Question about Hampton Bay 73554 Antigua Ceiling Fan
How do you reverse the blades when there is no switch on the fan itself.
  • 1,557 Answers
There should be a switch on the motor try taking of the cover (make sure power turned of )
Posted on Jan 02, 2011
Testimonial: "Fast response."
  • etcwest Jan 02, 2011
    Thank you.
  • sonic boom electronics
    sonic boom electronics Jan 02, 2011
    your welcome please remember to rate the advice were it says did this help
5 Suggested Answers
SOURCE: Reversing blade direction
change the connection of your capacitor.it runs in different direction.
Posted on Jul 07, 2008
SOURCE: reversing direction on remote controlled fan
There is no switch. Put the fan on high then hit the reverse button. Your fan should stop, reverse and you'll bet all set.
Posted on Nov 30, 2008
tbirdfan1
  • 3051 Answers
SOURCE: I have a ceiling fan that the blades are in
Helo there:
providing that this has that capability the switch will be on the side of the housing of the fan or on the very top. ok?
best regards mike
Posted on Aug 15, 2009
  • 351 Answers
SOURCE: Motor Humming but blades not running
Hi m.. if this is a new installation, look up at the area where the blades attach and be sure that you have removed all the black rubber packing stops. If this has been running and now does not , then you probably have a bad capacitor on the motor.
Posted on May 04, 2010
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
I am working on an antique fan and for some reason when i fiinhshed, the fan was running backward? What did I do?
Some ceiling fans have a switch mounted on the fan itself for changing the direction of spin of the blades. Look up at the fan and you might see a switch on it which you can change.
Aug 31, 2011 | Emerson Dryers
Hi I need to know if I can switch the direction my hunter green Lasko fan is turning it is going clockwise and I would like to reverse it for the summer can't find a switch we've have it for...
Turn the fan off. Locate the reversing switch. It is on the base of the fan near the fan speed and light switches. if its not on the remote control. have a good day !!
If it does not have a revesing fan switch and its older, You may have to physically(with fan stopped)
Push blade in from end and twist blade for reverse air.
Jun 22, 2011 | Hunter Traditional Southwest 52" Ceiling...
Our fan is going in the reverse direction...how do we switch it?
mcdevito75 here, Generally, The Fan switch itself is a pull chain type switch on the fan motor itself, this is a fan speed switch, NOW! also generally the reverse fan swtich is another shorter pull chain switch just about an inch away from the Fan Speed switch or the longer pull chain switch on the fan motor. This reverse switch can also be a toggle type or slide type switch but will be close to the fan speed switch on the fan motor itself.
Jul 18, 2010 | Monte Carlo Dryers
How do I reverse the blades without a remote?
theres a black switch around the fan to change directions , thanks AJ
Jul 14, 2009 | Dryers
I cannot reverse the fan blades
look for a small slide switch around the body of the fan. most fans have a small switch to reverse direction.
good luck....jay
Apr 22, 2009 | Air Cool AC436-GB Fan
How do I reverse the direction of the fan blades to counter-clockwise on the fan? The fan is a Hampton Bay ''Clarington'' with a remote control.
There is a small black switch on the switch housing directly under the blades. When the fan is completely off, move the switch to the opposite direction.
Mar 31, 2009 | Universal Remote Control Hampton Bay...
Hampton Bay-Parisian II, 54" ceiling fan, model 670-760
I finally found the switch. It is on the motor. No dismantling is required. It is hard to see, feel around, it is where the blade holders start to curve.
May 09, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 73554 Antigua Ceiling Fan Logo
290 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
