Question about Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe (Trevi)
Hi, the Saeco I have is the Trevi model that is the same model as the Vienna De Luxe. When I turn the machine on, the only green light that is on is the power light. There is no action, and not even a noise. I will appreciate if you tell me what it can be. Thank you! Mike
  • mzgam Jul 10, 2008
    Hi Mirran,
    I tried what you suggested me, and the pump does not start. If you have any other suggestion, please let me know. Thanks for the help!
    Mike
  • 515 Answers
Hi Mike,
Try to open the steam knob to see if the pump is starting.
Posted on Jul 10, 2008
  • Mirko Blas
    Mirko Blas Jul 11, 2008
    I think your power board is the problem:-(
Saeco Trevi leaks from "inside"
What can have happened is that through an overflow of used coffee the hole in the back is stuffed with the ground used coffee. The way to solve this is getting out the brewing group and rinse the hole with water after removing the cloggin coffee residu. You can find this hole just beneath the outgoing axle.
Mar 05, 2009 | Saeco Vienna De Luxe Espresso Machine
Resevoir leaking on Saeco Trevi(like Vienna)
There are no screw to be removed, you have to take off the plastic ring in the water inlet. Take a screw driver and set it between the chassis and the water inlet.
Hope this will help you.
/Mirran
Aug 21, 2008 | Saeco Vienna De Luxe Espresso Machine
Contact Saeco USA and see where they have a local service for Saeco.
Saeco USA Inc.
7905 Cochran Road Suite 100
Glenwillow, OH 44139
Tel. 440-528-2000
Fax 440-542-9173
E-mail: info@saeco-usa.com
Visit the Web: www.saeco-usa.com
/Mirran
Aug 17, 2008 | Saeco Vienna De Luxe Espresso Machine
you have to replace the gasket in your water inlet, if you look where the inlet is you will see there are a little gap between the chassis and the inlet.
Take a screwdriver and bend up the plastic, you will now see the gasket.
The gasket have spare part number: 145842900
/Mirran
Aug 16, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Vienna de luxe saeco
I look at the picture and the hole should not be there. You have to replace the boiler:-(
Jul 28, 2008 | Saeco Vienna De Luxe Espresso Machine
SAECO TREVI NO HOT WATER
It would be cheaper to check the thermostat and heating element first and the wiring continuity, although I am not sure if you can find the replacement parts. If you can't, then it looks like you have no choice but to replace the entire assembly.
May 19, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
178 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
