Question about Haier HWR08XC5 Thru-Wall/Window Air Conditioner
My remote has stopped working and I cannot change the settings on unit itself
  • 2,133 Answers
Normally in many units there is no manual button in a/c itself. It's advisable replace with new remote and operate it.
Posted on Jan 02, 2011
Panasonic DMR-EX88 recorder was working fine but remote has stopped working so cant get to the hard drive (can still play a disk by pressing play on the unit). Remote started working intermittently, now...
Either the remote itself is exhibiting strange behaviour, or the unit's IRD controller circuit (and/or the IRD itself) is faulty. Perhaps when you changed the batteries, the remote needs to be 're-commanded' (that means entering a remote code by pressing and holding 2 buttons together for 10 seconds - example - 1 + ENTER/OK) - this should be done whenever the batteries are replaced. If this does not restore the remote to full control, then the IRD (and/or its controller circuit) is the most likely suspect; or, worst case scenario; your remote is defective. I hope it isn't the latter.
I suggest you submit the unit to an authorised service centre for a quote (since this is not a disc drive replacement/alignment it shouldn't be too expensive) then you can decide for yourself afterwards as to what further action to take. Up to you, it is not unfixable. You can always ask Panasonic directly for straight answers and get a second opinion at the same time.
I hope you do not need a new remote at this stage.
Apr 01, 2011 | Panasonic DMRES20D DVD Recorder
I am unable to click on features on the Tv. I changed the batteries and nothing happens as per a connection. # rm-yd016
IR REMOTE programming error Please take these actions before we try yet another universal programmable remote 1. Clean the IR screen on your tv set. It will often appear clear in view with a reflective window which often has a black, blue, or red tint to it 2. Clean the same window on the programmable remote 3. From tons of experience, I've noticed that Sony tends to provide the most compatible remote for replacements 4. Please confirm with me which codes your attempting to use when programming, and type /model number of the universal remote 5. Keep in mind that the remote that does not work as a replacment may very well be exchanged 6. Only use approved batteries for your remote and keep in mind that rechargeable batteries account for 50 percent of electronic errors 7. If your old remote simply stopped working for no reason at all, then we may have a communication problem with the tv combo set itself. 8. Ensure that the tv set is ready and able to receive a signal by setting it to the factory defaults within the settings menu 9. If we know why your older remote simply stopped transmitting the signal, we will acheive a must faster solution 10. Please attempt a fresh set of batteries in the older remote to determine the root cause behind the transmission problem 10. Check your power cord for crimping, dents, or pinched underneath unit. Each of these activities will cause power to stop transmitting to your unit 11. the digital display is not popular for having problems. 12. Ensure that you press the power on button on the digital display firmly at an attempt to power the unit on. 13. If you still have not recieved power, we will continue to troubleshoot the internal portions
Jan 27, 2011 | Sony The Miracle Remote for TV Remote...
I accidentally changed the command code from dvd3 to dvd1 and now my remote doesn't work, and I don't know how to access the systems menu to change it back.
Since unit has been set on DVD1 remote mode so you need to set remote control itself on dvd1 mode to communicate with unit.
Press and hold Enter and 1 numeric key on remote control for 5 seconds, this will change remote control to dvd1 mode, now unit will accept remote control signal and you can operate it normally.
Thanks.
Jan 02, 2011 | Sony RDR-VX535 Player
I have a conia YKR-F/06 air con & my remote wont work, can u turn it on from the unit itself?
Some units having manual button in unit itself. But you can't change temp setting or mode setting by that. It's advisable to get new remote and operate this. Thanks.
Dec 31, 2010 | Heating & Cooling
AOC Plasma TV turns on by itself and changes channels non stop.
I have an AOC 32" LCD HDTV and it turns on by itself as well. Tuning is done via my cable box, so the tv is set on HDMI and I don't have the channel changing issue. I as well am trying to figure it out. The only thing I could suggest is perhaps the remote batteries are low and triggering on it's own. Try changing the batteries, or ensure that the remove it in a drawer or other room so that triggering the unit is impossible. Hope that helps.
Jun 17, 2009 | AOC A42HD84 42 in. Plasma HDTV
Cant get the Unit to respond to the remote control
My remote won't work. It will work once, maybe twice and then no response from it. New batteries, haven't dropped it, etc.. HELP !!
Aug 19, 2008 | Audio Players & Recorders
I purchased a 7000 BTU portable airconditioner by commercial cool for Haier. I set it up without an issue and was able to turn it on and utilize the remote control to go through all the settings. A...
There may be a master reset switch or combination of buttons to press. The Manufacturer may be able to walk you through this process. Otherwise I would simply exchange it. It sounds like it has a manufacturing problem.
Jun 16, 2008 | Heating & Cooling
Hitachi onscreen menu access
Afraid only the original remote will fix this. All universals and aftermarket remotes will not have the function you need. try going here www.vancebaldwin.com and use there remote finder and see if they have the one you need
Feb 26, 2008 | Televison & Video
Haier HWR08XC5 Thru-Wall/Window Air Conditioner Logo
87 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
