Question about Toys
I bought the K B Classics Build & Load Track Set and when, I thought, putting the battery in the motor the whole thing fell apart. Unlike all other toys with batteries, the screws were to hold the inner parts together. To load the battery I was supposed to just pinch the sides together to open. Anyway the gears and axles all fell out and I can't figure out how the parts go back together. I am sure it is simple. If you can help, please e mail me.
I just did the same thing. Did you have any luck finding out ow to put it back together?
Posted on May 08, 2011
I did the same darn thing....did you ever have any luck?
Posted on Jan 23, 2011
Polaris snowmobile..chain broke. And the spike things broke. Bought a new chain case..i put it on and my track is locked up and wont move.. ne ideas please.. asap
Dear Danny,
Sorry about that.
Unfortunately, sometimes the obvious is not the problem.
You, or someone, must take apart the whole track and look inside, because I think the problem in internal.
Something broke or wore out inside, causing the chain to break and the sprocket gears to fail.
God bless your efforts.
Jan 12, 2016 | Winter Sports
How do I put the driver side power window back on track and the door panel for my 2003 Nissan Altima 3.5SE?
R/R the inner door panel, slide the window back on track, reconnect the window transmission to the window, (or reinstall the trans) bolt everything back together (window motor, window trans to door etc.) Make sure the window is in the UP position. use the switch to raise the window & keep it up if all is back together before finally installing the door panel ( make sure the switch & other plugs are plugged in before the door panel is reinstalled.) Lights etc. Good luck
Sep 14, 2014 | 2003 Nissan Altima
Manual for black and decker circular saws #7301 type A
Okay im restoreing an old Black&Decker circular saw 7 1/4 volt 120ac Amps 9.0 Type A Rpm 4900 now im putting it back togather and i need help Ive got evrything else down patt just what the saw blade sets on there's like a lil motor that is togather where the blade goes and has teeth all around it and connects to the big motor it has a pin there ive found that just when i put it all togather there's a gap there and dont know why ive took my time and went from one screw to next easy and still does the same thing i thought maybe something was in the way where the two plates screw down but there is nothing in the way any idea's help me please
Jan 12, 2012 | Black & Decker Saws
Opened the wrong compartment to change the battery and the gears fell out. I need a picture of gears to get it back together.
This is Bertie the bus. It stopped working so I took it apart. The Philips head (criss-cross) screw gives access to the battery. You're not supposed to take out the screws with triangular socket heads. If you do everything falls apart and you need an engineering degree to know how to put things right.
This battery holder is clear plastic, instead of black, so I can see what is happening after assembly. The red wire broke off the motor while I was looking at it so I had to resolder it. The red plate on the upper part swivels, it has an arm that holds the clutch plates together when the switch is on. The long white arm at the upper end of the gear assembly should fit into the slot of the red swivelling plate. I think it is supposed to be a noise-maker.
Bertie is supposed to go on the road, not the track and there is a plunger that cuts out the power when it is on a wooden track. This stopped working so I jumpered it to be always on.
Good luck.
Aug 25, 2011 | Seth Thomas Thomas & Friends Percy Train...
I need help taking apart my drivers side door on a 95 Pontiac Firebird in order to fix my window that partially fell off of the track. Also what would be the best way to fix the window issue, an adhisive...
If the door fell off the track then either the track is broken or mis-aligned. Don't use glue or tape, find out what caused the door to fall off in the first place and correct it.
Your parts store should have a diagram of the door and can tell you where the screws and pins are, othewise you can just pull out all the visible screws (including the one on the door handle) and the other things holding the door on are plastic push fittings. To take these out you just have to find the fittings and pry at them with a wonderbar.
The parts store can also sell you a new track/motor/etc.
Jun 07, 2011 | Pontiac Firebird Cars & Trucks
Bought a KB classics build & load track set. The small car fell apart when I thought I was putting in the battery. Instead when I unscrewed the car, the small motor just fell apart. There are...
i have the same exact problem, tried to put the gears back together myself and couldn't figure it out. i tried to see if i could just order another car car but no luck with that either. please let me know, as well
Jan 01, 2011 | Toys
Power window
It is probably just off of the track. It could be worse. take the door apart and put the window back in the guide (track). Hope this helps.
Aug 31, 2008 | 2000 Dodge Durango
My ps2 's tray just continues to spit out the loading tray!!!
You have to take it partially apart again. Remove the Cd tray. Look at the bottom of the tray and you will see a narrow track that runs the length and turns an L. The white piece that is between the laser drive and the cd tray motor has a white tit sticking up. When you put the tray back on, be sure the tit tracks into the track on the bottom of the CD tray.
Nov 27, 2007 | Sony PlayStation 2 (PS2) Console
Toys Logo
323 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
