Question about Panasonic Televison & Video
I have a panasonic digital projection tv. I turned it on thanksgiving after being gone all day and the red is out to the left, I went into color convergence and could not get it to come back in. Any suggestions?
  • 2 more comments
  • Matthew Johnson Jan 02, 2011
    Pansonic PT-53TWT53G
    Sorry, typed an extra t in the model number. Yes that is the model I meant and I will check it out. Are the parts expensive? And is this something I could purchase thru mouser.com?
    Sorry, im not sure what the dc board is. There are two large boards with a smaller board mounted to one of them and then a small board for each projector lamp. Is it the smaller board within the larger board?
    I see a lot of heat sinks like the ones near that one but nothing like the one that is circled in the picture.
  • 4,889 Answers
If you have already tried to adjust the convergence and cannot adjust it, then my money would be on blown STK amplifier ICs. There are usually two of them that need to be replaced along with the 12-15 resistors in the circuit. Please tell me the make and model of the set so that I can advise what replacements are to be used and how to replace them(requires soldering skills).
Posted on Jan 02, 2011
  • 3 more comments
  • eagle338
    eagle338 Jan 02, 2011
    Do you mean PT-53TW53G? Verify if the chassis is B19 coz I am not able to locate PT-53TWT53G. The IC is STK392-110. See the link below for the service manual, that should help you with the disassembly. The IC is located on the board that has the flyback transformer , from which two thick wires go into the CRTs. They are attached to aluminum heatsinks on that board. There should be two of them. You should replace both along with all the resistors in the circuit(see schematic on page 96. IC 2303 and IC 2302)
    http://www.mediafire.com/?cop19tu5q5wb0l...
  • eagle338
    Not the ICs are really inexpensive(should cost you about 15$ each) and the resistors are even more cheaper. You should also purchase thermal grease to apply to the new ICs before soldering them in. I would like you to verify the IC number before ordering though. The IC in the schematic shows 25 pin, which is not what 392-110 has. The number will be printed on the ICs themselves.
  • eagle338
    Ok. Its not the A-board schematic that you should look for , but the DC-board schematic which is not in the schematic. IF you can get me the board markings of the resistors, I will check the parts list and can tell you what their values are so that you can purchase replacements.
  • eagle338
    Have a look at this image. Do you see a heatsink like that?
    http://img.villagephotos.com/p/2002-12/7...
  • eagle338
    Look behind each sinks for a black IC like the one shown image. It is covered(partly) with white paste which is the thermal glue. It has STK-392110 inscribed on it. If you cannot find it then get me high-res images of all the heatsinks so that I can find it for you. You can upload the images to imageshack.us and get me the direct links.
    Sai.
I have mitsubishi vs-50800 i was watching a movie and the screen just all of a sudden went blury and the color is all mixed up i went to the convergence menu and it wont allow me to move the colors left or...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 03, 2011 | Mitsubishi VS-50800 50" Rear Projection...
Panasonic Cinemavision PT-56hx41e, wording on screen is red?
the convergence circuit governing the red picture has gone defective and needs attention possibly a convergence amplifier IC or and convergence coil at the red CRT went defective
Apr 28, 2010 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic pt-47wx53g red is out of convergence range
Have you moved the TV recently?, if so the red can(Red source) in the back bottom of the TV may have physically shifted in its holder, this is common when a rear projection tv is moved, jostled. Take the back off, look at the three cans,Red, Blue, Green, see if they all look like they are nested the same, bet the red is shifted a little.Good Luck with it!
kskip69
Aug 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
PANASONIC PTK-4077S PROJECTION
You need to adjust screen drives on Red Green Blue tubes ,does all 3 of them light up? Focus/screen control box is in front of TV behind front panel Turn color off then adjust all 3 tubes to where you have a black and white looking picture, now turn color back on.
Dec 27, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Tv went red and now power will not stay on
If one color goes out of control, the TV will auto turn off for safety reasons. Sounds like a red bias resistor has burned out. A tech will be needed to trace this problem. Sometimes there is a knob behind the front TV speaker panel for adjusting the color bias levels. You could try to mess with it if you are able to find it. I would just get a tech. Could be a cheap repair.
Nov 13, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Power problem
would require some troubleshooting, common problems would be convergence amp ic and high volt transformer transistors
If you are really brave tackle this TV FAQ.
http://repairfaq.ece.drexel.edu/sam/tvfaq.htm
Dec 04, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Red Gun screwy!!
You have a typical convergence problem here that happens on just about every tube type projection TV set ever made. There are two STK IC's that will need to be changed. Best thing to do, if you have any soldering experience on printed circuit boards, would be to get the service manual, locate the convergence amp IC's order the correct parts and not any replacement IC's that cost less the 20 bucks, and change the IC's. If you have no solid state repair experience, play it safe and call in a pro to assist you in this repair. Good Luck
Jun 30, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Rear projection tv
This sounds like the solder joints have cracked on one of the convergence IC's or the IC itself has gone bad. First determine which color has shifted inward on the left side (let's say red)and then find which output IC is labeled with that color and an H (RH) and resolder or replace that IC.
Jun 27, 2007 | GE 46GW 948 46" Rear Projection Television
Color guns out of alignment
It sounds to me like the convergence amps themselves have failed. Ic7001 and Ic7002, both are STK392-110 Sanyo built Ic's and not an expensive job for a qualified shop. When shopping around for a shop to repair it ask what they charge for replacement of the convergence amps in this unit. And take the unit to them to save pickup and delivery charges...
Have a great day!
Bill
Dec 21, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
