Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Colors are not sitting properly and picture is bowed
  • 1,557 Answers
I have been a tech for 26 yrs now i have seen so many postings on here about bulging caps and so on but there is only 1 thing to do our workshop has 18000 dollars in test equipment alone there is a great reason for this the amount of vereables that can go wrong with nano electronics there is no easy fix to this problem it needs to be seen by a certified electronics tech this is your best chance of having this tv fixed correctly im not putting down other techs on this site but some things we can fix by computer network some we cant imagine even if this tv was in my workshop right now it would take us over an hour just to find and fix the cause
i hope this helps you sir/mam
sonic boom electronics australia pty ltd.
managing director
Posted on Jan 02, 2011
3 Suggested Answers
  • 68 Answers
SOURCE: Picture bowed & Colors separted
Conversions are out....RCA>>>>>>>>>>>>>check
fuse by the flyback transformer
Posted on May 19, 2010
Ecollier2012
  • 3459 Answers
SOURCE: bowed picture colors off
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jun 06, 2010
May 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony 46 inch proj tv picture is bowed in the middle and color is
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Bowed picture and color misalignment
Replace both STKS ICs Ck low ohm resistors 2.7ohms most of the time there will be 2 of them bad.
Jun 11, 2009 | Samsung HCN5527W 55" Rear Projection...
Picture bows in towards middle
YOU HAVE A ALIGNMENT PROBLEM, ON YOUR BOW OR PINCUSION, OR A BAD RESISTOR, THE COLORS NOT LINING UP COULD BE A CONVERGENCE PROBLEM. I ADVISE YOU TO LET A EXPERT TO THIS DUE TO THE HIGH VOLATE ON THE CRT(PICTURE TUBE)
Jun 07, 2009 | RCA Televison & Video
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Green color convergence
make sure you hooked everything up properly and that all connections are tight
Aug 26, 2008 | JVC AV-56WP74 56" Rear Projection...
TV-Bowing
can you post a pic of your screen so i can properly diagnose the problem as it could be either a pincushion or convergence problem. A picture would clarify it for me.
Apr 16, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Picture is bowed and color is way off
i Would look for a loose connection around the convergence area.
Jan 21, 2008 | Zenith R49W36 49" Rear Projection HDTV
Covergence and Bowed Picture Problem
can you adjust any color of convergence in user menu blue, or red up or down left or right. if you can make any up or down left or right adjustments on any color then the likelihood it wont be a convergence ic. it would be a output resistor. so see if you can get any movement. with it being bowed i was suspect an convergence ic.
Jan 08, 2008 | RCA P60920BL 60" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
351 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
