Question about Dryers
What is the common belt routing for a admirial dryer drum?
  • Dryers Master
  • 7,482 Answers
Go to this website and view pictures of the routing of belts
Please rate me.
http://www.applianceaid.com/images/belt-config.JPG
Posted on Jan 02, 2011
My whirlpool dryer is making a very loud noise when on< sounds like it is destroying everything in the dryer. i checked the dryer hose all clear of debris!!
you will need to open up the dryer, make note of the belt routing and remove the drum as the drum rollers/glides are bad, here is a website. Hope this helped Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
belt routing:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
May 22, 2011 | Dryers
Tip
Gibson Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
!970- 1995 models use this diagram
Style: Flat with ribs
Installation Tips: Ribs face toward drum
1995 – present models use this diagram
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 06, 2010 | Dryers
Tip
Hotpoint Dryer Belt Diagrams and Replacement
For Hotpoint Dryers
1970- 1990 standard capacity
Installation Tips: Ribs against drum
1970- 1990 Large capacity
1990 – to present
1b9906a.gifStyle: Flat with ribs
The belt has come off my dryer and I'm tryint to put it back on, how do I get a digram of what it looks like when the belt correctly back in place?
It is something that you can repair yourself
You probably have a tensioner that has broken.
I am sorry but I do not have the Samsung routing available to me.
Below is a chart of the most common routing of dryer belts.
The part that has failed on your unit is probably the idler pulley/brackett.
You should be able to repair it without having to remove the drum
Apr 26, 2011 | Samsung DV218AEW Electric Dryer
Belt replacment
Here is a diagram from kenmore corp. that should help you out
Maytag Dryer Belt Routing
This is the most common belt routing found on most Maytag brands clothes dryers.
Since you will have everything disassembled to change the belt, this is an excellent opportunity to vacuum out the cabinet to remove dust and lint and perform preventative maintenance on your dryer. When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Dec 04, 2009 | Kenmore 66862 Dryer
Tip
Kenmore Dryer Belt Diagrams and Replacement
For Kenmore models starting with 110 or C110 with a removable back use this:
For dryers starting with 110 or C110 with nonremovable back use:
For Dryer models starting with 417 use:
I have a kenmore 27 inch electric dryer that when you push the start button it sounds like it starts but the drum doesn't turn. What could this be?
A clear indication that your dryer belt is broken is when the dryer drive motor runs but the drum does not rotate. A new belt is relatively inexpensive from several online or a local parts vendor, but installing it can be a bit frustrating since the dryer drum usually needs to be remove to install a replacement belt. Access to the interior of the dryer is usually necessary. For Maytag (and some Kenmore) models, the front of the dryer can be easily removed (two screws below front contour) by pulling out on the bottom of the panel and rotating up to release the top clips. Once off, place to the side, then remove four machine screws from the front drum/lint filter assembly, then remove by pullling out. Once off, place aside. Remove drum by lifting up and pulling out on drum (since the belt is broken it will not provide any resistance). Once removed, inspect the motor pulley arrangement noting the belt routing path around the motor pulley, belt tensioner, and the drum. Inspect the drum for belt wear marks, noting approximate location on drum where belt rides. Install replacement belt by routing through pulley arrangement (ridged side of belt rides againt motor pulley), then "hang" the belt on the interior backside to enable reaching the belt after reinstalling the drum. After placing the drum edge on the rear rollers, lift the front of the drum up into position, working the belt around the drum into the drum groove. Once the belt is in the groove, the drum should stay in position without lifting from the front. Check for proper pulley routing, taking care to avoid routing the belt OVER the tensioner belt keeper, i.e., route the the belt under the belt keeper to avoid belt riding on the keeper and failing prematurely. Install the front/lint filter assembly. As you manually rotate the drum, reach along the top and side of the drum and gently pull the belt out of the groove and into its normal ride position. Install the front panel, plug the unit in, start and check for proper rotation of the drum.
Oct 04, 2009 | Kenmore Dryers
How to install drum belt in Amana Model LED20AW. This model does not have front or back panels to remove. Fabio
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Amana DLE330RAW Electric Dryer
Replace dryer belt
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
