Question about Scientific Explorer Elmers Fizzy Foamy Science Kit By Scientific Explorer
I lost instruction guide of fizzy foamy science kit . i m unable to make experriment . it includes citric acid,baking soda, vegetable oil, baking yeast, 12 colors tablets
    New Friend:
We had this problem, too, but I found them! The company has moved around a bit, making them a little more difficult to find than a simple Google search.
Go here to download the instructions: http://poof-slinky.com/instructions/
Posted on Feb 23, 2014
Were you able to call the company to ask for the directions? We lost ours too. :(
Posted on Jun 05, 2011
Tip
How To Convert Vegetable Oil Into High-Grade Biodiesel Fuel
This tip will help you learn how to convert new or used vegetable oil into high-grade biodiesel fuel that can run in a standard diesel engine. Anybody can make biodiesel. It's easy, you can make it in your kitchen -- and it's better fuel than the petro-diesel the oil companies sell you. Your diesel motor will run better and last longer on your <a href="http://www.diversesolutions.org/detail/B0014FKHZ8">home-made fuel</a>, and it's much cleaner -- better for the environment and better for health.<br /><br /><a href="http://www.diversesolutions.org/detail/B0014FKHZ8">Biodiesel</a> has some clear advantages over straight vegetable oil, or SVO: <br /><br /> <ul> <li>It works in any diesel, without any conversion or modifications to the engine or the fuel system -- just put it in and go. </li> <li>It also has better cold-weather properties than SVO (but not as good as petro-diesel<a href="http://journeytoforever.org/biodiesel_vehicle.html#winter"></a>). </li> <li>Unlike SVO, it's backed by many long-term tests in many countries, including millions of miles on the road. </li></ul> Biodiesel is a clean, safe, ready-to-use, alternative fuel, whereas it's fair to say that many SVO systems are still experimental and need further development.<br /><br /><span style="font-weight: bold;">Instructions:<br /><br /></span> <ol> <li>Purchase a <a href="http://www.diversesolutions.org/detail/B0014FKHZ8">Biodiesel Processor</a>, such as the <a href="http://www.diversesolutions.org/detail/B0014FKHZ8">Fuelmeister II Biodiesel Processor available here.</a></li> <li>Follow the included instructions and you will be on your way to creating your own Biodiesel fuel!<br /></li></ol><br />Biodiesel is made from vegetable and animal oils and fats, or <b>triglycerides</b>. <a href="http://www.diversesolutions.org/detail/B0014FKHZ8">Biodiesel</a> cannot be made from any other kinds of oil (such as used engine oil).<br /> <br /> Chemically, triglycerides consist of three long-chain fatty acid molecules joined by a glycerine molecule. The biodiesel process uses a catalyst (lye) to break off the glycerine molecule and combine each of the three fatty-acid chains with a molecule of methanol, creating mono-alkyl esters, or Fatty Acid Methyl Esters (FAME) -- biodiesel. The glycerine sinks to the bottom and is removed.<br /> <br /> The process is called <a href="http://www.diversesolutions.org/detail/B0014FKHZ8">transesterification</a>.<br /><br /> <b>System Includes: </b> <br /> <ul> <li>Processor Tank and Stand</li> <li>Pump Assembly</li> <li>Oil Drawtube Kit</li> <li>Oil Titration Field Test Kit</li> <li>Operator Safety Kit</li></ul><br /> <b>Specifications:</b><br /><b><br /></b><br /> <ul> <li><a href="http://www.diversesolutions.org/detail/B0014FKHZ8">Biodiesel</a> Output: 43:5 gallons (max) per batch</li> <li>Mix Rate: 330 gallons per hour</li> <li>Operator: 1 1/2 hour per batch (typical)</li> <li>Tank Material: Chemical grade polyethylene</li> <li>Tank Stands: Welded steel frame with levelers</li> <li>Plumbing Materials: Chemical grade steel valves</li> <li>Processor Capacity: 55 gallons (maximum)</li> <li>Processor Size: 54" high x 26" diameter</li> <li>Footprint: Set up in a 30" x 30" space</li> <li>Shipping Weight Processor: 98 lbs.</li> <li>Shipping Weight Pump Assembly: 27 lbs.</li></ul><br /> <b>Other Features:</b><br /> <ul> <li>Handles most used vegetable oils</li> <li>Makes 2-40 gallon batches in 24 hours </li> <li>Industrial-grade materials</li> <li>Easy draining cone-bottom tanks</li> <li>90 minutes hands-on time after understanding the system</li> <li>Turbine pump blends and mixes</li> <li>Full-draining single tank system</li> <li>Special Modular Direct Catalyst Injection Lid (Patent Pending)</li> <li>Steel Methanol Pump</li> <li>Quick disconnect hose fittings throughout</li> <li>NEMA box with Solid-State control timer</li> <li>Steel valves No thru-tank ports</li> <li>Interchangeable Lid System</li> <li>Large diameter glycerol drain hose</li> <li>30" x 30" footprint, very compact</li> <li>Platform allows for modular upgrades</li></ul>
on Jan 14, 2011 | Kitchen Appliances - Others
Steam wont work on my coffee machine
If you've used the machine for awhile, and you have not cleaned/descaled it, it may be clogged with mineral deposits. Citric acid, a white natural mild acid is a good descaler. It comes in powder form and readily dissolves in water. You can locate citric acid on the web (ebay). White vinegar also works, about 1/2 & 1/2 with water. Run the solution through the machine to descale it. It may take a few treatments to get all the mineral deposits out. Use about 2 tbsp of baking soda in water afterwards to neutralize the acid.Hope this Helps!!
May 13, 2014 | Williams-Sonoma Saeco Intelia Espresso...
What is the most acidic fruit
lemons and limes have the highest level of citric acid as far as i know
Jan 05, 2014 | Cooking
How do you get Jalapeno Juice off hands it is burning????
Alternate your hands in two soaks:
1) Soak your hands in an acidic juice (Lemon, Lime, Orange, etc.) The acidity helps remove the oils from your skin. Try to work the juice onto your skin to help break up the oil layer. I usually keep my hands in each soak for a MINIMUM of five minutes.
2) Then rinse your hands with cool water, wash with a grease-cutting soap (I use Dawn).
3) Soak your hands in a baking soda mixture - 1 part baking soda to 3 parts water.
4) Rinse & wash your hands again.
Depending on how much oil you have on your hands, you may wish to repeat these steps a few times. If you do, it is important that you DO NOT reuse the soaks.....they will contain any of the hot oil they removed from your skin....reusing them just lets the oil get right back onto you, and defeats the entire process.
Wash out the bowls with a grease-cutting soap, rinse well, and then refill with the juice / baking soda mixtures.
Aug 16, 2011 | Health & Beauty
Lost instructions to mind blowing science kit
i bought the science kit but it wasn't have the guide in it can anyone write where can i find the guide?
Jul 30, 2011 | Scientific Explorer Elmers Mind Blowing...
I would like to clean off the calcium deposits that are in the dishwasher. How can I do this or what product should I use.
there are few things you can do to remove the calcium deposits.....
Change the detergent you use. Powdered dishwasher detergent is more efficient in removing grease and oil than gels. Decreasing the gunk left on surfaces may help slow lime scale buildup.
Put a quart of vinegar or lemon juice in the bottom of an empty dishwasher and run it up to the "dry" cycle once a month to keep up with accumulating scale. Extended exposure to mild acid and hot water dissolves most scale.
Clean circulator arms with vinegar or lemon juice and a vegetable brush or toothbrush. Let the acid sit on the scale before scrubbing. Use a needle or hat pin to pierce clogged holes, then rinse by running a cycle with vinegar.
Use plain salt or baking soda to scour surfaces with a sponge or rag. Rinse with boiling water or run a cycle with an empty dishwasher. Do not run the dry cycle.
  • 2 Put a quart of vinegar or lemon juice in the bottom of an empty dishwasher and run it up to the "dry" cycle once a month to keep up with accumulating scale. Extended exposure to mild acid and hot water dissolves most scale.
  • 3 Clean circulator arms with vinegar or lemon juice and a vegetable brush or toothbrush. Let the acid sit on the scale before scrubbing. Use a needle or hat pin to pierce clogged holes, then rinse by running a cycle with vinegar.
  • 4 Use plain salt or baking soda to scour surfaces with a sponge or rag. Rinse with boiling water or run a cycle with an empty dishwasher. Do not run the dry cycle.
  • Read more: How to Remove Lime Deposits in Dishwashers | eHow.com http://www.ehow.com/how_5611602_remove-lime-deposits-dishwashers.html#ixzz0wtABvYq2
    Aug 17, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
    Car won't start
    Take your batterie cables off the battery and clean them really good. the best way to clean a battery cable is to go and buy a box of arm and hammer baking soda for the .50 cents and what you do is put a small amount of water on the cables and then dump the baking soda on them and slowly add more water. Baking soda is the only thing that nutralizes sulferic acid. and if you ever get battery acid on your self you can use the baking soda to nutralize it and stop the burning and the eating of the acid. but it sounds to me that you are not getting a good connection at the battery and also check to see if your cables are tight.
    please rate me if you would and i hope this helps you out
    thank you
    aaron
    May 29, 2009 | 1998 Ford Windstar
    Brown residue from muratic acid fumes on stainless steel applianc
    Just a thought it may not work.
    Since Muratic acid caused the trouble try it to remove the stain. Then after its removed use baking soda to kill the acid and within 3 toi 4 hours re apply baking soda and re clean. Maybe do the cleaning 3 times just to be safe.
    I only say this because to remove oil you use an oil based solvent. Water use a water base solvent.
    So maybe ...
    Then again maybe not
    If this works or doesn't Id like to know.
    The last thing to use is a piece of aluminum tape to cover the area so its not brown.
    If this helped you please rate me accordingly and good luck.
    Mar 13, 2009 | Kenmore Refrigerators
    Scientific Explorer Elmers Fizzy Foamy Science Kit By Scientific Explorer Logo
    805 people viewed this question
    Top Scientific Explorer Toys Experts
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you a Scientific Explorer Toy Expert? Answer questions, earn points and help others
