Have a dp32640 but cant get any channels after channel scan...shows 0 channels...do i need an outside antenna?
  • Mark Carey Jan 02, 2011
    Do you have the tv set for broadcast or cable?
  • 1,557 Answers
Yes the tv is telling you it either has no signal or bad input in most areas now you need above 33mhz to receive a reception on tv
Posted on Jan 02, 2011
How to reset channel auto scan.After I finish channel scan,message pops up stating PLEASE RUN CHANNEL AUTO SCAN,
If when You scan, and you don't get at least one channel, it will keep showing You this message! look at screen it will show new channels! if no new channels check to make sure your coax is hooked up good, also make sure you are using right setting if outside antenna, select antenna, if cable select cable for your source!
Nov 03, 2016 | Televison & Video
NTD-1356 Auto Channel Scan not finding channels
Cable TV comes from the receiver to the monitor (ntd 1356) thru a cable the ntd 1356 tuner needs the external antenna to be installed to work
Check the inputs for external signals
Oct 29, 2016 | Televison & Video
If there is no channels after scanning is it the outside antenna?
Do you see any channels [as a glimpse], during auto-tune. If you see them for a moment during channel auto scan, and do not store them in the TV memory, after the channel scan has been finished; the fault is with the TV itself. If you do not see that glimpse of programs during channel auto scan, there are two possibilities.
1. The tuner of the set is faulty.
2. The set do not get any signal to process [might be antenna].
Aug 14, 2016 | Televison & Video
I cant pick up any channels on my 32'' Emerson hdtv with my channell scan
Did you select antenna in the setup menu?
If you did and still can't receive anything you may not be receiving signals strong enough. Read the setup instructions in the manual. link below.
LC320EM9 EMERSON LCD TELEVISION Manual
Sep 09, 2014 | Emerson LC320EM9 32 in. LCD HDTV
32in Vizio getting no channels
You have to go to your menu screen and change the settings from antenna to cable that should take care of it, and should be able to do a auto scan to load channel memory
Mar 26, 2013 | Vizio VX37L Television
Shows "no signal" on my
when you say jack in antenna, I assume you mean you have an outide antenna. If you have never recived over the air signals before you won't now. If you have cable tv, then go into setup and set your scan channels to CATV and not Outside antenna, or what ever it might be called on your set. i need more infomation before I can give you more advice
Mar 17, 2011 | Televison & Video
RCA HD52W59 HDTV Plug in digital antenna into air antenna input then run channel scan =0 channels What should I do next??? Mike
Make sure you are connecting the digital antenna to the digital antenna input on the back of the set, then rescan. Most over the air Tv signals migrated to digital transmission and therefore the analog input is mostly for older analog devices. If you still do not get any channels, then you need to make sure the antenna you are using is rated for reception in your area. You can check for proper antenna size and channels available here,http://www.antennaweb.org/aw/welcome.aspx
Feb 08, 2011 | RCA HD52W59 HDTV Projection Television
Shows "updating". Never completes. Pulled power plug and retried. No help. Displays channel 0 until antenna is pluged in then updating. Displays "antenna failure" if antenna is unpluged during "updating".
Oct 11, 2010 | Pioneer SIR-PNR2 SIRIUS Radio Receiver
VIORE PLC7V95 7'' portable TV, cant get channels when scan
I notice that on mine, the positioning of the included tv antenna is very, very, very finicky. I also don't know how to "add" a new channel other than to hook it to the big house antenna and pick "re-scan" (or auto-scan or whatever it's called).
So I think your best bet is to pick a better antenna or know that even the tiniest fiddling with the antenna makes a diff. Sometimes, I even have the antenna horizontal (using the magnet) to get the good reception on a given channel. Seems like a hassle except that what should I expect from a tiny antenna....
Jun 15, 2009 | Televison & Video
Can't get cable stations
you have to go into the menu and set for cable then scan for active stations.
Mar 15, 2008 | Televison & Video
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Electro Med Services...
