Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Sears/devilbiss 5hp 30 gal 240 volt 919176952 I need to know how much oil this compressor takes. I called Sears and they said "they have no idea" Exhaustive search on the internet gives no clue and no quantity in the manual only the oil weight is specified.
  • 1388 Answers
SOURCE: type of oil
Air compressor pumps can use different grades of oil depending on weather conditions and usage, however do not use engine oil. Some Ingersol Rand pumps use a synthetic oil available through WWGrainger on the web. (generally not model specific) If this pump is lightly used you can use the less expensive compressor oil sold at Lowes lumber made by Campbel Hausfeld. It sells for less than $3.00 a bottle. Generally speaking, under normal weather conditions and light duty use, do not worry about the weight of the oil; just make sure that it stays clean and at the right level. If your compressor is running hot, it may be due to other problems like the check valve, head gaskets leaking between cylinders or chambers or high usage. If, however you just want the best oil for your compressor, use the synthetic. It is usually colored blue or green. This oil is special formulation to prevent breakdown in high heat and will not allow carbon for form on parts or inside of the hoses. enjoy
Posted on Nov 29, 2008
  • 1388 Answers
SOURCE: Craftsman 5 hp 30 Gal Won't build to more than 50/60 PSi
Most oilless compressors suffer from a short lifespan of the cylinder and piston ring. Unplug the unit and remove the cover to expose the cylinder and rod. Move piston to topmost position and examine the condition of the cylinder. If you see scratches or worn areas close to the top of the cyl. then most likely will need rebuild kit. (Not expensive) If cylinder looks good, remove the head and check the reed valves for debris or broken reed. Reed valve plate is also available as part with gaskets. To extend the life of an oilless compressor try not to use it in dusty or sandy areas as the bottom of the unit is open and tends to **** dirt into cylinder. Good Luck.
Posted on Dec 31, 2008
  • 1388 Answers
SOURCE: Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
Posted on Apr 26, 2009
  • 5 Answers
SOURCE: my sears 2hp 15 gal compressor runs but pressure wont exceed 60lb
compresors pump, valvs or sels gon!
Posted on Jul 15, 2009
  • 138 Answers
SOURCE: sears craftsman 3 gal/1.5 hp air compressor won't run
are you using an extension cord? if so, plug the compressor into a wall socket, if it fires up fine then your extension cord is too long or not heavy enough - other problems could be a bad start capacitor, a loose connection in the pressure switch, or a bad switch
Posted on Aug 18, 2009
What type of oil to add
Mobile synthetic 10-30 , Craftsman compressor oil if K-mart or Sears are near by. You can also use a non-detergent 10 - 30 motor oil , I use Mobile or Craftsman in mine. I have three - one is a Campbell Hausfeld this oil is per their book - (minus the Craftsman)
Don F
Sep 08, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
I have a 20 gal. 2 hp, twin cyl., model # 106.154781. What type oil does it take and I need air filters and a new drive belt.
Most aircompressors these days take non detergent 30 like an hd 30 gear oil , call sears they will have filters and belt
Aug 22, 2011 | Craftsman Air Tools & Compressors
I purchased a used Craftsman 2 HP 20 Gal air compressor, model # 919.176220. I'm looking for a copy of the user manual, Sears # SI-30-14-4-C. This item is no longer available from Sears.com and doesn't...
Since the exact model number manual is not available go to Sears and look at the compressors they have on the floor (or in the catalog). Find one that looks like the one you have and note the model number (these devices haven't changed much over the years). order the manual for the one that matches your machine the best.
Mar 22, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
I have a 3 gal. air compressor mod. 921.153101, what type of oil does this unit take use?
I am sure that Sears has there own oil they would prefer you use, If not a quality brand of SAE 30 is commonly used in these compressors.
Aug 25, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a Sears 3 H.P. electric 30 gal air compressor
This link will take you to sears web site, where parts are available. I have linked you to the parts list. If this does not take you there, go to www.sears.com and click on the parts direct tab and enter your model number.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=106.154880&productCategoryId=0703000&brandId=0247&modelName=CRAFTSMAN-TWIN-CYLINDER-TANK-TYPE-PAINT-SPRAYER&diagramPageId=00001&documentId=00001361&pop=flush
Oct 30, 2009 | Air Tools & Compressors
I have a sears craftsman air compressor 5hp 22 gal tank single cyl oil free it gets up to 70 psi does not shut off but will go no higher i cant find any leaks just bought it used guy used it to paint i...
The regulator and emergency release valve need to be checked. It should shut off once the PSI hits the target pressure. If the motor is staying on and the pressure never raises above 70 lbs, then air is escaping, either the emergency prv or a seal has blown
Sep 24, 2009 | Air Tools & Compressors
Pressure regulator gauge wont work on my 3 gal. air compressor how do i fix it or where do i get a new one (craftsman) i also lost my book , how often do i change the oil ?
If the regulator is inline you need de-energize the compressor to remove the regulator.
Sears parts and service:
http://www.sears.com/shc/s/c_10153_12605_Home+Services_Repair+%26+Maintenance?adCell=W4
Compressor Information:
http://www.sears.com/shc/s/c_10153_12605_Tools_Compressors+%26+Air+Tools
Wiki Buying Guide for Craftsman Regulators:
http://www.shopwiki.com/search/Craftsman+Regulator+with+Gauge
Sears / Craftsman Forum & Repair Information:
http://www.sears.com/shc/s/nb_10153_12605_NB_CSHome
3rd Party Regulator Retailer:
http://www.controlair.com/
If you feel that your problem is too serious for you to repairyourself, please contact a licensed/certified technician.
If you wish,you can call Sears HomeCentral at 1-800-4-MY-HOME tomake an appointment for a technician to visit. (There is a charge forthis service.)
Mar 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a craftman oiless air compressor model # 919153210 that I need parts for and sears do not carry the part anymore. thank you for any help., gcmac@netzero.net
Many of Sears oilfree compressors were made by Devilbiss. Try going to this address http://www.devilbissparts.com/ and enter your sears part numbers. (example cac-4281 for valve plate) They will most likely have the parts that you need. Good luck and email if you have other questions about your conpressor.
Feb 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
383 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
