 wont read ps3 game disc
It may be inside the ps3 console and it may be broken you have to either clean the disk or get a new ps3 but try contacting a game stop or going to a local game stop to ask for help you might be able to fix it
Sep 01, 2012 | Video Game Consoles & Games
My ps3 wont read games, what is the problem?
ur PS3 wont read PS3 games? or ps2...because ps2 only works on the very oldest models. But as for ps3 games...if NOTHING will read then u have a problem with the laser for reading the discs...which i mean u can pay 150 dollars or something and wait 4 weeks to have it shipped and fixed...or u can try and fix it urself...whatever floats ur boat.
Jul 05, 2010 | Sony Video Game Consoles & Games
My ps3 wont read disc and went it does the game wont load it will just say error has occured
This is an extremely common problem with the PS3 and is caused by a problem with the laser on the Bluray drive which is malfunctioning and can no longer read the game disk properly.
The PS3 uses a dual laser system. This consists of either a dual refractor type lens or two entirely seperate lenses depending on which pickup is fitted to your particular system. One laser is for reading ordinary DVD disks and PS2 disks and the other for Bluray and PS3 games.
The symptoms you describe are typical of a failure of one or both of these lasers.
For more information on how to resolve the problem please have a look at this FixYa Tip on the subject.
Many thanks for using FixYa.
May 20, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont read ps3 games only ps2 games
sounds like a dead Laser they are a dual laser will read DVDs n CDs but wont read Blueray movies or PS3 games Laser needs replacing
Sep 16, 2009 | Sony Playstation 3 (PS3) Console
PS3 console will read PS2 games and dvds but not PS3 games
Sep 15, 2009 | Sony Playstation 3 (PS3) Console
Wont play ps3 games
try restoring your ps3. My ps3 wouldn't read disc, but since I restored it it's now reading discs. Go to system settings on you're home screen. Then go to restore ps3 system & then go to full restore. It will take 3 & 1/2 hours but it could fix you're problem.
Aug 16, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont read ps3 games
PS3 Not Reading Games
If you have this problem it is because the laser has shifted from where it needs to be and the good news is that it is not that hard to fix all you need is a good repair guide.
You can of course send it in but the disc reading issue you should be able to fix in less than 1 hour from home.
Check out this link for a full explanation:
Dec 22, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont read games
the lens eye maybe dirty clean it rubbing alcohol on a Q-tip. gently clean the eye and use the other end of the Q-tip to dry the access rubbing alcohol.
Nov 22, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont read games discs
ts a problem with the latest download update. sorry to say but its a job for sony as long as its still under warranty. just phone them up explain the probs your having and they will send you a new (normally reconditioned) unit out. sony's replacement service is very good.
Feb 12, 2008 | Sony Playstation 3 (PS3) Console
PS3 wont load games
scea consumer service 1-800-345-7669 monday to saturday 6am to 8pm pst sunday 7.00am to 6.30pm pst thanks for using fixya pierre
Feb 06, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
48 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
