Hi guys I got a toshiba sdv398kc2 for Christmas and have just hooked it up to my TV. I need to do the initial setup before I can play DVDs or VHS tapes which involves selecting the language, and an auto setup. I can't get the menu or any other setup information to appear on my screen. The remote appears to be working because I can get the power to go on and off. However, I press Menu or Setup and nothing happens. Any idea what I could be doing wrong?
  • Mark Carey Jan 02, 2011
    How do you have it hooked up?
SOURCE: Frozen digital screen
Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Posted on Jan 28, 2008
dsacco86
  • 1077 Answers
SOURCE: Setup Menu Appears Each Time I Turn On TV
The software of the TV might have been corrupted somehow. A problem that may have come strait out of the factory.
Most of the New Sharp TVs have a software upgrade port. In your manual, it will describe on how to do it. Best to call the number on the software upgrade page and tell them what happening. That way, they can get you the right patch or software to fix the problem.
Posted on Jun 21, 2009
  • 8457 Answers
SOURCE: Toshiba 23HLV85 LCD TV/DVD inverted image
Yes,Ur main Tuner board have problems,the ICS on the board is not coverting.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Posted on Apr 14, 2010
SOURCE: Pioneer PDP-6020 FD, Menu items grayed, no HMG after firmware upd
I have the same issue - Pioneer told me the local repair shop could reset the firmware, I paid the $90 service call and they could not fix anything. For a 18 month old $5000 TV they now want me to replace the digital board for around $500.
Posted on Nov 24, 2010
BElectric
  • 1140 Answers
SOURCE: I recent purchased a
There is always a possibility of getting a lemon when you buy any new electronic device, but I hope this is not the case here. From what you describe, it would appear that the channel scan is not finding anything and the TV is stuck in installation mode. There are several possible reasons why this could happen, but let's start with the 2 most common ones first:
- The devices are not connected correctly meaning there is no signal to the TV;
- The wrong scanning option has been selected;
I thank you for providing such a detailed description but I'm going to need some more information from you to solve this problem. Specifically, I need to know:
1. What is the signal source for the TV? (antenna, cable, satellite, etc)
2. How are all the devices interconnected? Basically what is connected to what else.
3. Model numbers of the TV and Shaw PVR
4. Any other detail which may be relevant - types of cable used to connect the devices, etc.
Please reply to me from within this page with the information requested and hopefully I will be able to solve this problem for you fairly easily.
In the meantime, if you are using a cable/satellite receiver or digital converter, try connecting this directly to the TV and scan again. It would be a good test to determine whether the TV is working and therefore something is wrong with the setup.
Thanks,
BElectric
Posted on Jan 31, 2011
I cannot get it to record a vhs tape to a dvd. The vcr will play tapes and the dvd player will play dvds. I need some one to walk me through what buttons to push to record.
You need a remote to setup the dvd record and vcr record. Then you have to do dvd initialization perhaps before you can dub from tape to dvd?
Dec 20, 2010 | Toshiba DVR610 DVD Recorder/VCR
Our new Toshiba SDV398KC2 will not play a DVD. It is like it is on the wrong channel. It shows the DVD playing with the counter but does not show it on the TV. Can you help?
I've seen this behavior before.
For this model, I *think* that you need to use the component connections/input in order to view the DVDs. If VCR shows ok when using the cable, but not the DVD (and it seems to work since it goes up as if playing), try to connect the component (blue/green/red connectors) and it should work.
Don't forget to switch input on your TV to component.
P.S. If you have HDMI on both this dvd/vcr & your TV, it should work with that too.
Nov 18, 2010 | Toshiba SD-3980 DVD Player
Hi I have a Toshiba TV/VHS/DVD combo. I would like to program my comcast remote control to play dvds and vhs. How do i do that?
Sure you can click on this site, Select your remote from the list and download the manual on how to do that.
CLICK HERE FOR REMOTE MANUALS
We sure hope this helps please do not forget to leave a rating.
Aug 19, 2010 | Toshiba MW24FM5 24 in. TV/VCR/DVD Combo
I can play dvds but not vhs. how do i hook it up or program it, etc, so I can watch vhs?
Hi dave
To answer your question;
In order to watch both the dvd and vcr on the same tv input , you need to use the dvd/vcr output of your jvc.
The component output is for the dvd only.
So if you want to keep the component output for high definition when playing a dvd you can connect another rca cable from the dvd/vcr output of your jvc to another input on your tv when playing vhs.
If you want the owners manual online you can find it HERE
You`ll find all the info on page 11
Hope this help Good luck
Apr 27, 2010 | JVC HR-XVC19S DVD Player/VCR
Toshiba DVR620KU error E 25 cannot put VHS onto DVDs
Probably copy protection.
You can remove it with a Grex or similar
device.
Jan 08, 2010 | Toshiba DVR620 DVD Recorder/VCR
I can play DVD's but not VHS tapes. I hav checked all connections and several tapes to no avail. Thank you ! Ol' Fred
Hey Ol' Fred...
One of my good friends is an ol Fred so I felt compelled to stop in and help!
I'm not sure of your setup, but if you've got a combo DVD/VHS unit, make sure that you have out puts to the TV for Both parts separately... You can designate by accessing the TV's onscreen menu and setting up a separate source for DVD and one for VHS. I've found on my projection TV that it's best to use the Coax cable connections for the VHS to TV.
Then once it's setup with separate hookups to the Tv, you should have audio and video for VHS...
k
Dec 18, 2009 | Televison & Video
Can't see dvd on TV
how to hook up to watch dvds
May 25, 2009 | Sansui VRDVD4005 DVD Player/VCR
Toshiba 26AV502U (new) video dropout if VHS tapeis not perfect
Had problem checked by local outfit called "Circuit Pro"; their analysis was compatibility.
Actual answer was that the Toshiba required a better quality input from "any" VHS source.
I finally took a "less than perfect" VHS tape with me when I returned the Toshiba TV to the store and demonstrated the problem to one of the TV sales people. He played the VHS tape through a display VHS/DVD player to three different brands of TV. The picture was often "black screen" on a Toshiba, but was merely poor quality on the other two brands. I upgraded to a Sony KDL26M4000 from the Toshiba 26AV502U.
Dec 03, 2008 | Toshiba 26HF84 26" TV
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Toshiba MW27F51
It is not clear whether one DVD or all DVDs play in black and white. If it is only one make sure that the format of the DVD is correct. If it is all DVDs, given that the VHS tape and cable play with color, there could be a problem with the chroma circuit in the unit. This is probably something that a technician would need to diagnose. Good luck.
Jun 30, 2006 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
