Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Internet connection problem.
My Macbook won't connect via Airport to our linksys router even though the connection was strong ten minutes before. I was about two feet away from the router, with absolutely no obstacles.
    Novelist:
    Champion:
  • 382 Answers
If you have a macbook, it should have 802.11n, which gives you a 50ft range. Your linksys is probably the wireless G, which gives a 30ft range. Pull the power cable from the router and put it back in 5 secs later. Notice if you get flashing lights on the activity displat on the router. Linksys is the consumer side of Cisco. Ive seen those linksys routers blow in rainstorms. You may need to have to plug the computer to the router with an ethernet cable and reconfigure the wireless.
Let me know.....I can assist you in resetting the router.
Posted on Jul 11, 2008
I have a Linksys wireless-G 2.4 GHz router directly connected to my PC. I've just bought a MacBook Pro and want to go online via this router. The Macbook finds the router but cannot connect to...
The reason you cannot connect, is you have to match the settings from your router to Airport- usually it requires you setting the security on your router to a specific WPA2, Wep, or no security- invariably I have had trouble getting clients to get online with the WPA2 set to the either or setting- but set it to either public or private- they're online. Anyhow, in order to do that- you will need to log into your router- if you have a pc/mac hard wired into the linksys via ethernet, open a web browser window and go to 192.168.1.1- it would be under wireless security. Match the settings on your Macbook, you should be able to go wireless at that point. Another solution, depending on your internet service provider... is that the provider could share your system remotely and assist with getting you online wirelessly (I know for a fact that Verizon DSL Business does do this. )
Jan 01, 2011 | Linksys Wireless-G WRT54G Router
Is too short for her MacBook Pro. -Thanks.
I would recommend purchasing a newer router that is more powerful. The Apple Airport Extreme is a fantastic router. If none of these choices work then you can either connect your Macbook via ethernet or move it closer to your router. here is the Apple Airport Extreme. http://store.apple.com/us/product/MC340LL/A/AirPort-Extreme?mco=MTY3ODQ5OTY
Dec 19, 2010 | Linksys WRT54G Wireless-G 802.11g...
Attempting to connect new Acer netbook to existing Mac network
Had the same problem. What i did was in the Airport Configuration program goto "Airport" then to "Wireless" and then to "Wirelesee options" In this menu deselect "Use wide channels". Also i decreased the power of the 5.0 Ghz transmission, because i don't use it yet. But i think the "Wide channels" is the reason of the problem. It is a bit weird thoug, on my Airports Guest acount with no password and incryption, the Acer One loged on perfectly, but on my private network with WPA2 it did not. Aparantly the Guest network does not use "Wide Channels" Hope this helps, but take care, maybe the menu's are called differendly because i had to translate them from Dutch. Good luck.
Aug 11, 2009 | Apple AirPort Extreme Base Station
Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Mar 10, 2009 | Apple AirPort Extreme Router
Macbook loses wireless internet connection
Hi 8233 is a good choice for a router
Here's your solution
1. These steps are to be performed strictly from a computer which is wired.
2.Even if you are using your mac book turn of the airport and connect it via a cable.
3. Open your router setup page by typing in 192.168.2.1 on your browser tab or typing i http://192.168.2.1 in the run window
4.An rsp will open and on the top right hand corner of the screen it will say Internet status:: connected
5.On the left hand side change you"ll see channell under wireless
6. Select it and change it to 6 or 11 for best signal strength
7.Now to the most important segment 8233 has a piculiar issue with its extra strong security
8.On the left hand side under wireless you"ll will see an option called wi-fi protected setup
9.Select it and turn it off reboot router and wow the problem should definately be resolved .
Then turn on airport and go wireless along with your wife.
10. You will still be secure with your data through security option on your router (wep or wpa )whatever you use .
Thank you and just let me know if it worked or not
Feb 26, 2009 | Belkin (F5D72304F5D7000) Router
Can't connect!
First of all... Unplug the modem, unplug the Airport (WiFi router) and turn off the Airport connectivity in your MacBook.
After 5 full minutes... Plug in the modem.
Wait 2 full minutes... Plug in the Airport.
Wait 1 full minute... Turn on the Airport connectivity in your MacBook.
After all of that...
If you're still not back up and running and you're using an Apple Airport, open the Applications folder, open Utilities, open Airport Utility.
If you're using any other type of WiFi router, use the Network Diagnostics button that should show up in the web browser window when you try to go to any website.
Aug 28, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook pro network connection
Verizon, the ones who sent me the router, helped me fix the problem. The router/modem software has to be updated because the old software can't work with the new version of leopard. The technical support guy did all of the updating via a screen share, so your best bet is to call the company who sent you the router and get their help.
Jul 08, 2008 | Westell Wirespeed VersaLink...
MacBook Internet connection
ok call me or I can post for you. I know what your problem is. But i need to know what model netopia router you have. Kepp in touch
Thank you
Jason
Feb 09, 2008 | Apple MacBook Pro Laptop Computer with...
Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Sep 27, 2007 | Brother MultiFunction Center MFC-440CN...
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
111 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
MarkMAlford
MarkMAlford
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
