Question about Refrigerators
When I hooked up our Frigidaire water, I noticed it leaked water from the elbow joint when we dispensed water; no leaks occur otherwise. I replaced the elbow joint, but the same problem exists. I'm stumped. Thanks - Steve
  • 29 Answers
The pipe that the elbow joint is connected to may have a small hair-line crack
Posted on Jan 02, 2011
Leaking water dispenser
Sounds like the water valve isn't seating properly, so a small amount of water gets by causing the leak. Replace the dual water valve.
Mar 24, 2014 | Refrigerators
Water leaking from under Frigidaire fridge
Hello - There are many reason for this issue to occur, for example the refrigerator could have a crack in the defrost pan, a defrost drain line blockage, a leak from the water supply line for the dispenser or ice maker, but most cases water leaking inside and draining through the refrigerator cabinet. Try confirming that the vales are tightened. If the connection is still leaking, turn of the water supply line to the water valve and take the connection apart. You can try using Teflon tape when retightening the connection to ensure a good seal. If these suggestions prove to be ineffective contact a professional to move forward accurately.
Oct 02, 2012 | Frigidaire Refrigerators
Behind the water pump it leaks antifreze its not the water pump but the hose from the radiator hook up to this metal tube and goes to the water pump that join is leaking does it have a gasket in between or...
you talking about water pump bypass heater pipe the metal elbow piece to the water pump hosing.the metal elbow piece is held in place by small bolt or bolts you should have either gasket or o ring betwween where metal elbow mounts to water pump housing.replace the hoses also.some times the hose will be leaking not gasket or o ring at the metal elbow.make sure screw or screws not loose or missing to the metal elbow pipe.
Apr 17, 2011 | 1997 Geo Metro
Noticed that our frigidaire crown series front loader washer has been leaking while wash cycle is going. Leaks occur at two places: from the bottom side of the door and also from the detergent dispenser...
Well from what ive seen the detergent dispenser will usually leak due to an excess build-up of fabric softener. If you remove the drawer and look up at the top of the dispenser you will see numerous small holes. If you see moldy gunk its fabric softener residue. This usually restricts the water coming into the dispenser causing it to "shoot out" in random directions. To correct the problem you can take a putty knife and scrape off the visible build-up then take a piece of wire or a pipe cleaner and stick it into the individual holes and clear them out one by one.
If you feel confident you could go as far as removing the top panel and the will be one access screw from the front panel that you can see and the dispenser can be removed. Be sure to disconnect the hose that hooks into it (it can be hard to remove and put back on) but then you could actually rinse it out, which is what I usually do.
If your leaking from the bottom side of the door its usually the way the water drips down from the dispenser or just a few drops of water from opening the door. Its common to see a water residue streak at 6 o'clock right under the door.
Hope this helps _MJ_
Feb 07, 2010 | Frigidaire FTF530FS Front Load Washer
Water leaking out the bottome of the disposal.
Check WHERE the water is coming from... tie paper towels around the fittings... at the top of the elbow that comes out of the side of the disposal and points down, just below the compression nut where the vertical part of the elbow enters the P-Trap, below the nut on the other side of the P-Trap, below the nut on the bottom of the elbow where the vertical part of the P-Trap goes horizontal. DRY off the bottom of the cabinet and put a dry paper towel down...
NOW, run the water, get a good flashlight and see exactly where the water is coming from (the paper towels tied around the pipes will help you see which compression fitting is leaking) if the water is not coming from one of the joints, and is coming from the actual disposer housing, that housing may be cracked and need to be replaced. Otherwise, if you can find the compression fitting that is loose and leaking, tighten it. If that doesn't work, you may need to replace the compression ring (plastic washer) which you can buy at any HW store.
Oct 11, 2009 | Emerson Home
Replacing a water elbow in a Fridgidare model FRS26ZRFW1. Can't pull old plastic elbow off the existing tubing. Do I need to cut and push in? The tube is coming into the ice maker/water dispenser from the...
I went to Lowes and bought a new Elbow (2.49) and cut the lower tube right at base of elbow. Upper tube slid out. Pulled a little on bottom tube and replaces easily.
Jun 15, 2009 | Refrigerators
Side by side gallery ...water leak
  • it sounds like the water valve is not closing fast enough.
  •  this will cause the ice-maker to overflow a little.
  •  your ice-maker may have an adjustment on it to control how long it keeps the water valve on.
  • it should be a screw with a + and - sing on it. it may be under the ice-maker plastic cover.
  • if it keeps doing it then you may need a new water valve.
Jun 29, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whirlpool dishwasher leaks everywhere
CHECK YOUR HOSES FOR CRACKS. BE SURE THEY ARE ATTACHED SECURELY TO THE PUMP OULET.
THERE IS ALSO A BLACK HOSE FROM THE VALVE THAT GOES UP THE LEFT SIDE TO A VACUUM BREAK ON THE SIDE OF THE TUB. BE SURE THE HOSE HASN'T BEEN DAMAGED OR DISCONNECTED. IF THERE IS SUFFICIENT SUPPLY HOSE, PULL THE DISHWASHER OUT OF IT'S INSTALLATION AND TURN IT ON. WATCH FOR WATER DRIPPING ON THE FLOOR AND TRACE IT BACK TO FIND THE PROBLEM.
Mar 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
your tub seal needs to be replaced. you might have damaged it when you moved it
Jan 25, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
