Question about GPS
My auto cruise hyundai matrix can't work - GPS
Speedometer and cruise controll on2003 sonata stopped working ,and check engine light on
No speedometer or cruise control and a check engine light all point to the VSS(vehicle speed sensor) on the transmission.Take it to a parts store that does free code scans(like Auto Zone) to verify the code(should be P0500-P0503).Or,take a chance and just change the sensor.
Oct 25, 2012 | Hyundai Motor 2004 Sonata
Cruise not working in hyundai sonata 2000
Either the cruise switch you depress is at fault or the box withe the cables running from it to the throttle body is. It will need to be checked out if the fuse is good located in the fuse bos
Mar 27, 2010 | 2000 Hyundai Sonata
Can i turn the abs off on my hyundai matrix had to enter the product wrong caus it wouldnt let me post it as the matrix
if u want to turn off the abs light on dash will need to have car scanned for problem most auto stores scan for free fixing problem will reset trouble light ---if u want to drive with out abs braking system[really not advisable] u can pull the abs fuse which will give u a trouble light on dash and in some cases[dont know what year matrix u have] the brake light and if u have traction control that trouble code as well
Mar 07, 2010 | 2001 Hyundai Elantra
Cruise control not working sets but no cruise//
Go to Auto Zone for a FREE scan of your vehicles computer. It sounds like the vehicle speed sensor control (VSS) for your trans is bad. They will find out exacxtly what the problem is if so. The VSS is linked to your computer for the cruise as well
Feb 05, 2010 | 2003 Hyundai Santa Fe
I have a 2003 Hyundai tiberon SE. Recently the
the bulb is not working because the fuse is probably dead. (check by the drivers leg side for the fuse box). Door locks will not work because the alarm system needs to be repaired, or replaced. I donot know what to do with the cruise control. and your seatbelt sensors need to be replaced.
Nov 18, 2009 | 2003 Hyundai Tiburon
I have a 2006 Hyundai Matrix 1.6 GSI petrol. Automatic. When cruising at 4o mph it starts jerking and seems like it has a problem selecting the right gear. Also at around 60 mph it jerks when I accelerate.
My experience with Hyundai vehicles strongly suggests you have a bad TPS (Throttle Position Sensor). Replace it... see if that CURES it. (OR, you can have a qualified technician bench test it to see if it is defective). Your solution.
Oct 01, 2009 | Hyundai Motor S Cars & Trucks
How does the cruise control work and the automatic stick shift work in the 2005 hyundai sonata
cruiose control is a seprate system from if you raise the hood you ll see 2 cables going to your throttle body injection 1 will be for your foor peddle and the other for cruise control ther independent from each other as you electonically move the buttons the cable will adjust for speed of what you desire
once the brakes are applied the system will dissengage all together from the throttle untill its is activated again hope i was able to help you with that
not quiet sure on how you meanabout the auto stick shift
Aug 10, 2009 | 2005 Hyundai Sonata
Auto has 23K and cruse stopped working. checked
I had the same problem with my 2003 santa fe. Do you have any brake lights out in back? Weird as it is, as soon as I fixed a burned out brake bulb, my cruise worked again. The only relation I can think of is that tapping the breaks causes cruise to turn off - so maybe a broken brake/tail light passes a singal to cruise control from some reason???
Apr 07, 2009 | 2003 Hyundai Santa Fe
Cruise control stopped working in my 2004 Hyundai Sonata
This works...the cruise is directly tied to the brake lights...when I replaced the brake and side light bulbs on my 2004 Santa Fe,,,the cruise started working with no other adjustments. It must complete a circuit or something.
Sep 11, 2008 | Hyundai Motor 2004 Sonata
GPS Logo
80 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
