Question about Pioneer PureVision PDP-4304 Television
Wont turn on and both green and red led lights r on indicating on and standby at the same time
SOURCE: Does not turn on.
i had my power supply blow on mine within the first year took it in because i had extended warranty and they fixed it, only problem was finding a dealer in my area to fix it, then took over a week, because of customer support issues
Posted on Nov 04, 2007
  • 35 Answers
SOURCE: phillips plasma wont turn on power light goes
need to replace caps on PSB. email for instruction and pics of what to look for. gysgt2u1@yahoo.com
Posted on Mar 21, 2009
  • 41 Answers
SOURCE: wont turn on
The error code of 2x red flashes tells me you need a Y DRIVE ASSY and the part number is AWZ6649. It should be replaced by a Technician thou.
Hope this hleps
Posted on Mar 30, 2009
  • 41 Answers
SOURCE: wont turn on red light flashes
Hope this hleps
SvenBosch
  • 3 Answers
SOURCE: my power light on hitachi lcd is flashing red and
Sadly to the end I can now explain the "problem" of my question by myself ...
Because I'm was not sure if I can handle the "problem" by myself I gave the Screen to a technican at our City with all the Information I found until this point (By the way my suspicion was the defect of something at the power supply unit). Two days later he gave me a call with the information about the error: An error at the power supply unit - spare parts => 50€, Work => 200€).
Unhappily im not yet got at soldering on screens, but for 250€ i would have made a good course for this (and if I can establish i will learn it).
So now again a bit more objectively:
Error / Problem:
TV - Step 1: Power Off
TV - Step 2: Stand-By
TV - Step 3: Power-On
TV - Step 4: Short flashing picture
TV - Step 5: Reverse to Step 1
Solution:
1. Find the defect Fuse/Safe/...
2. Buy the Spare part at eshop2.euras.com
3. Change the parts -> et voilá
Hopefully I could have been a little help for someone.
With kind regards,
NatureOneFreak
Posted on May 30, 2009
Sony lcd red blinks 6
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 23, 2014 | Televison & Video
RAPOO h6060 led is always red
Hi Bando
Just want to ask, have you accidentally dropped this head set? if not then lets make it this way.
Now the time that this headset still working or responding normally..
- the time that you use this headset what was the color of the led? is it red,green or blue?
- normally led red light indicates standby mode,
- how would you know that your headset is in fullcharge? is there an indicator?
Jan 27, 2014 | Rapoo BLUETOOTH STEREO HEADSET H6060 WHITE
Wont turn on red blinking light
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 19, 2013 | NEC PlasmaSync 42MP4 42 in. Television
No pic or sound. the stand by light blinks green then the lamp light blinks red untill it turns off all toghther. the lamp is broken i just want to know if that is the only problem or if the driver may...
Flashing green standby led light at the front panel is an indication that the unit waiting for the lamp to turn on. Since the lamp led light flashes, the unit sensed it already burned out.
Faulty lamp driver has a different error code which is "flashing of the standby light 5 times".
Your unit will back to normal operation again after the lamp replacement.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 22, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
The green power light wont turn on. the red light is on. pushing the remote power and manual power do nothing to turn box on.
Red LED light is an indication of standby mode only. It means you haven't a hight voltage that's why your tv will not power on and the green LED is dead also.
I've advice you to look for a qualified technician because you have a faulty parts on your low voltage power supply mainly on the regulator section. It is quite technical so you need an experts to isolate the faulty parts on the board. Your set also need to resolder for some dry joints because it is also one of the caused why some parts are damaged.
Thanks for using fixya!
Jan 05, 2011 | Televison & Video
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
The "on" light is always green, even if turned off. Why?
It occurs when your wii in the Standby, but WiiConnect24 is enabled with Standby Connection is enabled. the content can also be received when the Wii is left in standby mode.
WiiConnect24 can be turned on or off via the setup setting. While the console is in standby, the power LED indicates the current status of the standby connection,
  • Red indicating Standby - wiiConnect is off,
  • Yellow indicating Standby - Connect mode is on. If you hold the power button for 3-4 seconds, the Wii goes into standby mode with Standby Connect off. and WiiConnect24 will not operate until the console is turned on.
  • Green ...
Jan 18, 2010 | Nintendo Wii Console
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Pioneer PureVision PDP-4304 Television Logo
43 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
