You may have to use a Lionel transformer for this because some older trains worked on AC current not the DC current that this train uses
AC or DC isn't the actual problem here. The locomotive is three years old and the transformer, also a Lionel, is only about 2 or 3 years older. Of six locomotives, only one is exhibiting this behavior.
There's a circuit board on the inside of the locomotive that has triacs, diodes, resistors, transistors, and an IC on it that looks to be the issue, if not a solid symptom of the root cause. (The triacs are overheating)
If this were HO or N scale, I would suspect a DC / DCC problem, but I'm unaware of any Lionels that require the use of a DCC-like transformer. Do those exist?
it may be the IC or some diodes but if you have a mulitmeter check the resistance of the resistors test the diodes and then if those check out then it ma be some contact issues
