Question about Cameras
Dear Sir, Canon projector LV-7215 shows blue screen (and menus) - but not computer or video input. Optional Information: Make: Canon Model: LV-7215 Already Tried: Turning computer and FiOS box on and off cycling projector on and off only blue screen and menus project Please help as soon as possible because it is quite urgent. Regards, Chandrachur
  • Chandrachur Bose Jan 02, 2011
    Thank's for the great solution.I want to wish you a very happy and bright 2011.
  • Cameras Master
  • 4,924 Answers
Press the down left button ..and select the correct input for the mode you use..
the blue screen shows that you either do not have an input..or you didnt select the correct plug from the input button ..
after that use the settings to adjust the others..(from the menu button )
Posted on Jan 02, 2011
Canon lv-5220 multimedia projector flickering after start up
If it happens with no input hooked up then it could be the lamp. Or Worse.
Dec 05, 2012 | Canon LV-5220 Multimedia Projector
Our club owns a Canon LV-7240 which has worked OK. Last night we showed an NTSC DVD from Europe and no red showed. We could see what the colours ought to be on the laptop screen. On the big screen,...
Can't answer for the menu issues, but I can garuntee this is not a problem with brightness, contrast or sharpness, and very unlikely that you'll find a solution in the menu. What is likely is that the VGA wasn't plugged in properly initially. When the signal is going down the VGA it's broken up into 5 seperate signals, Red, Green, Blue and 2 sync signals. What is likely is that the green and blue pins havn't properly made contact either inside the projector or inside the laptop. This would also explain why it worked when you tried later because it made the connection properly. I would suggest trying again with the same laptop, if it does it again, try another PC without moving the projector or the VGA connector that's plugged into the projector. This will atleast narrow down your problem, but it doesn't sound like a problem with the projector to me. Also try plugging the laptop that wasn't working properly into a monitor (this will test the laptop)
Mar 25, 2011 | Canon LV-7240 Multimedia Projector
Can canon lv-53 projector run on USB....
MSRP (USD) : $1,299 Brightness (Lumens) : 1250 ANSI Contrast (Full On/Off) : 300:1 Variable Iris: No Audible Noise: 32.0 dB Weight: 2.2 kg Size (cm) (HxWxD) : 8 x 28 x 21 Std. Lens: Focus: Manual Zoom: Manual, 1.20:1 Throw Dist (m) : calculator.gif 1.3 - 6.5 Image Size (cm) : 86 - 508 Optional Lenses: No Digital Zoom: No Digital Keystone: Vertical Lens Shift: ** Warranty: 3 Years Performance: H-Sync Range: 15.0 - 80.0kHz V-Sync Range: 50 - 100Hz Compatibility: HDTV: 720p, 1080i, 1035i
575i EDTV/480p: Yes SDTV/480i: Yes Component Video: Yes Video: Yes Digital Input: No Computers: Yes Display: Type: 1 cm 3 LCD Native: 800x600 Pixels Maximum: 1280x1024 Pixels Aspect Ratio: 4:3 (SVGA) Lamp: Type: 160W UHP Life: ** Quantity: 1 Speakers: Mono Max Power: ** Voltage: 100V - 240V FCC Class: B Special: ** Status: Out of Production First Ship: Nov 2003 Last Ship: Mar 2006
May 08, 2010 | Canon LV-S3 Multimedia Projector
Hi there,there is a ring of blue dots
clean the lense of your projector, dirt or moist of water may be possible reason
Feb 18, 2010 | Canon LV-S3 Multimedia Projector
Canon LV-S3 casts a purplish cloud.
yes this happens all the time with lcd projectors, after a while lcd becomes distorted and bad,unfortunately you cant fix that (well thats what i know of anyway).
Jan 15, 2010 | Canon LV-S3 Multimedia Projector
Blue spot on screen
there are light filters at each of the 3 lcd panels in the optical engine with a coating on them that determine the color. one of them (most likely the blue) is burnt from the heat and needs replacement. it could also be the fly-eye lens (whick evenly distribute the light) has burned as well. either way, it's very involved to replace, if you can get the parts. it's easier to have it sent in to get repaired.
Jul 31, 2009 | Canon LV-LP11 Projector Lamp for LV-7345,...
Went out of town yesterday, hooked my canon 5210 up just like I always do, and got no response from the macbook. Luckily there was another projector available, and it worked. Seems to be the projector, not...
My problem didn't get solved, but my frustration was that I got a technician online two or three times, but couldn't post a response! The program wouldn't accept any input from the computer! So I was muted!
Jun 24, 2009 | Canon LV-5210 Multimedia Projector
Canon LV-S2 projector not work with component signal input
Try unplugging the projector. This seemingly works but I can't figure out WHY....
Mar 18, 2009 | Canon LV-S2 Multimedia Projector
Canon LV 7215 lcd projector: border is not black it orange brown colored and causes contrast problems with picture
Well, this could be attributed to settings, although if you've messed around with the settings for a while to no avail it could be another problem. Unfortunately, without much in the way of details, I can only make one suggestion.
It could perhaps be that your bulb has burn in. This happens with projectors over time, especially if a single image is left on too long (ie computer desktop or ppt borders)
I've also noticed that the lense can become burned as well, over time. Don't ask me how that's possible as I don't know enough about projectors to accurately guess.
Try cleaning the lense for starters, then consider replacing the bulb if that doesn't work.  You should take it to the place you bought it and they can tell you more concretely what the problem might be.
Caid.
Dec 30, 2008 | Canon LV-7215 Multimedia Projector
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
