Question about Mitsubishi WD-52528 52" Television
After replacing lamp tv screen or sound will not come on. yellow light is blinking but was also blinking when took the broke lamp out.
  • 1,557 Answers
I have been a tech for 26 yrs now i have seen so many postings on here about bulging caps and so on but there is only 1 thing to do our workshop has 18000 dollars in test equipment alone there is a great reason for this the amount of vereables that can go wrong with nano electronics there is no easy fix to this problem it needs to be seen by a certified electronics tech this is your best chance of having this tv fixed correctly im not putting down other techs on this site but some things we can fix by computer network some we cant imagine even if this tv was in my workshop right now it would take us over an hour just to find and fix the cause
i hope this helps you sir/mam
sonic boom electronics australia pty ltd.
managing director
Posted on Jan 02, 2011
    New Friend:
  • 90 Answers
If you touch the glass part of the lamp it wont work
Posted on Jan 03, 2011
Blinking code 3 2. will not turn on
error code 32 indicates the lamp cover is open, you might also check that lamp cover switch.
Mar 15, 2015 | Mitsubishi WD-60737 TV
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Blown lamps
Possible heat issue. Check for fan operation and any dust build up.
Mar 11, 2014 | Mitsubishi WD Televison & Video
Toshiba 56hm66, lamp replaced but lights still blink
Check the circuit boards to see if any have failed. They are small cylindrical objects. If the tops of any of these are bulged instead of flat then they are bad and board will have to be replaced. Hope this helps.
Jan 03, 2014 | Televison & Video
I have a Sony WEGA KDF-E60A20 TV. When I turn on the TV, it will stay on between 30 sec to a 1min. Then the screen will turn black and there is no sound. After about a minute, the TV is back on with...
Hello.
It looks like you have to replace lamp in your TV. Read owner's manual for info of how to do it. It is not very complicated. Lamp have to be replaced every 2.5 years of average use.
If you will still have same problem after lamp replacement you will have to replace lamp ballast as well, because your old lamp was long overdue and could inflict damage on it. It is not very probable and there is no way to know it for sure without replacing lamp first.
Regards.
Russ.
Dec 01, 2010 | Televison & Video
The screen goes black, power light blinks with sound on, then screen comes back normal and so on.
This symptom of weak lamp that has reached its end of working life and will be dead/ broke any time.
If lamp has not been replaced in tv since last 2-3 years then it is time for new lamp in tv to fix this issue. lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good quality picture.
Let me know if you have additional question.
Thanks.
Nov 05, 2010 | Sony KDS-55A2020 55" Television
I have a Sony 50" WEGA rear projection tv. Last night it made a popping sound and then the screen went black. I could still hear audio at that time. I turned the tv off and now there is a blinking red...
It sounds lamp in tv got broken as you heard pop sound of it, replace lamp in tv to fix the issue.
Blinking light would be Lamp light at tv front that shows lamp is dead.
Lamp replacement procedure is easy and mentioned in tv user manual.
Thanks.
Sep 13, 2010 | Televison & Video
Lamp trouble
It sounds lamp is getting weaker and TV needs new lamp.
Please intimate model and brand of your TV to find further helpful info.
Thanks.
Nov 13, 2009 | Televison & Video
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Tv doesnt turn on after replacing lamp??
Just took a look at the manual.
This information is in the troubleshooting section of appendix H in the owners manual.
12. Lamp indicator light is a flashing yellow. Lamp cover door is open or lamp cartridge is not secure. See AppendixH for lamp replacement information.
Appendix H is a bunch of graphics. that you'll need to see to understand. i can't paste it all here.
Oct 31, 2008 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WD-52528 52" Television Logo
219 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
