Question about Sharp XLMP131 Shelf System
Sharp XL-MP131 shelf system won't read any CDs. Keep getting "TOC READ" and then "No DISC". Discs are not scratched or dirty.
3 Suggested Answers
SOURCE: CD problem in Sharp Micro Component Shelf system XL-HP515
Compra un disco limpiador de lentes laser y puede que esto solucione tu problema ya que puede ser solo suciedad en el lente.
Posted on Apr 09, 2008
dehowletts
  • 14 Answers
SOURCE: Sharp XL-HP505 Not playing CDs
Hi try this.....
Put the system in standby (ie off but plugged in) then whilst pressing down the record button and the X-BASS/DEMO button, press the PRESET DOWN (i.e.left hand one) button until "CLEAR ALL" appears, then power on your system.
This gave me some functionality back i.e. i can play normal wave CD's but not mp3 ones....
Hope this helps
Posted on Dec 17, 2008
I canot get cds to play and theres a lit up message saying no cd when theres one in to play
Chances are the lens that sees the disc is dirty and needs cleaning. If can't see the disc and read the TOC it will just say there is no disc.
Mar 21, 2016 | Audio Players & Recorders
What do I do about a toc read error?
Are you trying to play a 'burned' copy or a new cd?
Oct 12, 2014 | Sharp XL-MP130 CD Shelf System
Wont play cds. toc read comes back with no disc. what is wrong
Hi!
Make sure discs are clean, purchase a lense cleaner to remove any grime or particles from the CD lense. If still no joy your laser is either out of focus, miss-tracked or completely shot and requires replacement. If it's the latter, rplacements can cost from $50 upwards depending upon what is required to fix the problem. You may be wise to replace the system OR purchase a seperate CD player (as used in a seperates system) and plug it into the aux input.
Jan 08, 2011 | Sharp CD-SW200 CD Shelf System
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Oct 09, 2009 | Philips CDR770 CD Recorder
Hi try this.....
Hope this helps
Sep 07, 2008 | Sharp XL-HP505 CD Shelf System
CD Player returns NO DISK code
looks like the OPTICAL LEN part D.O.A. on you , I suggest to replace the OP LEN , AND SHOULD BE ABLE TO PLAY. hope this helps
Apr 19, 2008 | Sharp CD-BA150 Shelf System
Apr 09, 2008 | Sharp XL-HP515 CD Shelf System
Toc error
toc error means "table of contents" error... means the player is unable to read the disc at all. May have a dirty focal lense to laser. clean gently with some windex on a cotton wool bud. It may be a faulty spindle motor that spins the disc. the bearings get worn or uneven and do not allow for disc reading to be successful. a check for this is a drop of oil to the bearing. It may then start to read discs, but will still require the motor to be replaced. . Check for the above... but if there is more required, take it to a Kenwood 'Agent... it may need a laser change
Dec 04, 2007 | Kenwood KDC-MP228 CD Player
Won't read disc
The laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 04, 2005 | Aiwa NSX-A115 Shelf System
131 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
