Question about Dell 922 All-In-One InkJet Printer
It pulls the paper in stronger on the right side and then gets stuck.
    Problem Solver:
  • 14 Answers
Check the paper feeder if have a foreign object.. you must disassemble the unit to see the paper feeder clearly.
Posted on Jan 02, 2011
Paper is pulled into printer unevenly causing paper jam
Look closely at the "path" that the paper takes through the printer -- you probably have a small piece of paper stuck somewhere, that is causing the paper-feed to get "skewed".
Failing that, take the printer to a qualified technician.
May 26, 2010 | Dell V313w AllInOne InkJet Printer
Printer pulls paper in from one corner
this problem occurs only when one side of the paper spooler is jammed and stuck. the spooler pulls the paper causing the paper to rotate inside the printer and getting stuck.
take professional help in clearing the jam and freeing up the spooler.
Mar 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam. paper pulls towards the right hand side and jams
Sound like you have something stuck in the paper feed path, check for a paperclip or similar, it may be that you have had a jam and torn off a piece of paper inside the printer which is now stuck, when removing jams from any nmachine allways pull paper in direction of feed never back on itself as it can cause this very problem
Dec 03, 2009 | Dell 810 All-In-One InkJet Printer
Paper will not pull from left side
Hi, I think you may have a sticking rubber roller. Very carefully check that all rubber rollers in the paper path are turning freely. The other cause is dust, this is a regular problem that I face and the solution is a tissue (best is toilet roll, stronger) soaked in clean water and then wrung out. Wipe all surfaces clean in paper path. If this clears all problems = result. If not, time to buy new (if under warranty, complain) but out of warranty, my experience is replacement is cheaper than repair. Should you find a sticking roller to shaft, UNDER NO CIRCUMSTANCES USE OIL, use water and wash through gently, HAVING 1ST DISCONNECTED FROM ELECTRICAL SUPPLY. Be lucky
Aug 25, 2009 | Dell 924 All-in-One InkJet Printer
Paper jam at B2
remove the paper tray or all paper trays that you have.
To remove the a tray first you should pull it towards you the most you can than by pulling towards you and in the same time you should lift it up.So again i will explain the procedure, first when is pulled to the max out of the copier you should lift it up for some 45 degrees and than pull it toward you. When you will remove the paper tray or trays inside of the copier where ware the paper tray on the right side of the inside should have some piece of paper which is stuck there. After you will remove the piece of paper the copier should not jammed the paper in B2.
Also see do the paper in the tray is putted as most close to the right fence of the tray, also see do the right green leveler is also closest to the paper in the tray. If the paper on the left and right side of the upper named fences is loosen than the rubber on the right side of the tray will not be able to pull up the paper in the copier when it will need to do it.
Jul 11, 2009 | Ricoh Aficio 2015 Copier
The paper is stuck in my printer
There should be a little door on the back side of the printer at the bottom. On the left or right side there should be a tab that will allow you to unlock the door and open it. There you can slowly pull out the paper.
Jun 18, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printer 2480- my printer is pulling paper only on right side
Try this :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
Paper jam on right side
its the problem of the gears which pulls the paper that gears needs to be replaced or the printer needs to be serviced internally.
Dec 09, 2008 | Canon PIXMA MX310 All-In-One Printer
MP390 paper jam at feeder
First thing that comes to mind is that SOMETHING you (or someone) fed in, had a paper clip, staple, crinkle or some other unnatural thickness on one side of the paper - and it's stuck inside the feed mechanism.
I had the same exact thing with the feeder on my shredder. You have to get right inside you printer to find the problem.
Watever it may have been probably got stuck in the paper path so EVERYTHING from that point on gets skewed as it gets sucked into the printer and jams.
Can you get "IN" to clear the path?
Mar 30, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Paper feed problem
Sound like something foreign is in paper path
Dec 24, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Dell 922 All-In-One InkJet Printer Logo
56 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
