Question about GE Refrigerators
My refigerator is leaking out of the spaut where you get the drinking water
    Genius:
  • 1,847 Answers
Why is water leaking at the bottom in front refigerators
Water leaking in the freezer and on the floor in the front of your refrigerator usually is caused by a blocked evaporator drain line.
Hope the video helps you understand what you will need to do to fix the problem.
Appliance 911 Sea Breeze
Leaking Refrigerators
Sep 29, 2015 | LG LRFD22850 Bottom Freezer Refrigerator...
My side by side refigerator ge model TPX21PRDA is leaking fron underneath when the water line is turned on to the ice maker.....why and how to fix it.
I have found pin hole's in plastic water line. Pull out from wall and get a flashlight to see. Turn water
back on to find leak.
Feb 01, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Water on the floor on the left side of the refigerator
possible water line couplin leak located under left front of refrig behind grill or cracked line.
Mar 01, 2010 | Kenmore 53642 / 53644 Side by Side...
My refigerator leaves too much moisture in the refigerator. Everything has mositure on it.
99 percent of the time that is from leaking door gaskets or a door not closing completely. The moisture you are seeing is from air entering the refrigerator and the moisture in the air condenses to water. Check the door gaskets for a good seal all around and make sure there is no gaps anywhere when the doors are shut.
Sep 13, 2009 | Refrigerators
Refigerator is leaking
There are many types of leaks and where they begin. It is my understanding that you are speaking of the inside back of the refrigerator. Below is a link that covers many different ways they happen. So if I am mistaken by what you are saying please don't rate me low because your meaning was something different. Just tell me what the problem is an where. Thanks, Sea Breeze
click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is leaking really badly underneath my Whirlpool refigerator.
I had this problem. Check you water line leading to your ice maker. the plastic section of it running up into the freezer cracks and leaks. easy fix, replace the tubing if it's leaking.
Jul 12, 2009 | Whirlpool Refrigerators
Refigerator will not saty cold but freezer works
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Jun 28, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Three year old Whirlpool Refigerator (ED5FHEXNB), water leaks from bottom of refigerator when outdoor garden hose water is turned on. Only leaks when outdoor garden hose is turned on. Water filter, Brita...
Hello it sounds like you have a leaking water hose which you need to find. maybe check first where it connects into the back of the unit.. Otherwise the fridge has a blocked drain in the freezer. cheers
May 15, 2009 | Refrigerators
It drinks cooliant
look around the water pump . water pump will leak very slow.ive had a few ford do that to me. have a nice day
Mar 19, 2009 | 1989 Ford Mustang
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
