Question about GE Dryers
My dryer was just moved from one location to another and now my clothes in the dryer are warm and damp. What could the problem be and how can I fix it?
    Top Expert:
  • GE Master
  • 9,472 Answers
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum. You may have dislodged some lint in the move.
Posted on Jan 02, 2011
Why are my cloths warm but slightly damp at the completion of all cycles selected.
Good Afternoon Friend,
I understand that your Frigidaire dryer is leaving your clothes warm but slightly damp. I will be more than happy to assist you. So I am able to better assist, I kindly ask that you provide me with the model number of your dryer. Typically, this number is located on the back of the door, or possibly around the edges where the door meets your appliance. Looking forward to hearing from you.
-WP-
Jul 09, 2014 | Frigidaire Dryers
The sensor on my dryer is not moving off the sensing over to wet, damp, dry or done. the dryer is heating but the sensor display does not seem to be moving. Model # wed6200sw1
In some cases this can happen, I have found by cleaning the sensor located inside the drum area with a rag and water or rubbing alcohol this will remove the residue from dryer sheet and should detect your clothes better. Over time the residue can build a barrier can cause this to happen. Normally this is a simple and quick fix.
Good Luck
Jul 15, 2011 | Dryers
My dryer is not heating the air clothes are rolling and air seems to be blowing but the clothes are damp when cycle ends and they are not warm. what do i need to fix this?
if the clothes are damp then I would disconnect the vent tube, and dry a load of clothes. If they are dry then the vent needs to cleaned. Hope this helps Tim
Feb 06, 2011 | Fisher and Paykel DEGX1 Electric Dryer
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
DRYER TAKES ALONG TIME TO DRY A LOAD OF CLOTHES IT HEATS TO WARM CLOTHES ARE STILL DAMP FOR AT LEAST 2 HOURS NOTHING IS CLOGGED IN THE VENTILATION LINT CATCHER IS CLEAN HELP!!
You may have a blower which is not circulating enough air flow. You can have heat and no blockage but a blower whcih is not moving enough air to distribute the heat and displace the moisture filled heat to the exterior.
Mar 17, 2010 | General Electric DBXR463EG Dryer
The Dryer runs forever and the clothes dont dry
there are two elements on the back wall of the dryer and if one goes it will still get warm but not to dry all the way and will not trigger the heat sensor to finish
Dec 12, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Damp clothes,
sounds like you have a restricted air vent check for air output on the outside of the home vent and check behind the dryer to ensure not crushing the vent at that location
Sep 02, 2009 | LG DLGX7188 Gas Dryer
Clothes only warm and damp after an hour
try checking to see if the vent is plugged up, this includes the lent catcher the hose and the outside ait vent.
Jun 26, 2009 | Dryers
Kenmore 70 series electric dryer. Clothes are
most common reason for this would be clogged vent...check all the way in and out!
Mar 16, 2009 | Dryers
Clothes Hot but damp, water out of vent
Is this a combo washer/dryer in 1 unit? water shoud not come out if it is just a dryer. Your air coming out of the back vent hose should be hot. If your clothes comes out of your WASHER damp (more than normal) then your washer is not spin drying good enough. (worn belt, clogged drainage system).
Jan 09, 2007 | LG DLE2532W Electric Dryer
Dryers Logo
37 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
