Question about Tivoli (PAL) AM/FM Radio
Hello, I have a new battery but it does not seem to hold it' s charge. With battery or with charger the radio goes off in 30 -45 seconds. Do I need to send it back to Tivoli for repairs? Betty C.
  • 1,557 Answers
The battery is not being charged send it back to have its charging lines fixed
Posted on Jan 02, 2011
It doesn't seem to keep the charge. does that mean I need a new charger or a new headset?
Sounds like the battery is not holding its charge.......you can rejuvenate the battery by fully charging and then fully draining til it goes off either by leaving on or using! Doing this a few times will allow the battery to fully charge and hold the charge better!
Feb 04, 2015 | Radio Communications
I put new batteries in my Cobra 2-way radios and charged them for 24 hours. Still shows "low battery" when I turn them on.
Check your charger and battery contacts. Cleaning battery contacts on the radio and charger with a pencil eraser will remove dust, dirt, debris, and hand oil which may cause the battery to charge poorly. Secondly, you might want to check that your charger itself is working properly. If you have a second known good radio you might try charging it on the same charger.
Best regards.
Sep 28, 2014 | Cobra Radio Communications
Changed the battery in my 2-Way Radio CLS1110 and it will turn on but when you push talk it goes off
The battery is bad or not charged. Check your charger and charger/battery connection. Clean all contacts with a pencil eraser and try charging again. With a new battery it may take up to 3 charge cycles to fully charge your battery.
Best regards.
Jan 20, 2014 | Motorola CLS 1110 (1 Channel) 2-Way Radio
The low battery light remains on after I changed the battery,
Hello
There are two possibilities for this fault. The first one is with its battery itself. If the battery did not hold current, in otherwords, it has weak, proper charge both in volts and amperes won't hold on it, and when the device draw current from it while it works, voltage drop will occur, and low voltage indication will be displayed.
The second chance is due to the charger circuit inside the radio. If charger circuit do not give proper voltage and current to battery, the battery won't charge to its full capacity.
Check it by replacing it with a new battery [batteries] first. If it helps you it's OK. If not, your radio need service, and its charger circuit must be checked well. OK.
Nov 15, 2011 | Emerson CKS2237 Clock Radio
Trouble charching battery, after 6 houres only one bar on battery . Charging will not complete.
1 charger
2.battery
3.charging port
There are three ares to look at,
There are three different things you can try to determine the real problem of your phone, firstly, try use a similar charger to charge the phone to see if it will hold charge, if it does, it means your charger is bad, get a new charger. secondly, another area you will need to look at is removing the battery on your phone and charging the battery of your phone with a similar phone to see if the phone will charge the battery and hold charge, if it did not, it means the battery of your phone is bad and will need to be replace, lastlt, check, the charging port of your phone might be malfunctioning and not charging your phone, if the two above look good, it means the charging port is the problem, replace the charging port and you will see that your phone will hold charge.
Take care.
Jul 05, 2010 | Motorola Mobility RAZR V3
My phone is not holding a charge. It seems completely dead, and when I try and charge it it flashes sporodically and vibrates for a second or two before dying again
When your phone tries to come on and goes back off after vibrating for a second or two.
This is due to the fact that the battery is completely dead and is trying to pick up when you plugged it to the charger.
Try to charge the battery of your phone in another phone before fixing it back into your phone.
turn it on before trying to charge it again.
make sure the battery never runs out before you charge it back.
take care
Jun 12, 2010 | Sony Ericsson K850i Mobile Phone
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Apr 14, 2010 | Sanyo PM-8200
Charging problem
there is nothing wrong with your charger. The problem is from your battery.
The battery cell is very weak, such that it does not have the ability to with hold power for long.
Therefore, get another battery and the problem will be resolved. But make sure you charge the new battery till its full before you start using it.
Take care.
Mar 10, 2010 | Nokia N70 Cellular Phone
No charge
Here are a few troubleshooting thoughts:
1) Check your charger contacts for film/debris. Use a pencil eraser to clean them. (This can be done on the charger and the battery.) If the charge light comes on and stays on consistently you know you have good contact.
2) Be certain your radio is shut off when on the charger.
3) New batteries sometimes need initialized. It will sometimes take 3 or more chargings to fully charge the battery. Check the date code of the new batteries to be certain what you obtained is truely new/fresh. Contact the vendor where you purchased the batteries and let them know of your difficulties in charging the new batteries.
Mar 13, 2009 | Motorola For MT2000 HT1000 HT6000 GP900...
Tivoli (PAL) AM/FM Radio Logo
695 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Electro Med Services...
KC135Nav
Level 1 Expert
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
